G71
7 years 5 months ago #134519 by automata
Replied by automata on topic G71
Hi Andy,
I am game to put the two together.
I have your G71 typeII python remap running.
I made some slight modifications and added G41/G42 cutter compensation to the python remap using some ugly hacks.
Computed the Z axis offset for each cut using trignometry. It is rudimentary and I would like to implement it inside rs274 so that we can use G41G42 compensation from the C++ code directly.
I also have the benporter/G71 running. I see how he has made the profile using profile and endprofile keywords.
Can you guide /review any changes to be made.
-automata
7 years 5 months ago #134688 by automata
Hi Andy, Partik T,
Any ideas on how to compute the roughing finish pass with thickness specified by I,K.
I checked benporter patch and because of monotonic requirement on the profile for both X and Z axes, the roughing finish pass will not eat up any profile segments.
Any ideas on how to handle same for non monotonic passes.
-automata
7 years 5 months ago #134718 by andypugh
Replied by andypugh on topic G71
I don't entirely understand the question but:
Could you add the offsets to the tool geometry before passing the data to the radius compensation code?
7 years 5 months ago #134733 by Patrik T
Replied by Patrik T on topic G71
I did it all from scratch, including the maths. So I have not investigated which parts of the existing code that can be combined and reused
7 years 5 months ago #134734 by andypugh
Being able to use the existing radius comp code (so that it is only done in one place, and consistently) is the only real reason to use C-code rather than the Python remap.
7 years 5 months ago #134742 by automata
Hi Patrik T,
1. How come you first rounded out there corners with Q word? Any reason for that?
2. Did you try the finish pass with very large value of the offset?
3. If you offset a semicircle with different values in X and Z does the offset curve still remain a part of a circle?
4. How did you calculate which of the offsetted curves in a valley that would result in a self intersecting offset curve. Would a self intersecting offset curve be allowed in your method? If not , how do you remove the self intersecting portions?
-automata
Time to create page: 0.485 seconds
