- Thank you received: 240
Arc Tolerance
- ArcEye
11 years 9 months ago #54575
by ArcEye
I know what you mean, I was happier with the original 0.005" and 0.0127mm and being able to make them looser.
As said, I think the rationale of the formula is to cater for the rounding up effect for each base, rather than give the same tolerance for inch and mm
It strikes me that this presents the same relationship that originally existed, except looser by approx 50%, so maybe that was the reason for the original values?
I have not heard from Seb yet, I will give him a few days and if nothing may put the patch onto the developers list, with a query regards the views of having different values
Replied by ArcEye on topic Arc Tolerance
I don't understand the rational of setting the default to different values and the min to the same value. Seems to me if 0.002" is good then mm should be 0.05, or the other way around if 0.25mm is good then inch should be .001" Maybe I just don't understand the logic of the default setting.
- ArcEye
11 years 9 months ago #54582
by ArcEye
PS
Just in case it is not clear from the patch, don't lose sight of the fact that the tolerances can be set in the ini file, that is nearly the whole point of it.
Whilst you may not like the defaults, and I have followed the guidance without wholly being convinced, you can set the tolerances you prefer like so in the ini file
[RS274NGC]
TOLERANCE_INCH =0.0011
TOLERANCE_MM =0.0282
In practical terms, to me the tolerance for imperial is completely irrelevant, as I only ever use metric.
For someone in USA, the reverse will probably apply
So long as the tolerance can be set to sufficient to allow CAM arc output to work, the end aim is met.
[RS274NGC]
- seb_kuzminsky
- Visitor
11 years 9 months ago #54590
by seb_kuzminsky
Replied by seb_kuzminsky on topic Arc Tolerance
Thanks for the updated patch, ArcEye. I'll look at it this week and merge it with Rob Ellenberg's updated spiral-arc handling code.
The rationale for having different tolerance for imperial and metric arcs came from this thread: www.linuxcnc.org/index.php/english/forum...ounce?start=10#54163
The user (ctrl-freq) has a g-code program written by CAM software, where the coordinates are rounded to the nearest 0.001 inch. This worked fine with a previous controller (not LinuxCNC), but LinuxCNC rejects the arcs as invalid because of the arc tolerance. The most that rounding to 0.001 inch in 2 dimensions can move a point is 0.001 * sqrt(2). If the endpoint and centerpoint of an arc move in opposite directions, that gives a change in radius of 2 * 0.001 * sqrt(2), which is where the suggested new arc tolerance value comes from. In metric, the rounding would typically be to 0.01 mm, for a metric arc tolerance of 2 * 0.01 * sqrt(2).
I opted to make the tolerance in each measurement system make sense in that measurement system, rather than pick one to make sense and have the other be derived from that. I'm hoping this will fix issues like the one ctrl-freq ran into, and make most old technically incorrect but practically workable g-code programs Just Work, no matter what units they're in.
And as ArcEye says, the user can change it in the .ini file if they care.
- IndyColts
11 years 2 months ago #61241
by IndyColts
Replied by IndyColts on topic Arc Tolerance
Hi all. I am new to this so please excuse my level of knowledge. I am trying to understand how the patch is to be applied and have a few questions. When mentioning the 2.7 and 2.8, is that actually refering to 2.6.7 and 2.6.8? As for the patch itself, are all the commands in the patch supposed to be entered line by line in a terminal window, or is it an executable file that can install it. And last, would just editing the tollerances values in the /rs274ngc/interp_internal.hh file work. Thanks again for any info.
- seb_kuzminsky
- Visitor
11 years 2 months ago #61244
by seb_kuzminsky
Hi IndyColts, the patch has been applied in our source code repo (git.linuxcnc.org). It went into the 2.7 branch and has been part of LinuxCNC starting with 2.7.0~pre3. No action is needed on part of users to include it.
By "2.7" and "2.8" we mean the 2.7 branch and the master branch (which may become 2.8 in the future). 2.7 is not released yet -- it has been in an extended stabilization period and is shaping up nicely. We've been making pre-releases from the 2.7 branch, including the 2.7.0~pre3 release in February 2015 that included this arc tolerance fix.
- IndyColts
11 years 2 months ago #61246
by IndyColts
Thanks for the explaination seb! I only saw the 2.6.8 rel and I never thought to do a search for 2.7.
Time to create page: 0.330 seconds
