G76, Troubleshooting needed!
- Victor
30 Oct 2018 14:12 #119655
by Victor
Replied by Victor on topic G76, Troubleshooting needed!
But i have "loadrt lowpass count=1" in the custom.hal file
if i have this in the main .hal file:
loadrt lowpass names=lowpass.spindle
loadrt names=lowpass.spindle,lowpass.spindlepos
I get the error message that lowpass already exists.
I'm really out in the deep here so it would be greatly appreciated if you could point out exactly what should be in the main .hal file. and perhaps if i need to change anything in the code you provided earlier for custom.hal file.
Thank you!
Br Victor
Thank you!
Br Victor
- Thank you received: 4656
30 Oct 2018 14:20 #119656
Replied by andypugh on topic G76, Troubleshooting needed!
You can only normally have one loadrt for a particular component.
But there is a way round this, using TWOPASS.
You might as well do this, to make things easier later.
linuxcnc.org/docs/2.7/html/config/ini-config.html#_hal_section
So putin the HAL section of the INI.
Put the loadrt in the main HAL back to how it was.
in the custom.hal change the loadrt to:
You can call it something else if you want, but the name needs to match everywhere else it is used.
So put
TWOPASS=ONPut the loadrt in the main HAL back to how it was.
loadrt lowpass names=lowpass.0You can call it something else if you want, but the name needs to match everywhere else it is used.
The following user(s) said Thank You: Victor
- Victor
30 Oct 2018 14:48 #119657
by Victor
TWOPASS=ON did produce a fair amount of errors:
Br Victor
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.8
Machine configuration directory is '/home/victor/linuxcnc/configs/Emco-120P'
Machine configuration file is 'Emco-120P.ini'
INIFILE=/home/victor/linuxcnc/configs/Emco-120P/Emco-120P.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./Emco-120P.hal
twopass:found ./custom.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=5330
hm2: unloading
Debug file information:
Note: Using POSIX realtime
Unknown parameter `num_encoders=1'
waitpid failed /usr/bin/rtapi_app hm2_eth
/usr/bin/rtapi_app exited without becoming ready
insmod for hm2_eth failed, returned -1
while executing
"hal loadrt hm2_eth board_ip=\"10.10.10.10\" config=\"firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=2 sserial_port_0=00xxxx\""
("eval" body line 1)
invoked from within
"eval hal loadrt $args"
(procedure "orig_loadrt" line 1)
invoked from within
"orig_loadrt hm2_eth board_ip=\"10.10.10.10\" config=\"firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=2 sserial_port_0=00xxxx\""
invoked from within
"eval $cmd"
(procedure "load_the_modules" line 22)
invoked from within
"load_the_modules"
(procedure "::tp::pass0" line 11)
invoked from within
"::tp::pass0"
(file "/usr/lib/tcltk/linuxcnc/twopass.tcl" line 556)
invoked from within
"source $filename"
invoked from within
"set result [source $filename]"
(file "/usr/bin/haltcl" line 55)
5330
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 432.153770] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 432.157533] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 432.935457] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 433.905079] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 434.912829] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 434.945826] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 436.392704] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 436.426326] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 436.428703] RTL871X: survey done event(e) band:0 for wlan0
[ 436.428765] RTL871X: rtw_indicate_scan_done(wlan0)
[ 436.913507] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 436.913521] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 452.945259] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 469.002603] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 491.024397] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 491.024410] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 495.032168] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 495.032182] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 499.041207] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 499.041217] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 501.046103] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 501.046117] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 515.073341] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 531.105388] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 552.154096] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 552.154110] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 552.158269] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 553.430111] RTL871X: Drop duplicate management frame with seq_num = 2432.
[ 553.912202] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 555.157960] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 555.191202] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 556.373330] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 556.406955] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 556.409577] RTL871X: survey done event(a) band:0 for wlan0
[ 556.409599] RTL871X: rtw_indicate_scan_done(wlan0)
[ 557.156698] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 557.156712] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 567.177000] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 583.209660] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 599.241498] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 615.274130] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 631.305504] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 653.349548] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 669.381568] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 672.154119] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 672.154132] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 672.158292] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 673.976706] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 675.416456] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 675.449575] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 676.419076] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 676.452577] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 676.455324] RTL871X: survey done event(c) band:0 for wlan0
[ 676.455347] RTL871X: rtw_indicate_scan_done(wlan0)
[ 677.397133] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 677.397147] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 685.413075] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 701.449776] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 717.482533] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 733.513459] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 761.570910] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 777.601296] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 783.611833] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 783.611846] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 789.624563] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 789.624578] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 791.628199] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 791.628208] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 792.154173] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 793.895329] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 795.640578] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 795.672205] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 795.677991] RTL871X: OnAction_back
[ 795.678001] RTL871X: OnAction_back, action=2
[ 795.678008] RTL871X: OnAction_back(): DELBA: 0(0)
[ 795.678027] RTL871X: OnAction_back
[ 795.678040] RTL871X: OnAction_back, action=0
[ 795.678064] RTL871X: issue_addba_rsp(wlan0) ra=08:60:6e:be:f2:60 status=0, tid=0, size=64
[ 795.679444] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 795.680115] RTL871X: Drop duplicate management frame with seq_num = 1148.
[ 796.343937] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 796.380452] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 796.382825] RTL871X: survey done event(a) band:0 for wlan0
[ 796.382934] RTL871X: rtw_indicate_scan_done(wlan0)
[ 797.046761] RTL871X: OnAction_back
[ 797.046772] RTL871X: OnAction_back, action=0
[ 797.047053] RTL871X: issue_addba_rsp(wlan0) ra=08:60:6e:be:f2:60 status=0, tid=0, size=64
[ 799.644052] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 799.644065] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 803.652638] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 803.652652] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 805.656357] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 805.656371] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 808.098325] RTL871X: OnAction_back
[ 808.098336] RTL871X: OnAction_back, action=2
[ 808.098343] RTL871X: OnAction_back(): DELBA: 0(0)
[ 821.691344] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 837.720396] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 840.561300] RTL871X: OnAction_back
[ 840.561311] RTL871X: OnAction_back, action=0
[ 840.561564] RTL871X: issue_addba_rsp(wlan0) ra=08:60:6e:be:f2:60 status=0, tid=0, size=64
[ 841.728466] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 841.728479] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 845.736727] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 845.736741] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 849.745830] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 849.745844] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 851.748558] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 851.748572] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 861.768923] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 861.768937] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 863.772481] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 863.772495] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 883.815343] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 899.844718] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 912.153748] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 912.153758] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 912.157954] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 913.938329] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 915.893202] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 915.926457] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 915.933698] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 916.376830] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 916.410325] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 916.412827] RTL871X: survey done event(e) band:0 for wlan0
[ 916.412847] RTL871X: rtw_indicate_scan_done(wlan0)
[ 917.881501] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 917.881515] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 931.910448] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 963.975332] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 980.005535] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 996.037100] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1012.069296] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1028.100968] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1032.153487] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1032.153499] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1032.157247] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1033.901579] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1034.118579] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1034.151328] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1036.128704] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1036.160081] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1036.167324] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1036.353081] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1036.386826] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1036.389202] RTL871X: survey done event(e) band:0 for wlan0
[ 1036.389223] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1038.120277] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1038.120291] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1080.205468] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1084.212048] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1084.212062] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1086.216087] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1086.216101] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1090.224211] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1090.224226] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1092.228313] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1092.228327] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1106.257058] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1122.289000] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1138.320878] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1152.154077] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1152.154090] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1152.158965] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1153.985454] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1154.357079] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1154.389704] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1156.369834] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1156.402210] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1156.409456] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1156.466581] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1156.501576] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1156.504082] RTL871X: survey done event(f) band:0 for wlan0
[ 1156.504195] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1160.365189] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1160.365204] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1180.405548] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1188.420402] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1188.420418] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1190.424269] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1190.424283] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1192.428136] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1192.428146] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1194.432687] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1194.432701] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1208.461920] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1224.493055] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1240.525062] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1258.560394] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1258.560407] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1260.564217] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1260.564232] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1272.153756] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1272.153769] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1272.156875] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1273.959721] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1274.594444] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1274.627065] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1276.451330] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1276.486561] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1276.489067] RTL871X: survey done event(4) band:0 for wlan0
[ 1276.489082] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1276.596161] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1276.596175] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1280.604910] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1296.637050] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1306.656037] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1306.656051] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1308.659836] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1308.659850] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1312.668196] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1312.668210] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1314.672772] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1314.672786] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1316.676202] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1316.676215] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1320.684125] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1320.684139] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1322.688646] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1322.688659] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1324.694137] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1324.694151] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1338.720520] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1362.771426] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1378.802440] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1392.154511] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1392.154524] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1392.159738] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1393.570862] RTL871X: Drop duplicate management frame with seq_num = 3656.
[ 1393.574858] RTL871X: Drop duplicate management frame with seq_num = 3656.
[ 1393.579074] RTL871X: Drop duplicate management frame with seq_num = 3656.
[ 1393.923706] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1394.850829] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1394.882939] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1394.887710] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1396.345318] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1396.378827] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1396.381204] RTL871X: survey done event(9) band:0 for wlan0
[ 1396.381226] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1396.836430] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1396.836443] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1410.865628] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1424.893347] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1424.893361] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1426.897257] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1426.897271] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1428.902161] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1428.902174] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1430.906121] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1430.906135] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1444.932552] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1444.932566] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1448.939832] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1448.939846] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1452.948071] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1452.948083] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1454.952351] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1454.952364] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1456.956155] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1456.956168] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1462.969056] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1462.969075] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1464.973045] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1464.973058] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1466.976963] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1466.976977] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1481.005506] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1497.037405] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1512.154653] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1512.154667] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1512.159100] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1513.300985] RTL871X: Drop duplicate management frame with seq_num = 1243.
[ 1513.908580] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1515.096204] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1515.128826] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1516.354953] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1516.388450] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1516.390701] RTL871X: survey done event(a) band:0 for wlan0
[ 1516.390722] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1517.076960] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1517.076973] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1527.098320] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1543.129338] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1573.189399] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1589.221586] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1605.253828] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1621.285504] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1632.154229] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1632.154242] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1632.158519] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1633.888201] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1635.328578] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1635.361200] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1636.324955] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1636.358702] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1636.361322] RTL871X: survey done event(b) band:0 for wlan0
[ 1636.361344] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1637.317791] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1637.319516] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1637.319611] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1681.405505] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1697.437540] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1713.469849] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1729.501175] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1745.535716] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1752.154323] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1752.154336] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1752.158672] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1753.920204] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1755.558706] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1755.591327] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1756.388577] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1756.422077] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1756.424200] RTL871X: survey done event(5) band:0 for wlan0
[ 1756.424220] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1757.556405] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1757.556419] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1777.597535] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1793.629520] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1831.705913] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1863.769843] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1872.153649] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1872.153662] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1872.158504] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1873.565111] RTL871X: Drop duplicate management frame with seq_num = 1083.
