Error in ArcBuddy
  • Sterling
  • Sterling's Avatar Topic Author
  • Premium Member
  • Premium Member
25 Oct 2013 03:41 #40267 by Sterling
Replied by Sterling on topic Error in ArcBuddy
Well...that's interesting. :dry:
If I were encountering this problem, I would...
#1) Ensure that ALL versions were uninstalled
#2) Reboot the computer
#3) Re-install the software (Possibly using a different file = meaning if you used the 'Installer' for your WinXP machine, try the ZIP file instead, etc...)
...if that didn't work...I'd start looking for help on-line; this is new to me as well~!
  • Sterling
  • Premium Member
  • Premium Member
25 Oct 2013 03:45 #40268 by Sterling
I looked up their User Forums and did a search regarding "CAM Export". I turned up nothing that would help. :(
25 Oct 2013 19:53 #40285 by BigJohnT
Replied by BigJohnT on topic Qcad CAM
I looked in scripts/Cam/CamConfigurationsGCode.js and it has an include for scripts/Cam/CamExport/CamExporter.js and neither the tar or the installed have that file. That may be the problem.
26 Oct 2013 18:13 #40310 by BigJohnT
I got on the Qcad forum and the latest update fixes the missing files.
The machine file GCode converts to mm. There is supposed to be a machine configuration file GCodeInch but it is lost too. I'm going to try and create a LinuxCNC machine configuration file.
JT
26 Oct 2013 19:12 #40314 by BigJohnT
Wow this has gotten pretty far off topic. I created a new topic in the CAD/CAM section to continue discussing QCad CAM. BTW, I have the inch solution over there too...
linuxcnc.org/index.php/english/forum/31-...27145-qcad-cam#40313
JT
