G71
9 years 1 month ago #99549 by skunkworks
Replied by skunkworks on topic G71
Could you share?
9 years 1 month ago - 9 years 1 month ago #99608 by Patrik T
Replied by Patrik T on topic G71
I tried to convince myself that I could use CAM or ngcgui, but in the end I just did the work. I did the G71 I had wished for, with pockets and fully compensated all the time. I also threw in fillet radii between all types of moves. At first I thought getting the most efficient retract between pockets would be arduous, but I found a brilliant way to do pockets easily, inside, outside or backwards. I'd share, at a fee.
The Python remap feature is great, thanks Michael.
Last edit: 9 years 1 month ago by Patrik T. Reason: A bad mood was showing through.
9 years 4 weeks ago #99857 by andypugh
Replied by andypugh on topic G71
I do hope that we will get G71 as an actual G-code at some point. I was hoping Ben was going to do it, but he seems to have found other things to do.
It's on my list. Along with multiple spindles, but I have a bunch of bugfixes that are higher priority, and only just got a working dev machine back.
8 years 6 months ago #108263 by Patrik T
Tapered propeller axle. Some vibrations, maybe should have used the tailstock. There will be another finishing cut and threads after cool down.
8 years 3 months ago #114131 by HalaszAttila
Replied by HalaszAttila on topic G71
Hello,
i want to implement G71 function in linuxcnc.
I found this version:
github.com/nkp216/G71
and a very interesting for me.
But in readme.txt tells that first step is to do the "remapping".
What this mean, and can someone please explain how and what to do to "remap" G71 in linuxcnc?
I never do this and dont know where to start.
On github site of project, i found simulated config, but this does`t work. Stops with error when i open *.dxf file.
Thanks. Attila.
8 years 3 months ago #114133 by andypugh
There is another version here:
github.com/LinuxCNC/linuxcnc/tree/andypugh/g71type2remap
The files you need are here:
github.com/LinuxCNC/linuxcnc/tree/andypu...configs/sim/axis/g71
Copy the Python folder to your config directory, then make the changes in [PYTHON] and [RS274NGC] from that INI file in your own INI file.
Documentation for the cycles is here:
github.com/LinuxCNC/linuxcnc/blob/andypu...ughing-cycle-turning
It was my intention to code the cycles in C and add them "properly" but I have not got round to it.
The following user(s) said Thank You: HalaszAttila
Time to create page: 0.143 seconds