[ 1873.568982] RTL871X: Drop duplicate management frame with seq_num = 1083.
[ 1873.916577] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1875.796956] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1875.828955] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1875.838575] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1876.378830] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1876.412702] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1876.414700] RTL871X: survey done event(b) band:0 for wlan0
[ 1876.414721] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1877.797027] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1877.797041] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1891.826629] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1907.857757] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1923.890618] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1939.922597] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1980.003350] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1992.152615] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1992.152628] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1992.158672] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1993.167360] RTL871X: Drop duplicate management frame with seq_num = 2379.
[ 1993.916952] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1994.032829] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1994.065826] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1996.047831] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1996.079830] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1996.087076] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1996.405701] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1996.439202] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1996.441701] RTL871X: survey done event(a) band:0 for wlan0
[ 1996.441720] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1998.037322] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1998.037336] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2012.066243] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2028.097511] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2044.129804] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2084.209406] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2104.249660] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2112.153724] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2112.153738] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2112.162557] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2113.170862] RTL871X: Drop duplicate management frame with seq_num = 3734.
[ 2113.307735] RTL871X: Drop duplicate management frame with seq_num = 3737.
[ 2113.918076] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2114.275204] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2114.308076] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2116.286703] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2116.318456] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2116.325699] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2116.388201] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2116.421701] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2116.424204] RTL871X: survey done event(a) band:0 for wlan0
[ 2116.424224] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2118.277053] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2118.277068] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2132.305533] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2148.337504] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2180.401411] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2196.434982] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2212.466309] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2228.497516] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2232.153934] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2232.153948] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2232.160381] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2233.156487] RTL871X: Drop duplicate management frame with seq_num = 930.
[ 2233.160593] RTL871X: Drop duplicate management frame with seq_num = 930.
[ 2233.883581] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2234.511453] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2234.544826] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2236.359329] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2236.392827] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2236.394951] RTL871X: survey done event(9) band:0 for wlan0
[ 2236.394971] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2236.512210] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2236.512223] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2244.528894] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2260.560869] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2284.609070] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2300.640683] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 2300.640696] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2302.644655] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2302.644670] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2326.693402] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2342.724698] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2352.153903] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2352.153917] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2352.157081] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2353.276485] RTL871X: Drop duplicate management frame with seq_num = 2273.
[ 2353.282085] RTL871X: Drop duplicate management frame with seq_num = 2273.
[ 2353.285877] RTL871X: Drop duplicate management frame with seq_num = 2273.
[ 2353.290082] RTL871X: Drop duplicate management frame with seq_num = 2273.
[ 2353.887703] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2354.752205] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2354.785576] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2356.348327] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2356.381827] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2356.384078] RTL871X: survey done event(8) band:0 for wlan0
[ 2356.384099] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2356.752369] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2356.752383] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2358.756947] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2386.813663] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2402.845936] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2418.877752] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2434.909233] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2450.941822] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2466.973587] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2472.153623] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2472.153636] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2472.156981] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2473.223988] RTL871X: Drop duplicate management frame with seq_num = 3576.
[ 2473.228459] RTL871X: Drop duplicate management frame with seq_num = 3576.
[ 2473.973076] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2474.993076] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2475.025953] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2476.464328] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2476.497826] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2476.500079] RTL871X: survey done event(8) band:0 for wlan0
[ 2476.500099] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2476.993169] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2476.993183] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2485.009383] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2501.043411] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2517.073507] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2533.107714] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2549.138624] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2565.170394] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2592.154262] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2592.154276] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2592.159622] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2593.952010] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2595.230833] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2595.263594] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2596.446330] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2596.479830] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2596.482200] RTL871X: survey done event(8) band:0 for wlan0
[ 2596.482220] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2597.232940] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2597.232954] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2601.241739] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2617.274306] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2633.307713] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2649.339345] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2657.351974] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 2657.351986] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2665.368573] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2665.368587] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2667.372538] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 2667.372552] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2669.378117] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2669.378131] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2699.438979] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2712.153402] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2712.153415] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2712.158395] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2713.912206] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2715.486955] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2715.517078] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2715.523951] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2716.357327] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2716.390827] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2716.393202] RTL871X: survey done event(4) band:0 for wlan0
[ 2716.393223] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2717.473327] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2717.473341] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2731.501505] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2743.992315] RTL871X: recv eapol packet
[ 2743.992638] RTL871X: ~~~~set sta key:groupkey
[ 2743.992649] RTL871X: ==> rtw_set_key algorithm(4),keyid(1),key_mask(0)
[ 2743.992710] RTL871X: send eapol packet
[ 2743.996469] RTL871X: set group key camid:6, addr:08:60:6e:be:f2:60, kid:1, type:AES
[ 2743.997327] RTL871X: SetHwReg8812A, 5703, RCR= f40760ce
[ 2744.014370] RTL871X: recv eapol packet
[ 2744.014728] RTL871X: send eapol packet
[ 2761.561137] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2777.593508] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2795.629998] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2811.661433] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2827.693596] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2832.154659] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2832.154672] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2832.157837] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2833.894579] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2835.710827] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2835.742708] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2835.751704] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2836.294706] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2836.328954] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2836.331078] RTL871X: survey done event(4) band:0 for wlan0
[ 2836.331099] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2837.712683] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2837.712698] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2851.741120] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2867.773053] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2885.808265] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 2885.808278] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2889.816767] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2889.816781] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2903.844946] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2919.876333] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2935.909478] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2951.941089] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2952.153976] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2952.153989] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2952.156017] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2953.880328] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2953.948452] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2953.981076] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2955.950453] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2955.982079] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2955.989327] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2956.298702] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2956.332203] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2956.335199] RTL871X: survey done event(4) band:0 for wlan0
[ 2956.335219] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2957.952648] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2957.952662] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2967.998160] RTL871X: issue_probereq_ex(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 24 ms
[ 2967.998333] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2968.028471] RTL871X: issue_nulldata(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 32 ms
[ 2970.007003] RTL871X: issue_probereq_ex(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 28 ms
[ 2970.007274] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2970.039034] RTL871X: issue_nulldata(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 32 ms
[ 2972.006993] RTL871X: issue_probereq_ex(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 24 ms
[ 2972.007300] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2972.041085] RTL871X: issue_nulldata(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 36 ms
[ 2974.011202] RTL871X: issue_probereq_ex(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 24 ms
[ 2974.011444] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2974.041448] RTL871X: issue_nulldata(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 32 ms
[ 2976.014955] RTL871X: issue_probereq_ex(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 24 ms
[ 2976.015200] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2976.048848] RTL871X: issue_nulldata(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 36 ms
[ 2976.048858] RTL871X: linked_status_chk(wlan0) disconnect or roaming
[ 2976.048865] RTL871X: receive_disconnect
[ 2976.048879] RTL871X: report_del_sta_event: delete STA, mac_id=0
[ 2976.053715] RTL871X: rtw_stadel_event_callback(mac_id=0)=08:60:6e:be:f2:60
[ 2976.053724] RTL871X: [MacId], Set MacId Ctrl(original) = 0x0
[ 2976.054824] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2976.056994] RTL871X: ### Clean STA_(0) info ###
[ 2976.057004] RTL871X: free disconnecting network
[ 2976.057028] RTL871X: roaming from Shadownetwork 2.4Ghz(08:60:6e:be:f2:60), length:20
[ 2976.057051] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_DISCONNECT
[ 2976.057060] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2976.058574] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(0)
[ 2976.058587] RTL871X: beamforming_deinit_entry Idx 0
[ 2976.058594] RTL871X: beamforming_notify BeamformState 0 bSounding 0
[ 2977.730574] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2980.184829] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2980.219083] RTL871X: survey done event(0) band:0 for wlan0
[ 2980.219103] RTL871X: rtw_select_and_join_from_scanned_queue: return _FAIL(candidate == NULL)
[ 2980.219111] RTL871X: try_to_join, but select scanning queue fail, to_roam:2
[ 2980.219127] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2981.929079] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2984.359330] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2984.393578] RTL871X: survey done event(1) band:0 for wlan0
[ 2984.393598] RTL871X: rtw_select_and_join_from_scanned_queue: return _FAIL(candidate == NULL)
[ 2984.393606] RTL871X: try_to_join, but select scanning queue fail, to_roam:1
[ 2984.393696] RTL871X: indicate disassoc
[ 2984.393766] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2984.393797] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(0)
[ 2984.393809] RTL871X: beamforming_deinit_entry Idx 0
[ 2984.393817] RTL871X: beamforming_notify BeamformState 0 bSounding 0
[ 2984.399574] RTL871X: ==>rtw_ps_processor .fw_state(8)
[ 2984.399581] RTL871X: ==>ips_enter cnts:2
[ 2984.399586] RTL871X: nolinked power save enter
[ 2984.399591] RTL871X: ===> rtw_ips_pwr_down...................
[ 2984.399597] RTL871X: ====> rtw_ips_dev_unload...
[ 2984.410368] RTL871X: usb_read_port_cancel
[ 2984.410452] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.410571] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.410695] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.410821] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.410944] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.411070] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.411196] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.411321] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.411340] RTL871X: usb_write_port_cancel
[ 2984.411371] RTL871X: ==> rtl8812au_hal_deinit
[ 2984.412696] RTL871X: hal_poweroff_8812au
[ 2984.417317] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 2984.423571] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=0
[ 2984.423820] RTL871X: <=== rtw_ips_pwr_down..................... in 24ms
[ 2985.227240] RTL871X: _rtw_pwr_wakeup call ips_leave....
[ 2985.227251] RTL871X: ==>ips_leave cnts:2
[ 2985.227257] RTL871X: ===> rtw_ips_pwr_up..............
[ 2985.227269] RTL871X: ===> ips_netdrv_open.........
[ 2985.227835] RTL871X: power-on :REG_SYS_CLKR 0x09=0xb0. REG_CR 0x100=0xea.
[ 2985.227842] RTL871X: MAC has not been powered on yet.
[ 2985.234450] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=1
[ 2985.300450] RTL871X: FirmwareDownload8812 fw source from Header
[ 2985.300461] RTL871X: FirmwareDownload8812 fw:NIC, size: 31936
[ 2985.300469] RTL871X: FirmwareDownload8812: fw_ver=38 fw_subver=0 sig=0x9501
[ 2985.344076] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00070705
[ 2985.345944] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 2985.373950] RTL871X: _FWFreeToGo8812: Polling FW ready OK! (220, 28ms), REG_MCUFWDL:0x000707c6
[ 2985.373958] RTL871X: FWDL success. write_fw:1, 72ms
[ 2985.373966] RTL871X: rtl8812au_hal_init: Download Firmware Success!!
[ 2985.399200] RTL871X: ===> phy_BB8812_Config_ParaFile() EEPROMRegulatory 1
[ 2985.720953] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2986.438456] RTL871X: pDM_Odm TxPowerTrackControl = 1
[ 2986.440581] RTL871X: MAC Address from REG_MACID = 9c:5c:8e:b2:b5:a9
[ 2986.440592] RTL871X: rtl8812au_hal_init in 1216ms
[ 2986.474815] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 2986.475336] RTL871X: <=== rtw_ips_pwr_up.............. in 1248ms
[ 2986.475341] RTL871X: nolinked power save leave
[ 2986.475438] RTL871X: ==> ips_leave.....LED(0x00028220)...
