- Thank you received: 6
Tool offset patch
- DaOne
Now here is where it gets weird...
It will only load this version is I run linuxcnc for the command line in linuxcnc-dev How do I fix this to make it the default app?
- jlviloria
- Thank you received: 9
but assumes wear backwards. digit 1 in Z and the display shows -1
sorry is my mistake
thanks
Jorge Viloria
- DaOne
cd linuxcnc-dev
cd src
sudo make setuid
cd ..
. scripts/rip-environment
linuxcnc
Can someone help me make the new build run as the default? Got to be something simple I am not seeing.
Thanks, sorry for being such a pain.
- Thank you received: 2181
jlviloria wrote: Chris, there is one detail, I notice now add the value of the compensation to 1000n, and Tn is the wear.
sorry is my mistake
thanks
Jorge Viloria
Ya Jorge when entering something like g10 L10 p10001 z.001
I am not sure what is expected in the tooltable. I woulda thought +.001 in the T1 position.
Chris M
DaOne wrote: Ok, the only way I seam to be able to make the new build run is by doing this every single time...
cd linuxcnc-dev
cd src
sudo make setuid
cd ..
linuxcnc
You _should_ only need the . ./scripts/rip-environment
(And I tend to have that in my .bashrc file)
To install you need to repeat the compile steps, with a small change:
./configure --prefix /usr
then make, sudo make setuid. and then the compile will over-write the installed version.
cd linuxcnc-dev
cd src
sudo make setuid
cd ..
linuxcnc
You don't need the sudo make setuid anymore.
The rest of the commands is what we all do. You can automate it with a script - someone else will have to give you a sample.
The other thing you can try is cd to the src/
and enter: make install-menus
If it still works, you we see extra entries in the Applications/cnc menu.
Chris M
