Arc Tolerance
11 years 10 months ago #54264 by ArcEye
Replied by ArcEye on topic Arc Tolerance
BigJohnT wrote: To get a branch just do:
To list all branches do:
git branch -r
That just shows the holes in my git-fu
The man page says that command is to list remote branches, I was using just git branch to show the local ones for this clone, obviously not correct.
Like you say, muchos branches :laugh:
11 years 10 months ago #54266 by ArcEye
It now looks as though Seb fixed this in 2.7 on Sunday, presumably after some discussion with Dewey
commit 2cc22013dfdbd33ceba36570ed78711e0d310e99
Author: Sebastian Kuzminsky <seb@highlab.com>
Date: Sun Dec 21 19:35:32 2014 -0700
interp: use the same arc radius tolerance in inch and metric
Signed-off-by: Sebastian Kuzminsky <seb@highlab.com>
I am chasing my tail here.
I'll wait and see if Dewey wants to go ahead with the rest of the patch
11 years 10 months ago #54271 by BigJohnT
Replied by BigJohnT on topic Arc Tolerance
I missed that commit... now it is down to being able to set the tolerance from the ini or not. I too shall wait and see.
JT
11 years 10 months ago #54279 by BigJohnT
Seb said this on the IRC
<seb_kuzminsky> JT_Shop: cradek had the very sensible idea of making the arc tolerance so large that any valid arc in "imperial rounded to 3 figures after the decimal point" or "metric rounded to 2 figures" would be accepted
Reading back there was quite a bit of discussion on arcs lately.
JT
11 years 10 months ago #54313 by ctrl-frq
Replied by ctrl-frq on topic Arc Tolerance
WOW !
Got busy on my end and just got back to learning more just today. I want to thank you all for taking the time to look into this. I am blown away by your interest in the issue and just by what you found out by looking at it (the difference between mm/inch).
My internet searches revealed that the topic does come up all over the place (various package Cam forums) with Lcnc users, and the answer has always been to fix the cam output. Perhaps some "cam" programs will always have trouble keeping things within the defined limits.
I have to wonder what it was that prompted the developers of the control I have used all these years to add the tolerance option. I am going to assume it has been there since 1998 or so, because I have been using the same program to create code and run on the control.
In any event, it would be wonderful to have this adjust-ability via INI if that is where it fits.
I have been able to wrap up my wiring and actually run some files. I have plenty of them that do not use arcs, just short line segments. I'm finding a few things here and there that surprise me, but I am making good headway. With the machine moving, homing, running files and me getting familiar with gmoccapy, my next step is to thoroughly read documentation so I am not asking silly questions in the future.
THANK YOU for all the assistance !
  • seb_kuzminsky
  • Visitor
  • Visitor
11 years 10 months ago #54396 by seb_kuzminsky
Replied by seb_kuzminsky on topic Arc Tolerance
ArcEye, Dewey, I like the patch that you're developing. It'd be a good addition to 2.7. I'd like to see a couple of changes, however.
1. The default tolerance (if none is specified in the ini file) should be 2 * 0.001 * sqrt(2) for inch, and 2 * 0.01 * sqrt(2) for mm. This would mean that any valid arc where the endpoints and/or centerpoint got rounded or truncated to 0.001 inch or 0.01 mm precision would be accepted, which i think would be a good default behavior. I've verified that Rob Ellenberg's new trajectory planner in 2.7 handles this amount of arc radius slop just fine.
2. I'd like the values in the ini file to be bounded. The largest acceptable value should be the defaults above, and the smallest acceptable should be 0.
Sound good?
Thanks for your work on this.
Time to create page: 0.290 seconds
