G33.1 right hand tapping weird behavior H E L P !
11 years 3 months ago #60846 by tkamsker
We now have success
So remember to never ever have an encoder running faster than the spindle ;)-
11 years 3 months ago #60967 by joekline9
The A and B phases must overlap. If A is on B must turn on before A goes off. Then A must go off before B goes off and so on.
The following user(s) said Thank You: tkamsker
11 years 3 months ago #61034 by tkamsker
Joe you are right this should be ensured by the AMT102 Encoder itself the problem is only that if the spindle turns 1,7 times faster than the Encoder
you can not rigid tapping in steps and you can not spindle orient
that why i had to even write an component for that
my learning is next time it will be an mechanic solution ;)-
thx
thomas
The following user(s) said Thank You: joekline9
Time to create page: 0.822 seconds
