Tool offset patch
13 years 5 months ago #34310 by cmorley
Replied by cmorley on topic Re:Tool offset patch
hmm I didn't do anything to that patch other then update it so it applied cleanly.
Should be no different from the original.
If your interested in trying a experimental patch I have one available that switches to an INI switch and fixes the G10 problem.
(tool setting changes the wrong offset entry)
File Name: lathe_styl...atch.zip
File Size:2 KB
Remember experimental - it has minimum testing.
If anyone tries it please let me know.
Chris M
13 years 5 months ago - 13 years 5 months ago #34311 by jlviloria
Replied by jlviloria on topic Re:Tool offset patch
Chris,
The version I had installed before had other things.
I will try this new version. you will be so kind as to explain briefly that's different
thanks,
Jorge Viloria
Last edit: 13 years 5 months ago by jlviloria.
13 years 5 months ago #34312 by jlviloria
Chris,
thanks,
Jorge Viloria
13 years 5 months ago #34313 by DaOne
Replied by DaOne on topic Tool offset patch
Chris, No it does not do a change without the m6 command. I do have the tool 1 and tool 10001 in the toolfile.
Is there anything else i need to do after the "sudo make setuid" command of should it just work after that?
In the readme it says...
"to run the software go back to the top level directory, and issue:
. scripts/rip-environment
linuxcnc"
This have anything to do with it??
The patch did apply and the make went without an error.
13 years 5 months ago #34314 by cmorley
Replied by cmorley on topic Tool offset patch
If you haven't done that yet then yes.
It doesn't hurt to enter it twice anyways (it'll just tell you so )
If you don''t enter that commands then you are running the installed version rather then the RIP version.
When you start linuxcnc is should mention the version number: like 2.6 pre XXXXX
Chris M
13 years 5 months ago #34315 by cmorley
jlviloria wrote: Chris,
thanks,
Jorge Viloria
If you do you must add:
LATHE_STYLE_TOOLCHANGE = 1
under the [RS274NGC] heading
Chris M
The following user(s) said Thank You: jlviloria
Time to create page: 0.473 seconds