[ 2988.172946] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2990.584829] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2990.619818] RTL871X: survey done event(0) band:0 for wlan0
[ 2990.619834] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2990.627444] RTL871X: ==>rtw_ps_processor .fw_state(8)
[ 2990.627450] RTL871X: ==>ips_enter cnts:3
[ 2990.627453] RTL871X: nolinked power save enter
[ 2990.627456] RTL871X: ===> rtw_ips_pwr_down...................
[ 2990.627460] RTL871X: ====> rtw_ips_dev_unload...
[ 2990.638764] RTL871X: usb_read_port_cancel
[ 2990.638950] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.639065] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.639187] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.639315] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.639443] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.639796] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.639969] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.640199] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.640215] RTL871X: usb_write_port_cancel
[ 2990.640238] RTL871X: ==> rtl8812au_hal_deinit
[ 2990.641432] RTL871X: hal_poweroff_8812au
[ 2990.645816] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 2990.652446] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=0
[ 2990.652690] RTL871X: <=== rtw_ips_pwr_down..................... in 28ms
[ 2995.622678] RTL871X: _rtw_pwr_wakeup call ips_leave....
[ 2995.622688] RTL871X: ==>ips_leave cnts:3
[ 2995.622694] RTL871X: ===> rtw_ips_pwr_up..............
[ 2995.622705] RTL871X: ===> ips_netdrv_open.........
[ 2995.622979] RTL871X: power-on :REG_SYS_CLKR 0x09=0xb0. REG_CR 0x100=0xea.
[ 2995.622986] RTL871X: MAC has not been powered on yet.
[ 2995.628828] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=1
[ 2995.696577] RTL871X: FirmwareDownload8812 fw source from Header
[ 2995.696589] RTL871X: FirmwareDownload8812 fw:NIC, size: 31936
[ 2995.696597] RTL871X: FirmwareDownload8812: fw_ver=38 fw_subver=0 sig=0x9501
[ 2995.743329] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00070705
[ 2995.745195] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 2995.773201] RTL871X: _FWFreeToGo8812: Polling FW ready OK! (224, 28ms), REG_MCUFWDL:0x000707c6
[ 2995.773211] RTL871X: FWDL success. write_fw:1, 76ms
[ 2995.773219] RTL871X: rtl8812au_hal_init: Download Firmware Success!!
[ 2995.798197] RTL871X: ===> phy_BB8812_Config_ParaFile() EEPROMRegulatory 1
[ 2996.120329] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2996.839814] RTL871X: pDM_Odm TxPowerTrackControl = 1
[ 2996.841812] RTL871X: MAC Address from REG_MACID = 9c:5c:8e:b2:b5:a9
[ 2996.841818] RTL871X: rtl8812au_hal_init in 1220ms
[ 2996.875202] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 2996.875738] RTL871X: <=== rtw_ips_pwr_up.............. in 1256ms
[ 2996.875746] RTL871X: nolinked power save leave
[ 2996.875951] RTL871X: ==> ips_leave.....LED(0x00028220)...
[ 2996.875961] RTL871X: IW_SCAN_THIS_ESSID, ssid=Shadownetwork 2.4Ghz, len=20
[ 2998.556451] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3001.005204] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3001.040079] RTL871X: survey done event(1) band:0 for wlan0
[ 3001.040103] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3001.040934] RTL871X: wpa_set_auth_algs, AUTH_ALG_OPEN_SYSTEM
[ 3001.040948] RTL871X: set_mode = IW_MODE_INFRA
[ 3001.040988] RTL871X:
[ 3001.040991] wpa_ie(length:22):
[ 3001.040999] RTL871X: 0x30 0x14 0x01 0x00 0x00 0x0f 0xac 0x04
[ 3001.041006] RTL871X: 0x01 0x00 0x00 0x0f 0xac 0x04 0x01 0x00
[ 3001.041014] RTL871X: 0x00 0x0f 0xac 0x02 0x00 0x00 0x00 0x00
[ 3001.041702] RTL871X: SetHwReg8812A, 5710, RCR= f40060ca
[ 3001.041828] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 3001.041838] RTL871X: rtw_wx_set_freq: set to channel 10
[ 3001.041868] RTL871X: =>rtw_wx_set_essid
[ 3001.041874] RTL871X: ssid=Shadownetwork 2.4Ghz, len=20
[ 3001.041887] RTL871X: set ssid [Shadownetwork 2.4Ghz] fw_state=0x00000008
[ 3001.041893] RTL871X: Set SSID under fw_state=0x00000008
[ 3001.041906] RTL871X: [by_bssid:0][assoc_ssid:Shadownetwork 2.4Ghz][to_roam:0] new candidate: Shadownetwork 2.4Ghz(08:60:6e:be:f2:60, ch10) rssi:-58
[ 3001.041917] RTL871X: rtw_select_and_join_from_scanned_queue: candidate: Shadownetwork 2.4Ghz(08:60:6e:be:f2:60, ch:10)
[ 3001.041930] RTL871X: link to Broadcom AP
[ 3001.041940] RTL871X: [HT] HAL Support STBC = 0x01
[ 3001.041947] RTL871X: [HT] Declare supporting RX STBC_2R
[ 3001.041955] RTL871X: [VHT] Support STBC = 0x03
[ 3001.041960] RTL871X: [VHT] Support Beamformee
[ 3001.041971] RTL871X: <=rtw_wx_set_essid, ret 0
[ 3001.041998] RTL871X: set bssid:08:60:6e:be:f2:60
[ 3001.042005] RTL871X: Set BSSID under fw_state=0x00000088
[ 3001.042462] RTL871X: start_join_set_ch_bw: ch=10, bwmode=0, ch_offset=0
[ 3001.111492] RTL871X: OnBeacon: beacon keys ready
[ 3001.111505] RTL871X: link to Broadcom AP
[ 3001.111513] RTL871X: start auth
[ 3001.111537] RTL871X: issue_auth
[ 3001.114855] RTL871X: OnAuthClient
[ 3001.114863] RTL871X: auth success, start assoc
[ 3001.114878] RTL871X: network.SupportedRates[0]=82
[ 3001.114884] RTL871X: network.SupportedRates[1]=84
[ 3001.114889] RTL871X: network.SupportedRates[2]=8B
[ 3001.114894] RTL871X: network.SupportedRates[3]=96
[ 3001.114900] RTL871X: network.SupportedRates[4]=24
[ 3001.114905] RTL871X: network.SupportedRates[5]=30
[ 3001.114910] RTL871X: network.SupportedRates[6]=48
[ 3001.114916] RTL871X: network.SupportedRates[7]=6C
[ 3001.114921] RTL871X: network.SupportedRates[8]=0C
[ 3001.114926] RTL871X: network.SupportedRates[9]=12
[ 3001.114932] RTL871X: network.SupportedRates[10]=18
[ 3001.114937] RTL871X: network.SupportedRates[11]=60
[ 3001.114943] RTL871X: bssrate_len = 12
[ 3001.119682] RTL871X: OnAssocRsp
[ 3001.119701] RTL871X: report_join_res(8)
[ 3001.119710] RTL871X: rtw_joinbss_update_network
[ 3001.119718] RTL871X: +rtw_update_ht_cap()
[ 3001.119735] RTL871X: rtw_alloc_macid(wlan0) if1, hwaddr:08:60:6e:be:f2:60 macid:0
[ 3001.119742] RTL871X: rtw_joinbss_update_stainfo
[ 3001.119777] RTL871X: supp_mcs_set = ff, ff, 00, rf_type=2, tx_ra_bitmap=000000000fffffff
[ 3001.119784] RTL871X: ### Set STA_(0) info ###
[ 3001.119794] RTL871X: assoc success
[ 3001.119870] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3001.120945] RTL871X: WMM(0): 0, a42b
[ 3001.121067] RTL871X: WMM(1): 0, a44f
[ 3001.121247] RTL871X: WMM(2): 0, 5e4322
[ 3001.121662] RTL871X: WMM(3): 0, 2f3222
[ 3001.121670] RTL871X: wmm_para_seq(0): 0
[ 3001.121675] RTL871X: wmm_para_seq(1): 1
[ 3001.121681] RTL871X: wmm_para_seq(2): 2
[ 3001.121686] RTL871X: wmm_para_seq(3): 3
[ 3001.121692] RTL871X: HTOnAssocRsp
[ 3001.121826] RTL871X: VHTOnAssocRsp
[ 3001.121843] RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x00, WirelessMode:0x0b, rate_bitmap:0x0f8ff005
[ 3001.121853] RTL871X: UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x0fffffff
[ 3001.121856] ==> rssi_level:0, rate_bitmap:0x0f8ff005, psta->raid=2
[ 3001.122945] RTL871X: [MacId], Set MacId Ctrl(original) = 0x10000
[ 3001.124806] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3001.126316] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(1)
[ 3001.127828] RTL871X: rtw_hal_set_fw_rsvd_page PageSize: 512, RsvdPageNUm: 7
[ 3001.127840] RTL871X: LocPsPoll: 2
[ 3001.127846] RTL871X: LocNullData: 3
[ 3001.127852] RTL871X: LocQosNull: 4
[ 3001.128072] RTL871X: rtw_hal_set_fw_rsvd_page: Set RSVD page location to Fw ,TotalPacketLen(2634), TotalPageNum(5)
[ 3001.128081] RTL871X: RsvdPageLoc: ProbeRsp=0 PsPoll=2 Null=3 QoSNull=4 BTNull=0
[ 3001.129073] RTL871X: wlan0: 1 DL RSVD page success! DLBcnCount:1, poll:1
[ 3001.129504] RTL871X: OnAction_back
[ 3001.129514] RTL871X: OnAction_back, action=0
[ 3001.129537] RTL871X: issue_addba_rsp(wlan0) ra=08:60:6e:be:f2:60 status=0, tid=0, size=64
[ 3001.129817] RTL871X: Set RSVD page location to Fw.
