- Thank you received: 93
G71
- automata
7 years 5 months ago #134888
by automata
Replied by automata on topic G71
Hi Andy and Patrik T,
I think I have understood the algorithm for offsetting the curve by different values in X and Z axes.
Assumptions:
1. Profile is monotonic (increasing or decreasing) in Z axis.
2. Profile may or may not be monotonic in X
First apply Tool diameter compensation (like in milling) to the current profile using the cutter compensation by a value of K*2. This compensation is NOT similar to the turning tool nose radius compensation where the tool origin(tool control point) is also shifted. This offset is like the milling offset where, the tool control point is assumed to be at the center of a round tool.
Now the new profile is always K distance from the actual profile.
After this apply a linear offset of value I-K to the K-compensated profile. This will ensure that the flat portions of the original profile will have an offset of I from the new cut profile.
Further if Tool nose radius compensation is ON (G41,G42), then apply the tool nose radius compensation to the final shifted profile.
Same algorithm can be followed for G73 (pattern shifted profile).
Does this sound correct?
I will be doing a few mock-ups and trials in python for the roughing finishing pass before writing C code for it. Any suggestions are appreciated.
Regards
-automata
Assumptions:
Regards
-automata
7 years 5 months ago #134890
Replied by andypugh on topic G71
I am a little confused here.
I thought that the problem actually was lathe-tool radius compensation.
My Python algorithm already handles the X and Z offsets of the roughing pass.
Note that you might want to abstract X and Z (as my code does) to handle the G72 casw where the profile is monotonic in X but not necessarily in Z.
There might be an argument that lathe tool compensation isn't 100% necessary during the roughing phase, if enough material is left on for the finishing phase which can be run using existing code.
Why bother with a Python mockup when there already is an extensively checked one?
- automata
7 years 5 months ago #134894
by automata
Hi Andy,
In the current cycle implementation you have programmed, with high depth of cut D, we are left with high amount of material on the horizontal sections if the Depth of cut is not an exact multiple of the radius of the flat sections.
The material left over is high enough not to allow a uniform finish pass.
For eliminating this high leftover material on horizontal parts of the profile, most professional controllers offer a roughing finish pass which is offset by I and K from the programmed surface.
This is same as a G73 pattern cutting pass with I and K offsets.
So we need to run
I agree with you that there is an argument to be made for not having TNRC (tool nose radius compensation) during roughing.
However, I did add nose radius compensation to your current implementation by 2 methods
1. using self.execute("") in the python code. This will call TNRC if it is active in the code preceeding the G71 call
2. explicitly computing the G41/42 offsets in the individual cuts made and then use emccanon.* functions instead of self.execute("G1 Zzzz")
The I and K offsets are required by the roughing finishing pass at the end of G71 and also required by G73.
Point taken about making the axes computation generic to be able to reuse code in G72.
The reason for python mockup is ease of testing everything in python before pushing it to C.
-automata
So we need to run
-automata
- Patrik T
- Thank you received: 11
7 years 5 months ago #134913
by Patrik T
Replied by Patrik T on topic G71
Sounds good, I did the I - K thing you mentioned.
- r.lol
7 years 4 months ago #136204
by r.lol
Replied by r.lol on topic G71
Hi !
I've trying to get basic G71/G72 working and to get a kick start, I tried this branch . But Whiel running sample codes I received an error
And similar error was encountered in three out of four files present in nc_files folder:
There would be high probability of something being wrong in my setup but I'm not able to pin-point it.
I cloned the project, checkout the branch, compiled it and ran the sim-axis-g71-lathe configuration.
G71: The programmed profile has an exit ramp angle of 232.871519507 and can not be cut with the active tool frontangle of 87.0
G71test2.ngc
G72test1.ngc
G71test1.ngc
7 years 4 months ago #136206
This is a problem with the tool shapes in the tool table.
Though it seems a bit odd, as the tool table is part of the sim fileset normally.
With the tool selected, does the profile _look_ like it could be machined with the selected tool?
Time to create page: 1.901 seconds