[ 3001.129945] RTL871X: =>mlmeext_joinbss_event_callback
[ 3001.131484] RTL871X: recv eapol packet
[ 3001.133943] RTL871X: send eapol packet
[ 3001.150901] RTL871X: recv eapol packet
[ 3001.151116] RTL871X: send eapol packet
[ 3001.151177] RTL871X: ~~~~set sta key:unicastkey
[ 3001.151333] RTL871X: ~~~~set sta key:groupkey
[ 3001.151343] RTL871X: ==> rtw_set_key algorithm(4),keyid(1),key_mask(0)
[ 3001.151565] RTL871X: set pairwise key camid:4, addr:08:60:6e:be:f2:60, kid:0, type:AES
[ 3001.154829] RTL871X: set group key camid:5, addr:08:60:6e:be:f2:60, kid:1, type:AES
[ 3001.155198] RTL871X: SetHwReg8812A, 5703, RCR= f40060ce
[ 3003.056074] RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x02, WirelessMode:0x0b, rate_bitmap:0x0f8ff000
[ 3003.056083] RTL871X: UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x0fffffff
[ 3003.056085] ==> rssi_level:2, rate_bitmap:0x0f8ff000, psta->raid=2
[ 3011.559563] wlan0: no IPv6 routers present
[ 3021.084628] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3021.084648] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3051.145218] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3072.153809] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3072.153823] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3072.158423] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3074.020453] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3075.204079] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3075.237074] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3076.447828] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3076.482942] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3076.486940] RTL871X: survey done event(5) band:0 for wlan0
[ 3076.486954] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3077.198111] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3077.198126] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3083.209450] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3097.240017] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3112.158446] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3112.158460] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3112.164162] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3113.911065] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3115.274829] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3115.333333] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3115.342827] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3116.400830] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3116.434325] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3116.436451] RTL871X: survey done event(0) band:0 for wlan0
[ 3116.436472] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3117.277291] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3117.277305] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3131.304067] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3131.304076] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3135.312954] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3135.312969] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3137.316736] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3137.316749] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3141.324020] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3141.324034] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3155.352992] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3171.385128] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3172.157406] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3172.157420] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3172.162246] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3173.896711] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3175.399079] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3175.431831] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3176.360579] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3176.394078] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3176.396579] RTL871X: survey done event(3) band:0 for wlan0
[ 3176.396600] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3177.396980] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3177.396994] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3229.502470] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3252.154370] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3252.154384] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3252.159394] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3253.917076] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3255.557828] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3255.589334] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3255.596575] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3256.399453] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3256.432951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3256.435451] RTL871X: survey done event(5) band:0 for wlan0
[ 3256.435510] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3257.557751] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3257.557765] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3275.593149] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3291.633548] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3295.635334] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3313.669692] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3323.687822] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3323.687831] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3325.691960] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3325.691974] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3341.724204] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3341.724215] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3343.728069] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3343.728083] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3347.736662] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3347.736676] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3349.739825] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3349.739835] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3352.158706] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3352.158720] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3352.164780] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3353.945827] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3355.764078] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3355.796700] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3356.372704] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3356.406200] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3356.408578] RTL871X: survey done event(4) band:0 for wlan0
[ 3356.408598] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3357.756014] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3357.756028] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3363.769397] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3367.777330] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3367.777343] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3373.788355] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3373.788369] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3375.792024] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3375.792037] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3379.800337] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3379.800350] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3393.828913] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3409.865011] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3441.947961] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3447.947831] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3447.978398] RTL871X: issue_nulldata(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 32 ms
[ 3449.945704] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3472.157962] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3472.157975] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3472.159635] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3473.878453] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3473.994568] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3474.025328] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3474.030199] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3475.998587] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3476.030081] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3476.037454] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3476.318201] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3476.354201] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3476.356454] RTL871X: survey done event(7) band:0 for wlan0
[ 3476.356477] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3477.999831] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3477.999845] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3506.055951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3538.119952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3568.179953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3584.211953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3592.155371] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3592.155385] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3592.157207] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3593.146989] RTL871X: Drop duplicate management frame with seq_num = 3850.
[ 3593.874452] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3594.234582] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3594.267698] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3596.238589] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3596.270952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3596.278455] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3596.311200] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3596.344954] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3596.347200] RTL871X: survey done event(9) band:0 for wlan0
[ 3596.347223] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3598.239830] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3598.239845] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3646.335832] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3646.335846] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3650.343835] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3650.343848] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3712.153042] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3712.153056] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3712.155084] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3713.151266] RTL871X: Drop duplicate management frame with seq_num = 1072.
[ 3713.155881] RTL871X: Drop duplicate management frame with seq_num = 1072.
[ 3713.874451] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3714.474473] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3714.507604] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3716.274326] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3716.308198] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3716.310951] RTL871X: survey done event(6) band:0 for wlan0
[ 3716.310972] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3716.475954] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3716.475968] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3724.491954] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3750.543952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3766.575951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3782.607951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3798.639951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3814.671964] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3832.157401] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3832.157415] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3832.159208] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3833.922588] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3834.714463] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3834.748075] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3836.286201] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3836.320084] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3836.322699] RTL871X: survey done event(7) band:0 for wlan0
[ 3836.322722] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3836.715957] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3836.715971] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3846.735950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3862.767952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3878.799950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3894.831951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3910.864201] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3926.896074] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3952.153978] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3952.153991] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3952.155837] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3952.977326] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3953.906454] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3954.954459] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3954.987576] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3956.278201] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3956.311825] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3956.313946] RTL871X: survey done event(7) band:0 for wlan0
[ 3956.313968] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3956.955956] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3956.955970] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3968.979950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3985.011954] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4001.044327] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4017.076078] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4053.147952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4069.179939] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4072.156382] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4072.156397] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4072.158340] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4073.890436] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4075.194447] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4075.228708] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4076.270445] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4076.308212] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4076.310460] RTL871X: survey done event(4) band:0 for wlan0
[ 4076.310486] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4077.195835] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4077.195848] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4085.211940] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4101.243944] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4117.275937] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4133.307940] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4155.351950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4171.383935] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4187.415957] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4192.157266] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4192.157280] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4192.159064] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4193.537898] RTL871X: Drop duplicate management frame with seq_num = 2276.
[ 4193.542140] RTL871X: Drop duplicate management frame with seq_num = 2276.
[ 4193.546147] RTL871X: Drop duplicate management frame with seq_num = 2276.
[ 4193.882939] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4195.434439] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4195.467945] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4196.258199] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4196.292460] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4196.294952] RTL871X: survey done event(6) band:0 for wlan0
[ 4196.294973] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4197.436077] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4197.436091] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4203.447937] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4209.459815] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 4209.459824] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4211.463833] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4211.463842] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4231.503952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4271.583941] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4287.615937] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4303.647957] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4312.156255] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4312.156269] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4312.157938] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4313.280243] RTL871X: Drop duplicate management frame with seq_num = 3554.
[ 4313.886705] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4315.674559] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4315.707948] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4316.266189] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4316.300824] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4316.303449] RTL871X: survey done event(7) band:0 for wlan0
[ 4316.303477] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4317.675819] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4317.675829] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4319.679944] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4335.711945] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4367.776077] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4383.807940] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4399.839942] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4415.871948] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4431.903940] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4432.156354] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4432.156371] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4432.158711] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4433.274745] RTL871X: Drop duplicate management frame with seq_num = 748.
[ 4433.878441] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4433.910438] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4433.944315] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4435.918696] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4435.952579] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4435.959815] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4436.270324] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4436.306069] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4436.308313] RTL871X: survey done event(9) band:0 for wlan0
[ 4436.308329] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4437.915957] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4437.915972] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4465.972065] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4482.003941] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4498.035943] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4514.067945] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4530.099948] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4552.153077] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4552.153090] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4552.154941] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4553.526748] RTL871X: Drop duplicate management frame with seq_num = 2034.
[ 4553.530621] RTL871X: Drop duplicate management frame with seq_num = 2034.
[ 4553.874689] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4554.153455] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4554.188701] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4556.162066] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4556.194566] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4556.201824] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4556.258691] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4556.293687] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4556.299943] RTL871X: survey done event(7) band:0 for wlan0
[ 4556.299959] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4558.155817] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4558.155826] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4572.183953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4588.215936] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4604.247951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4620.280069] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4636.311943] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4662.364077] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4672.156223] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4672.156236] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4672.157957] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4673.278737] RTL871X: Drop duplicate management frame with seq_num = 3333.
[ 4673.282934] RTL871X: Drop duplicate management frame with seq_num = 3333.
[ 4673.535969] RTL871X: Drop duplicate management frame with seq_num = 3339.
[ 4673.878582] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4674.413453] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4674.447960] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4676.274205] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4676.308202] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4676.310496] RTL871X: survey done event(9) band:0 for wlan0
[ 4676.310548] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4676.391836] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4676.391849] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4678.395953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4694.427942] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4710.459953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4726.492076] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4742.523951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4760.559952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4776.591950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4792.153142] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4792.153155] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4792.154818] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4792.652811] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4793.279102] RTL871X: Drop duplicate management frame with seq_num = 517.
[ 4793.878702] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4794.630830] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4794.664702] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4796.322339] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4796.357705] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4796.359835] RTL871X: survey done event(6) band:0 for wlan0
[ 4796.359860] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4796.631817] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4796.631826] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4808.656208] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4824.687944] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4856.751951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4872.783949] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4888.816072] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4904.847951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4912.156323] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4912.156339] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4912.157941] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4913.278117] RTL871X: Drop duplicate management frame with seq_num = 1778.
[ 4913.282372] RTL871X: Drop duplicate management frame with seq_num = 1778.
[ 4913.286489] RTL871X: Drop duplicate management frame with seq_num = 1778.
[ 4913.531267] RTL871X: Drop duplicate management frame with seq_num = 1783.
[ 4913.535422] RTL871X: Drop duplicate management frame with seq_num = 1783.
[ 4913.539511] RTL871X: Drop duplicate management frame with seq_num = 1783.
[ 4913.543383] RTL871X: Drop duplicate management frame with seq_num = 1783.
[ 4913.878588] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4914.870568] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4914.903310] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4916.318200] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4916.355086] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4916.357838] RTL871X: survey done event(9) band:0 for wlan0
[ 4916.357864] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4916.871834] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4916.871849] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4920.880071] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4936.912261] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4954.947954] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4970.979950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4987.011952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5003.043958] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5019.075953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5032.152809] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5032.152822] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5032.154458] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5033.338653] RTL871X: Drop duplicate management frame with seq_num = 3084.
[ 5033.342523] RTL871X: Drop duplicate management frame with seq_num = 3084.
[ 5033.594862] RTL871X: Drop duplicate management frame with seq_num = 3089.
[ 5033.598656] RTL871X: Drop duplicate management frame with seq_num = 3089.
[ 5033.602763] RTL871X: Drop duplicate management frame with seq_num = 3089.
[ 5033.938576] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5035.110455] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5035.140813] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5035.145323] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5036.326208] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5036.361448] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5036.364950] RTL871X: survey done event(7) band:0 for wlan0
[ 5036.365031] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5037.111835] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5037.111848] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5049.135829] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 5049.135842] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5053.143820] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5053.143829] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5055.147831] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 5055.147844] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5057.151832] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5057.151846] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5071.180363] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5087.211948] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5103.244076] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5129.295936] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5152.157821] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5152.157834] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5152.159470] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5153.922456] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5155.350451] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5155.383575] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5156.314199] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5156.349444] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5156.351813] RTL871X: survey done event(6) band:0 for wlan0
[ 5156.351828] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5157.351996] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5157.352011] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5163.364105] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5179.395950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5195.427936] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5211.459938] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5227.491940] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5243.523942] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5271.579951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5272.153635] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5272.153648] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5272.155331] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5273.902457] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5275.590584] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5275.623463] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5275.630700] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5276.282201] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5276.315825] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5276.318696] RTL871X: survey done event(6) band:0 for wlan0
[ 5276.318719] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5277.591832] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5277.591846] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5291.619952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5307.651951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5323.683951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5339.715952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5359.756084] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5375.787952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5391.819953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5392.157995] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5392.158008] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5392.159709] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5393.149735] RTL871X: Drop duplicate management frame with seq_num = 3251.
[ 5393.153613] RTL871X: Drop duplicate management frame with seq_num = 3251.
[ 5393.886580] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5395.830451] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5395.861953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5395.869200] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5396.274200] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5396.307703] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5396.309821] RTL871X: survey done event(9) band:0 for wlan0
[ 5396.309842] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5397.831832] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5397.831845] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5425.887950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5461.959950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5490.015951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5506.047955] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5512.157093] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5512.157107] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5512.159209] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5513.534383] RTL871X: Drop duplicate management frame with seq_num = 534.
[ 5513.878463] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5514.066458] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5514.100072] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5516.070458] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5516.105456] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5516.112820] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5516.270199] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5516.304325] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5516.307702] RTL871X: survey done event(9) band:0 for wlan0
[ 5516.307725] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5518.071832] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5518.071845] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5532.099949] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5558.151952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5574.183950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5590.215951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5606.247951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5622.279950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5632.157372] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5632.157386] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5632.159082] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5633.894458] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5634.306471] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5634.339076] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5636.262200] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5636.296328] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5636.298824] RTL871X: survey done event(8) band:0 for wlan0
[ 5636.298844] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5636.307828] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5636.307841] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5638.311948] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5656.347952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5672.379950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5688.411951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5704.443952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5720.475950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5736.507951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5752.157864] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5752.157877] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5752.159594] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5753.281759] RTL871X: Drop duplicate management frame with seq_num = 3239.
[ 5753.285760] RTL871X: Drop duplicate management frame with seq_num = 3239.
[ 5753.882457] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5754.546460] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5754.580700] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5756.246201] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5756.280078] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5756.282578] RTL871X: survey done event(8) band:0 for wlan0
[ 5756.282599] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5756.547832] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5756.547845] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5766.567951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5782.599949] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5798.631940] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5814.663951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5830.695955] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5846.727958] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5864.763942] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5872.154807] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5872.154820] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5872.156571] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5873.530744] RTL871X: Drop duplicate management frame with seq_num = 508.
[ 5873.534518] RTL871X: Drop duplicate management frame with seq_num = 508.
[ 5873.538498] RTL871X: Drop duplicate management frame with seq_num = 508.
[ 5873.874456] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5874.786454] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5874.823702] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5876.266326] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5876.300571] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5876.304200] RTL871X: survey done event(6) band:0 for wlan0
[ 5876.304219] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5876.787816] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5876.787826] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5880.795939] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5890.815816] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 5890.815825] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5892.819959] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5892.819969] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5912.860794] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5928.892641] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5930.896207] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 5930.896217] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5932.115699] RTL871X: rtw_issue_addbareq_cmd, p=0
[ 5932.115765] RTL871X: BA_starting_seqctrl = 809 for TID=0
[ 5932.115787] RTL871X: issue_addba_req(wlan0) ra=08:60:6e:be:f2:60 tid=0
[ 5932.144013] RTL871X: OnAction_back
[ 5932.144020] RTL871X: OnAction_back, action=1
[ 5932.144024] RTL871X: agg_enable for TID=0
[ 5938.912135] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5938.912144] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5940.916612] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 5940.916625] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5944.924604] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5944.924618] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5960.958130] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5976.989056] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5992.157772] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5992.157785] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5992.161395] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5993.056953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5993.913204] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5995.030955] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5995.063704] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5996.376453] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5996.410701] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5996.412701] RTL871X: survey done event(3) band:0 for wlan0
[ 5996.412721] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5997.028938] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5997.028952] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6009.052930] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6025.085558] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6077.189576] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6093.221722] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6109.253253] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6112.157853] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6112.157866] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6112.161673] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6113.896953] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6115.269453] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6115.302073] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6116.352078] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6116.385825] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6116.388701] RTL871X: survey done event(3) band:0 for wlan0
[ 6116.388722] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6117.268378] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6117.268388] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6125.285281] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6141.317844] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6157.348651] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6173.381320] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6189.413267] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6205.445506] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6221.477300] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6232.152555] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6232.152569] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6232.154708] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6233.882451] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6235.508204] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6235.540825] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6236.336578] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6236.371582] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6236.373948] RTL871X: survey done event(5) band:0 for wlan0
[ 6236.373970] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6237.508140] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6237.509683] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6237.509695] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6253.541237] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6260.127877] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_SPECIAL_PACKET
[ 6260.127886] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6261.556794] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6261.556808] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6277.589144] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6285.604654] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6285.604668] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6287.608473] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6287.608488] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6291.617984] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6291.617998] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6293.620387] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6293.620398] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6295.624043] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6295.624056] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6299.632265] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6299.632274] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6301.636075] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6301.636088] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6309.652629] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6309.652643] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6313.661908] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6313.661922] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6317.668953] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6317.668967] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6319.673372] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6319.673386] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6321.678117] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6321.678131] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6334.873699] RTL871X: recv eapol packet
[ 6334.874086] RTL871X: ~~~~set sta key:groupkey
[ 6334.874098] RTL871X: ==> rtw_set_key algorithm(4),keyid(2),key_mask(0)
[ 6334.874161] RTL871X: send eapol packet
[ 6334.875748] RTL871X: recv eapol packet
[ 6334.876051] RTL871X: send eapol packet
[ 6334.878078] RTL871X: set group key camid:6, addr:08:60:6e:be:f2:60, kid:2, type:AES
[ 6334.878445] RTL871X: SetHwReg8812A, 5703, RCR= f40760ce
[ 6352.157013] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6352.157026] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6352.160522] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6353.283862] RTL871X: Drop duplicate management frame with seq_num = 1657.
[ 6353.287987] RTL871X: Drop duplicate management frame with seq_num = 1657.
[ 6353.292209] RTL871X: Drop duplicate management frame with seq_num = 1657.
[ 6353.937952] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6355.761078] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6355.792831] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6355.800074] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6356.372953] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6356.406449] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6356.408952] RTL871X: survey done event(a) band:0 for wlan0
[ 6356.408972] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6357.748946] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6357.748960] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6371.777381] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6395.825424] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6411.857276] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6435.905402] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6459.954468] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6472.157475] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6472.157489] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6472.162430] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6473.918828] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6473.986328] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6474.019702] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6475.993828] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6476.025581] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6476.032826] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6476.348703] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6476.382701] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6476.384827] RTL871X: survey done event(9) band:0 for wlan0
[ 6476.384847] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6477.989061] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6477.989076] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6492.017501] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6508.049413] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6540.113548] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6556.145396] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6572.177394] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6588.209149] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6592.158379] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6592.158393] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6592.163367] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6593.909329] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6594.225451] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6594.258950] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6596.240577] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6596.273200] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6596.339322] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6596.374701] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6596.379457] RTL871X: survey done event(6) band:0 for wlan0
[ 6596.379480] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6598.228906] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6598.228920] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6604.241392] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6628.289196] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6644.321247] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6662.357383] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6678.389216] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6694.421436] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6712.157705] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6712.157719] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6712.161646] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6713.331505] RTL871X: Drop duplicate management frame with seq_num = 1719.
[ 6713.592860] RTL871X: Drop duplicate management frame with seq_num = 1724.
[ 6713.597300] RTL871X: Drop duplicate management frame with seq_num = 1724.
[ 6713.601297] RTL871X: Drop duplicate management frame with seq_num = 1724.
[ 6713.939075] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6714.479323] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6714.512200] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6716.366451] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6716.403703] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6716.405950] RTL871X: survey done event(a) band:0 for wlan0
[ 6716.406011] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6716.464702] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6716.464716] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6736.505423] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6752.537550] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6768.569445] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6784.601442] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6800.633725] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6816.665437] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6832.158550] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6832.158563] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6832.163900] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6833.186736] RTL871X: Drop duplicate management frame with seq_num = 3260.
[ 6833.191082] RTL871X: Drop duplicate management frame with seq_num = 3260.
[ 6833.578360] RTL871X: Drop duplicate management frame with seq_num = 3267.
[ 6833.582483] RTL871X: Drop duplicate management frame with seq_num = 3267.
[ 6833.932331] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6834.704955] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6834.738326] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6836.432702] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6836.466204] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6836.468577] RTL871X: survey done event(9) band:0 for wlan0
[ 6836.468597] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6836.704789] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6836.704803] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6846.725433] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6862.757784] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6878.789468] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6894.821457] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6910.853325] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6926.885153] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6952.156366] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6952.156375] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6952.162580] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6953.561485] RTL871X: Drop duplicate management frame with seq_num = 579.
[ 6953.920956] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6954.946455] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6954.979832] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6956.446954] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6956.480586] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6956.482956] RTL871X: survey done event(b) band:0 for wlan0
[ 6956.482978] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6956.944441] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6956.944451] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6962.956671] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6972.975837] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6972.975850] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6976.984267] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6976.984281] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6978.989010] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6978.989024] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6980.992766] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6980.992780] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6995.021602] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 7011.053471] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 7027.085523] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 7043.117396] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000Br Victor
- Thank you received: 4656
30 Oct 2018 14:58 #119658
Replied by andypugh on topic G76, Troubleshooting needed!
That's wierd
(don't worry about the \ characters)
I don't know what the problem is there. Before editing again, try a restart.
Unknown parameter `num_encoders=1'
waitpid failed /usr/bin/rtapi_app hm2_eth
/usr/bin/rtapi_app exited without becoming ready
insmod for hm2_eth failed, returned -1
while executing
"hal loadrt hm2_eth board_ip=\"10.10.10.10\" config=\"firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=2 sserial_port_0=00xxxx\""(don't worry about the \ characters)
The following user(s) said Thank You: Victor
- Victor
30 Oct 2018 15:13 #119659
by Victor
Replied by Victor on topic G76, Troubleshooting needed!
Ok did a restart but still same issue.
If i put # before TWOPASS=ON it starts right up, if i remove it i get the error message as above.
Br Victor
[HAL]
HALUI = halui
HALFILE = Emco-120P.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
#TWOPASS=ONBr Victor
30 Oct 2018 15:17 #119660
Does it start up and actually work with that commented out?
- Victor
30 Oct 2018 15:20 #119661
by Victor
Yup, starts right up with # before TWOPASS=ON
Have runned it like that for some time now.. i have removed the code you gave me in custom.hal so the only diffrence is the twopass line.
Br Victor
Br Victor
30 Oct 2018 15:25 #119662
Oh. I thought you were saying that it was all working, which would have been a surprise.
So, put the loadrt for both lowpasses in the main HAL, and the rest in the custom.hal. What happens then?
- Victor
30 Oct 2018 15:31 #119663
by Victor
No when i put the TWOPASS=ON it stops working.
This is what i now have in my main .HAL file:
This is what i have in my custom.hal file:
This is what i have in my .ini file:
This is the error message i get:
Br Victor
# Generated by PNCconf at Wed Jul 5 19:54:29 2017
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=2 sserial_port_0=00xxxx"
setp hm2_7i76e.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.z,pid.s
loadrt abs names=abs.spindle
loadrt lowpass names=lowpass.spindle
loadrt lowpass names=lowpass.0
loadrt scale names=scale.spindle
addf hm2_7i76e.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf scale.spindle servo-thread
addf abs.spindle servo-thread
addf lowpass.spindle servo-thread
addf hm2_7i76e.0.write servo-thread
setp hm2_7i76e.0.dpll.01.timer-us -50
setp hm2_7i76e.0.stepgen.timer-number 1
# external output signals
# --- COOLANT-FLOOD ---
net coolant-flood hm2_7i76e.0.7i76.0.0.output-00
# external input signals
# --- ESTOP-EXT ---
net estop-ext <= hm2_7i76e.0.7i76.0.0.input-04
# --- HOME-X ---
net home-x <= hm2_7i76e.0.7i76.0.0.input-06-not
# --- HOME-Z ---
net home-z <= hm2_7i76e.0.7i76.0.0.input-07-not
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.x.error-previous-target true
setp pid.x.maxerror .0005
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# Step Gen signals/setup
setp hm2_7i76e.0.stepgen.00.dirsetup [AXIS_0]DIRSETUP
setp hm2_7i76e.0.stepgen.00.dirhold [AXIS_0]DIRHOLD
setp hm2_7i76e.0.stepgen.00.steplen [AXIS_0]STEPLEN
setp hm2_7i76e.0.stepgen.00.stepspace [AXIS_0]STEPSPACE
setp hm2_7i76e.0.stepgen.00.position-scale [AXIS_0]STEP_SCALE
setp hm2_7i76e.0.stepgen.00.step_type 0
setp hm2_7i76e.0.stepgen.00.control-type 1
setp hm2_7i76e.0.stepgen.00.maxaccel [AXIS_0]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.00.maxvel [AXIS_0]STEPGEN_MAXVEL
setp hm2_7i76e.0.gpio.000.invert_output true
# ---closedloop stepper signals---
net x-pos-cmd <= axis.0.motor-pos-cmd
net x-vel-cmd <= axis.0.joint-vel-cmd
net x-output <= hm2_7i76e.0.stepgen.00.velocity-cmd
net x-pos-fb <= hm2_7i76e.0.stepgen.00.position-fb
net x-pos-fb => axis.0.motor-pos-fb
net x-enable <= axis.0.amp-enable-out
net x-enable => hm2_7i76e.0.stepgen.00.enable
# ---setup home / limit switch signals---
net home-x => axis.0.home-sw-in
net x-neg-limit => axis.0.neg-lim-sw-in
net x-pos-limit => axis.0.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror .0005
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp hm2_7i76e.0.stepgen.01.dirsetup [AXIS_2]DIRSETUP
setp hm2_7i76e.0.stepgen.01.dirhold [AXIS_2]DIRHOLD
setp hm2_7i76e.0.stepgen.01.steplen [AXIS_2]STEPLEN
setp hm2_7i76e.0.stepgen.01.stepspace [AXIS_2]STEPSPACE
setp hm2_7i76e.0.stepgen.01.position-scale [AXIS_2]STEP_SCALE
setp hm2_7i76e.0.stepgen.01.step_type 0
setp hm2_7i76e.0.stepgen.01.control-type 1
setp hm2_7i76e.0.stepgen.01.maxaccel [AXIS_2]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.01.maxvel [AXIS_2]STEPGEN_MAXVEL
net z-pos-cmd <= axis.2.motor-pos-cmd
net z-vel-cmd <= axis.2.joint-vel-cmd
net z-output <= hm2_7i76e.0.stepgen.01.velocity-cmd
net z-pos-fb <= hm2_7i76e.0.stepgen.01.position-fb
net z-pos-fb => axis.2.motor-pos-fb
net z-enable <= axis.2.amp-enable-out
net z-enable => hm2_7i76e.0.stepgen.01.enable
net home-z => axis.2.home-sw-in
net z-neg-limit => axis.2.neg-lim-sw-in
net z-pos-limit => axis.2.pos-lim-sw-in
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm-abs => pid.s.command
net spindle-vel-fb-rpm-abs => pid.s.feedback
net spindle-output <= pid.s.output
# ---digital potentionmeter output signals/setup---
setp hm2_7i76e.0.7i76.0.0.spinout-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT
setp hm2_7i76e.0.7i76.0.0.spinout-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT
setp hm2_7i76e.0.7i76.0.0.spinout-scalemax [SPINDLE_9]OUTPUT_SCALE
net spindle-vel-cmd-rpm-abs => hm2_7i76e.0.7i76.0.0.spinout
net spindle-enable => hm2_7i76e.0.7i76.0.0.spinena
net spindle-ccw => hm2_7i76e.0.7i76.0.0.spindir
setp hm2_7i76e.0.encoder.00.counter-mode 1
setp hm2_7i76e.0.encoder.00.filter 1
setp hm2_7i76e.0.encoder.00.index-invert 0
setp hm2_7i76e.0.encoder.00.index-mask 0
setp hm2_7i76e.0.encoder.00.index-mask-invert 0
setp hm2_7i76e.0.encoder.00.scale [SPINDLE_9]ENCODER_SCALE
net spindle-revs <= hm2_7i76e.0.encoder.00.position
net spindle-vel-fb-rps <= hm2_7i76e.0.encoder.00.velocity
net spindle-index-enable <=> hm2_7i76e.0.encoder.00.index-enable
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# Use ACTUAL spindle velocity from spindle encoder
# spindle-velocity bounces around so we filter it with lowpass
# spindle-velocity is signed so we use absolute component to remove sign
# ACTUAL velocity is in RPS not RPM so we scale it.
setp scale.spindle.gain 60
setp lowpass.spindle.gain 1.000000
net spindle-vel-fb-rps => scale.spindle.in
net spindle-fb-rpm scale.spindle.out => abs.spindle.in
net spindle-fb-rpm-abs abs.spindle.out => lowpass.spindle.in
net spindle-fb-rpm-abs-filtered lowpass.spindle.out
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-ext => iocontrol.0.emc-enable-in
# ---manual tool change signals---
# Include your custom HAL commands here
# This file will not be overwritten when you run PNCconf again
loadusr -W toolerator3000
net tool-change iocontrol.0.tool-change => toolerator3000.toolchange
net tool-changed iocontrol.0.tool-changed <= toolerator3000.toolchanged
net tool-number iocontrol.0.tool-prep-number => toolerator3000.toolnumber
#loadrt scale count=1
#addf scale.0 servo-thread
#setp scale.0.gain 0.002
#net spindle-speed-scale motion.spindle-speed-out => scale.0.in
#net spindle-speed-DAC scale.0.out => <hm2_7i76e.0.7i76.0.0.spinout>
# Disconnect motion.spindle-revs from the signal in the main HAL file
unlinkp motion.spindle-revs
#loadrt lowpass names=lowpass.0
addf lowpass.0 servo-thread
setp lowpass.0.gain 0.05
# This signal needs to be the one from your main HAL file.
# This is a guess...
net spindle-revs lowpass.0.in
net spindle-revs-filt lopass.0.out => motion.spindle-revsThis is what i have in my .ini file:
[HAL]
HALUI = halui
TWOPASS=ON
[HALUI]This is the error message i get:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.8
Machine configuration directory is '/home/victor/linuxcnc/configs/Emco-120P'
Machine configuration file is 'Emco-120P.ini'
INIFILE=/home/victor/linuxcnc/configs/Emco-120P/Emco-120P.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./Emco-120P.hal
twopass:found ./custom.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=4107
hm2: unloading
Debug file information:
Note: Using POSIX realtime
while executing
("eval" body line 1)
invoked from within
"eval hal loadrt $args"
(procedure "orig_loadrt" line 1)
invoked from within
"orig_loadrt hm2_eth board_ip=\"10.10.10.10\" config=\"firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=2 sserial_port_0=00xxxx\""
invoked from within
"eval $cmd"
(procedure "load_the_modules" line 22)
invoked from within
"load_the_modules"
(procedure "::tp::pass0" line 11)
invoked from within
"::tp::pass0"
(file "/usr/lib/tcltk/linuxcnc/twopass.tcl" line 556)
invoked from within
"source $filename"
invoked from within
"set result [source $filename]"
(file "/usr/bin/haltcl" line 55)
4107
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-4-rt-amd64 (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT RT Debian 3.2.96-2
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-rt-amd64 root=UUID=91c3399b-61f5-4d16-8a0d-e4b87d432e14 ro quiet
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009c800 (usable)
[ 0.000000] BIOS-e820: 000000000009c800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000020000000 (usable)
[ 0.000000] BIOS-e820: 0000000020000000 - 0000000020100000 (reserved)
[ 0.000000] BIOS-e820: 0000000020100000 - 00000000ad584000 (usable)
[ 0.000000] BIOS-e820: 00000000ad584000 - 00000000ad5b4000 (reserved)
[ 0.000000] BIOS-e820: 00000000ad5b4000 - 00000000ad608000 (usable)
[ 0.000000] BIOS-e820: 00000000ad608000 - 00000000ad719000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000ad719000 - 00000000ada7d000 (reserved)
[ 0.000000] BIOS-e820: 00000000ada7d000 - 00000000ada7e000 (usable)
[ 0.000000] BIOS-e820: 00000000ada7e000 - 00000000adac0000 (reserved)
[ 0.000000] BIOS-e820: 00000000adac0000 - 00000000adc2e000 (usable)
[ 0.000000] BIOS-e820: 00000000adc2e000 - 00000000adffa000 (reserved)
[ 0.000000] BIOS-e820: 00000000adffa000 - 00000000ae000000 (usable)
[ 0.000000] BIOS-e820: 00000000e00f8000 - 00000000e00f9000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed01000 - 00000000fed02000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 0000000140000000 (usable)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.8 present.
[ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./Q1900B-ITX, BIOS P1.80 12/10/2015
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] No AGP bridge found
[ 0.000000] last_pfn = 0x140000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-E7FFF write-through
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 080000000 mask FE0000000 write-back
[ 0.000000] 2 base 0A0000000 mask FF0000000 write-back
[ 0.000000] 3 base 0AE800000 mask FFF800000 uncachable
[ 0.000000] 4 base 0AF000000 mask FFF000000 uncachable
[ 0.000000] 5 base 100000000 mask FC0000000 write-back
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000ae800000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0xae000 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [ffff8800000fd6b0] fd6b0
[ 0.000000] initial memory mapped : 0 - 20000000
[ 0.000000] Base memory trampoline at [ffff880000097000] 97000 size 20480
[ 0.000000] init_memory_mapping: 0000000000000000-00000000ae000000
[ 0.000000] 0000000000 - 00ae000000 page 2M
[ 0.000000] kernel direct mapping tables up to ae000000 @ 1fffc000-20000000
[ 0.000000] init_memory_mapping: 0000000100000000-0000000140000000
[ 0.000000] 0100000000 - 0140000000 page 2M
[ 0.000000] kernel direct mapping tables up to 140000000 @ adffe000-ae000000
[ 0.000000] RAMDISK: 36b9c000 - 375c6000
[ 0.000000] ACPI: RSDP 0x00000000000F04A0 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 0x00000000AD68E080 0007C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 0x00000000AD6993C0 0010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI Warning: FADT (revision 5) is longer than ACPI 2.0 version, truncating length 268 to 244 (20110623/tbfadt-288)
[ 0.000000] ACPI: DSDT 0x00000000AD68E190 0B229 (v02 ALASKA A M I 01072009 INTL 20120913)
[ 0.000000] ACPI: FACS 0x00000000AD718F80 00040
[ 0.000000] ACPI: APIC 0x00000000AD6994D0 00084 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 0x00000000AD699558 00044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG 0x00000000AD6995A0 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: LPIT 0x00000000AD6995E0 00104 (v01 ALASKA A M I 00000003 VLV2 0100000D)
[ 0.000000] ACPI: AAFT 0x00000000AD6996E8 000D7 (v01 ALASKA OEMAAFT 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET 0x00000000AD6997C0 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT 0x00000000AD6997F8 00763 (v01 PmRef CpuPm 00003000 INTL 20061109)
[ 0.000000] ACPI: SSDT 0x00000000AD699F60 00290 (v01 PmRef Cpu0Tst 00003000 INTL 20061109)
[ 0.000000] ACPI: SSDT 0x00000000AD69A1F0 0017A (v01 PmRef ApTst 00003000 INTL 20061109)
[ 0.000000] ACPI: UEFI 0x00000000AD69A370 00042 (v01 ALASKA A M I 00000000 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at 0000000000000000-0000000140000000
[ 0.000000] Initmem setup node 0 0000000000000000-0000000140000000
[ 0.000000] NODE_DATA [000000013fffb000 - 000000013fffffff]
[ 0.000000] [ffffea0000000000-ffffea00045fffff] PMD -> [ffff88013ba00000-ffff88013effffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] DMA32 0x00001000 -> 0x00100000
[ 0.000000] Normal 0x00100000 -> 0x00140000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[8] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009c
[ 0.000000] 0: 0x00000100 -> 0x00020000
[ 0.000000] 0: 0x00020100 -> 0x000ad584
[ 0.000000] 0: 0x000ad5b4 -> 0x000ad608
[ 0.000000] 0: 0x000ada7d -> 0x000ada7e
[ 0.000000] 0: 0x000adac0 -> 0x000adc2e
[ 0.000000] 0: 0x000adffa -> 0x000ae000
[ 0.000000] 0: 0x00100000 -> 0x00140000
[ 0.000000] On node 0 totalpages: 972249
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 5 pages reserved
[ 0.000000] DMA zone: 3919 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 14280 pages used for memmap
[ 0.000000] DMA32 zone: 691845 pages, LIFO batch:31
[ 0.000000] Normal zone: 3584 pages used for memmap
[ 0.000000] Normal zone: 258560 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high dfl lint[0x7d])
[ 0.000000] ACPI: NMI not connected to LINT 1!
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] res edge lint[0xbe])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] dfl dfl lint[0x77])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] low level lint[0x15])
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-86
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 103
[ 0.000000] PM: Registered nosave memory: 000000000009c000 - 000000000009d000
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 0000000020000000 - 0000000020100000
[ 0.000000] PM: Registered nosave memory: 00000000ad584000 - 00000000ad5b4000
[ 0.000000] PM: Registered nosave memory: 00000000ad608000 - 00000000ad719000
[ 0.000000] PM: Registered nosave memory: 00000000ad719000 - 00000000ada7d000
[ 0.000000] PM: Registered nosave memory: 00000000ada7e000 - 00000000adac0000
[ 0.000000] PM: Registered nosave memory: 00000000adc2e000 - 00000000adffa000
[ 0.000000] PM: Registered nosave memory: 00000000ae000000 - 00000000e00f8000
[ 0.000000] PM: Registered nosave memory: 00000000e00f8000 - 00000000e00f9000
[ 0.000000] PM: Registered nosave memory: 00000000e00f9000 - 00000000fed01000
[ 0.000000] PM: Registered nosave memory: 00000000fed01000 - 00000000fed02000
[ 0.000000] PM: Registered nosave memory: 00000000fed02000 - 00000000ffb00000
[ 0.000000] PM: Registered nosave memory: 00000000ffb00000 - 0000000100000000
[ 0.000000] Allocating PCI resources starting at ae000000 (gap: ae000000:320f8000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 107 pages/cpu @ffff88013fc00000 s409408 r8192 d20672 u524288
[ 0.000000] pcpu-alloc: s409408 r8192 d20672 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 954324
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-rt-amd64 root=UUID=91c3399b-61f5-4d16-8a0d-e4b87d432e14 ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Checking aperture...
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 3746092k/5242880k available (3535k kernel code, 1353884k absent, 142904k reserved, 3237k data, 916k init)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:33024 nr_irqs:1024 16
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration failed
[ 0.008000] TSC: PIT calibration matches HPET. 1 loops
[ 0.008000] Detected 1999.994 MHz processor.
[ 0.000005] Calibrating delay loop (skipped), value calculated using timer frequency.. 3999.98 BogoMIPS (lpj=7999976)
[ 0.000011] pid_max: default: 32768 minimum: 301
[ 0.000121] Security Framework initialized
[ 0.000127] AppArmor: AppArmor disabled by boot time parameter
[ 0.001410] Dentry cache hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.004382] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.005232] Mount-cache hash table entries: 256
[ 0.005458] Initializing cgroup subsys cpuacct
[ 0.005466] Initializing cgroup subsys memory
[ 0.005484] Initializing cgroup subsys devices
[ 0.005488] Initializing cgroup subsys freezer
[ 0.005491] Initializing cgroup subsys net_cls
[ 0.005494] Initializing cgroup subsys blkio
[ 0.005992] Initializing cgroup subsys perf_event
[ 0.006044] CPU: Physical Processor ID: 0
[ 0.006047] CPU: Processor Core ID: 0
[ 0.006052] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.006054] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.010812] mce: CPU supports 6 MCE banks
[ 0.010824] CPU0: Thermal monitoring enabled (TM1)
[ 0.010830] using mwait in idle threads.
[ 0.011259] ACPI: Core revision 20110623
[ 0.030208] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.069896] CPU0: Intel(R) Celeron(R) CPU J1900 @ 1.99GHz stepping 03
[ 0.173955] Performance Events: no PEBS fmt2+, generic architected perfmon, Intel PMU driver.
[ 0.173979] ... version: 3
[ 0.173983] ... bit width: 40
[ 0.173987] ... generic registers: 2
[ 0.173990] ... value mask: 000000ffffffffff
[ 0.173994] ... max period: 000000007fffffff
[ 0.173997] ... fixed-purpose events: 3
[ 0.174001] ... event mask: 0000000700000003
[ 0.194349] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.214010] Booting Node 0, Processors #1
[ 0.214017] smpboot cpu 1: start_ip = 97000
[ 0.326833] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.342034] #2
[ 0.342039] smpboot cpu 2: start_ip = 97000
[ 0.454814] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.470023] #3 Ok.
[ 0.470027] smpboot cpu 3: start_ip = 97000
[ 0.582815] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.585967] Brought up 4 CPUs
[ 0.585973] Total of 4 processors activated (15999.98 BogoMIPS).
[ 0.587291] devtmpfs: initialized
[ 0.591078] PM: Registering ACPI NVS region at ad608000 (1118208 bytes)
[ 0.591742] print_constraints: dummy:
[ 0.591946] NET: Registered protocol family 16
[ 0.592311] ACPI: bus type pci registered
[ 0.592514] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.592520] PCI: not using MMCONFIG
[ 0.592525] PCI: Using configuration type 1 for base access
[ 0.595645] bio: create slab <bio-0> at 0
[ 0.595979] ACPI: Added _OSI(Module Device)
[ 0.595987] ACPI: Added _OSI(Processor Device)
[ 0.595993] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.595999] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.601471] ACPI: EC: Look up EC in DSDT
[ 0.657432] ACPI: SSDT 0x00000000AD5ACC18 003D7 (v01 PmRef Cpu0Ist 00003000 INTL 20061109)
[ 0.658868] ACPI: Dynamic OEM Table Load:
[ 0.658876] ACPI: SSDT 0x0000000000000000 003D7 (v01 PmRef Cpu0Ist 00003000 INTL 20061109)
[ 0.659583] ACPI: SSDT 0x00000000AD5AB918 003DE (v01 PmRef Cpu0Cst 00003001 INTL 20061109)
[ 0.660924] ACPI: Dynamic OEM Table Load:
[ 0.660932] ACPI: SSDT 0x0000000000000000 003DE (v01 PmRef Cpu0Cst 00003001 INTL 20061109)
[ 0.692485] ACPI: SSDT 0x00000000AD5B1C18 0015F (v01 PmRef ApIst 00003000 INTL 20061109)
[ 0.694045] ACPI: Dynamic OEM Table Load:
[ 0.694053] ACPI: SSDT 0x0000000000000000 0015F (v01 PmRef ApIst 00003000 INTL 20061109)
[ 0.714626] ACPI: SSDT 0x00000000AD5ADF18 0008D (v01 PmRef ApCst 00003000 INTL 20061109)
[ 0.716021] ACPI: Dynamic OEM Table Load:
[ 0.716030] ACPI: SSDT 0x0000000000000000 0008D (v01 PmRef ApCst 00003000 INTL 20061109)
[ 0.744303] ACPI: Interpreter enabled
[ 0.744312] ACPI: (supports S0 S3 S4 S5)
[ 0.744423] ACPI: Using IOAPIC for interrupt routing
[ 0.744746] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.749133] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.826387] ACPI: Power Resource [USBC] (on)
[ 0.832326] ACPI: Power Resource [FN00] (off)
[ 0.834491] ACPI: No dock devices found.
[ 0.834497] HEST: Table not found.
[ 0.834504] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.835688] \_SB_.PCI0:_OSC invalid UUID
[ 0.835694] _OSC request data:1 8 0
[ 0.835707] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.837244] pci_root PNP0A08:00: host bridge window [io 0x0000-0x006f]
[ 0.837251] pci_root PNP0A08:00: host bridge window [io 0x0078-0x0cf7]
[ 0.837256] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.837261] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.837267] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff]
[ 0.837272] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000fffff]
[ 0.837277] pci_root PNP0A08:00: host bridge window [mem 0xc0000000-0xd0716ffe]
[ 0.837307] pci 0000:00:00.0: [8086:0f00] type 0 class 0x000600
[ 0.837375] pci 0000:00:02.0: [8086:0f31] type 0 class 0x000300
[ 0.837393] pci 0000:00:02.0: reg 10: [mem 0xd0000000-0xd03fffff]
[ 0.837408] pci 0000:00:02.0: reg 18: [mem 0xc0000000-0xcfffffff pref]
[ 0.837423] pci 0000:00:02.0: reg 20: [io 0xf080-0xf087]
[ 0.837508] pci 0000:00:13.0: [8086:0f23] type 0 class 0x000106
[ 0.837533] pci 0000:00:13.0: reg 10: [io 0xf070-0xf077]
[ 0.837545] pci 0000:00:13.0: reg 14: [io 0xf060-0xf063]
[ 0.837558] pci 0000:00:13.0: reg 18: [io 0xf050-0xf057]
[ 0.837570] pci 0000:00:13.0: reg 1c: [io 0xf040-0xf043]
[ 0.837583] pci 0000:00:13.0: reg 20: [io 0xf020-0xf03f]
[ 0.837596] pci 0000:00:13.0: reg 24: [mem 0xd0716000-0xd07167ff]
[ 0.837650] pci 0000:00:13.0: PME# supported from D3hot
[ 0.837686] pci 0000:00:14.0: [8086:0f35] type 0 class 0x000c03
[ 0.837710] pci 0000:00:14.0: reg 10: [mem 0xd0700000-0xd070ffff 64bit]
[ 0.837777] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.837820] pci 0000:00:1a.0: [8086:0f18] type 0 class 0x001080
[ 0.837850] pci 0000:00:1a.0: reg 10: [mem 0xd0500000-0xd05fffff]
[ 0.837867] pci 0000:00:1a.0: reg 14: [mem 0xd0400000-0xd04fffff]
[ 0.837998] pci 0000:00:1a.0: PME# supported from D0 D3hot
[ 0.838039] pci 0000:00:1b.0: [8086:0f04] type 0 class 0x000403
[ 0.838067] pci 0000:00:1b.0: reg 10: [mem 0xd0710000-0xd0713fff 64bit]
[ 0.838147] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.838179] pci 0000:00:1c.0: [8086:0f48] type 1 class 0x000604
[ 0.838251] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.838285] pci 0000:00:1c.1: [8086:0f4a] type 1 class 0x000604
[ 0.838356] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.838389] pci 0000:00:1c.2: [8086:0f4c] type 1 class 0x000604
[ 0.838460] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.838494] pci 0000:00:1c.3: [8086:0f4e] type 1 class 0x000604
[ 0.838564] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.838611] pci 0000:00:1d.0: [8086:0f34] type 0 class 0x000c03
[ 0.838643] pci 0000:00:1d.0: reg 10: [mem 0xd0715000-0xd07153ff]
[ 0.838771] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.838811] pci 0000:00:1f.0: [8086:0f1c] type 0 class 0x000601
[ 0.838925] pci 0000:00:1f.3: [8086:0f12] type 0 class 0x000c05
[ 0.838964] pci 0000:00:1f.3: reg 10: [mem 0xd0714000-0xd071401f]
[ 0.839040] pci 0000:00:1f.3: reg 20: [io 0xf000-0xf01f]
[ 0.839191] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.839272] pci 0000:02:00.0: [10ec:8168] type 0 class 0x000200
[ 0.839293] pci 0000:02:00.0: reg 10: [io 0xe000-0xe0ff]
[ 0.839324] pci 0000:02:00.0: reg 18: [mem 0xd0604000-0xd0604fff 64bit]
[ 0.839346] pci 0000:02:00.0: reg 20: [mem 0xd0600000-0xd0603fff 64bit pref]
[ 0.839427] pci 0000:02:00.0: supports D1 D2
[ 0.839432] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.845977] pci 0000:00:1c.1: PCI bridge to [bus 02-02]
[ 0.845986] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
[ 0.845993] pci 0000:00:1c.1: bridge window [mem 0xd0600000-0xd06fffff]
[ 0.846049] pci 0000:00:1c.2: PCI bridge to [bus 03-03]
[ 0.846100] pci 0000:00:1c.3: PCI bridge to [bus 04-04]
[ 0.846132] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.847269] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.847552] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 0.847839] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
[ 0.848114] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT]
[ 0.848743] \_SB_.PCI0:_OSC invalid UUID
[ 0.848748] _OSC request data:1 1f 0
[ 0.848760] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.849117] \_SB_.PCI0:_OSC invalid UUID
[ 0.849122] _OSC request data:1 0 1d
[ 0.849134] pci0000:00: ACPI _OSC request failed (AE_ERROR), returned control mask: 0x1d
[ 0.849138] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.884943] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.885244] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.885530] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.885815] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.886100] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.886385] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.886674] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.886983] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.887372] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.887413] vgaarb: loaded
[ 0.887416] vgaarb: bridge control possible 0000:00:02.0
[ 0.887609] PCI: Using ACPI for IRQ routing
[ 0.893945] PCI: pci_cache_line_size set to 64 bytes
[ 0.894089] reserve RAM buffer: 000000000009c800 - 000000000009ffff
[ 0.894097] reserve RAM buffer: 00000000ad584000 - 00000000afffffff
[ 0.894103] reserve RAM buffer: 00000000ad608000 - 00000000afffffff
[ 0.894110] reserve RAM buffer: 00000000ada7e000 - 00000000afffffff
[ 0.894116] reserve RAM buffer: 00000000adc2e000 - 00000000afffffff
[ 0.894123] reserve RAM buffer: 00000000ae000000 - 00000000afffffff
[ 0.894480] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.894492] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.896562] AMD NB: Cannot enumerate AMD northbridges.
[ 0.896568] Switching to clocksource hpet
[ 0.906244] pnp: PnP ACPI init
[ 0.906287] ACPI: bus type pnp registered
[ 0.906365] pnp 00:00: [io 0x0070-0x0077]
[ 0.906456] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.906595] pnp 00:01: [mem 0xfed00000-0xfed003ff]
[ 0.906603] pnp 00:01: IRQ 8 override to edge, high
[ 0.906620] pnp 00:01: [irq 8]
[ 0.906700] pnp 00:01: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.907452] pnp 00:02: [bus 00-ff]
[ 0.907459] pnp 00:02: [io 0x0070-0x0077]
[ 0.907465] pnp 00:02: [io 0x0cf8-0x0cff]
[ 0.907471] pnp 00:02: [io 0x0000-0x006f window]
[ 0.907476] pnp 00:02: [io 0x0078-0x0cf7 window]
[ 0.907482] pnp 00:02: [io 0x0d00-0xffff window]
[ 0.907488] pnp 00:02: [mem 0x000a0000-0x000bffff window]
[ 0.907494] pnp 00:02: [mem 0x000c0000-0x000dffff window]
[ 0.907500] pnp 00:02: [mem 0x000e0000-0x000fffff window]
[ 0.907506] pnp 00:02: [mem 0x00000000 window]
[ 0.907512] pnp 00:02: [mem 0x00000000-0xffffffff window]
[ 0.907518] pnp 00:02: [mem 0xc0000000-0xd0716ffe window]
[ 0.907665] pnp 00:02: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.907964] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 0.908058] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.908115] pnp 00:04: [io 0x002e-0x002f]
[ 0.908121] pnp 00:04: [io 0x004e-0x004f]
[ 0.908127] pnp 00:04: [io 0x0061]
[ 0.908132] pnp 00:04: [io 0x0063]
[ 0.908137] pnp 00:04: [io 0x0065]
[ 0.908142] pnp 00:04: [io 0x0067]
[ 0.908147] pnp 00:04: [io 0x0070]
[ 0.908152] pnp 00:04: [io 0x0080-0x008f]
[ 0.908158] pnp 00:04: [io 0x0092]
[ 0.908163] pnp 00:04: [io 0x00b2-0x00b3]
[ 0.908168] pnp 00:04: [io 0x0680-0x069f]
[ 0.908174] pnp 00:04: [io 0x0400-0x047f]
[ 0.908179] pnp 00:04: [io 0x0500-0x05fe]
[ 0.908341] system 00:04: [io 0x0680-0x069f] has been reserved
[ 0.908351] system 00:04: [io 0x0400-0x047f] could not be reserved
[ 0.908359] system 00:04: [io 0x0500-0x05fe] has been reserved
[ 0.908367] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.908769] pnp 00:05: [io 0x0000-0xffffffffffffffff disabled]
[ 0.908777] pnp 00:05: [io 0x0000-0xffffffffffffffff disabled]
[ 0.908783] pnp 00:05: [io 0x0290-0x029f]
[ 0.908788] pnp 00:05: [io 0x0000-0xffffffffffffffff disabled]
[ 0.908938] system 00:05: [io 0x0290-0x029f] has been reserved
[ 0.908946] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.911170] pnp 00:06: [io 0x0378-0x037f]
[ 0.911177] pnp 00:06: [io 0x0778-0x077f]
[ 0.911191] pnp 00:06: [irq 5]
[ 0.911197] pnp 00:06: [dma 3]
[ 0.911931] pnp 00:06: Plug and Play ACPI device, IDs PNP0400 PNP0401 (active)
[ 0.913076] pnp 00:07: [io 0x03f8-0x03ff]
[ 0.913089] pnp 00:07: [irq 4]
[ 0.913095] pnp 00:07: [dma 0 disabled]
[ 0.913288] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.914747] pnp 00:08: [io 0x02f8-0x02ff]
[ 0.914760] pnp 00:08: [irq 3]
[ 0.914767] pnp 00:08: [dma 0 disabled]
[ 0.914957] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.916009] pnp 00:09: [mem 0xe0000000-0xefffffff]
[ 0.916016] pnp 00:09: [mem 0xfed01000-0xfed01fff]
[ 0.916022] pnp 00:09: [mem 0xfed03000-0xfed03fff]
[ 0.916028] pnp 00:09: [mem 0xfed04000-0xfed04fff]
[ 0.916033] pnp 00:09: [mem 0xfed0c000-0xfed0ffff]
[ 0.916039] pnp 00:09: [mem 0xfed08000-0xfed08fff]
[ 0.916045] pnp 00:09: [mem 0xfed1c000-0xfed1cfff]
[ 0.916050] pnp 00:09: [mem 0xfee00000-0xfeefffff]
[ 0.916056] pnp 00:09: [mem 0xfef00000-0xfeffffff]
[ 0.916243] system 00:09: [mem 0xe0000000-0xefffffff] could not be reserved
[ 0.916252] system 00:09: [mem 0xfed01000-0xfed01fff] has been reserved
[ 0.916260] system 00:09: [mem 0xfed03000-0xfed03fff] has been reserved
[ 0.916268] system 00:09: [mem 0xfed04000-0xfed04fff] has been reserved
[ 0.916276] system 00:09: [mem 0xfed0c000-0xfed0ffff] has been reserved
[ 0.916283] system 00:09: [mem 0xfed08000-0xfed08fff] has been reserved
[ 0.916291] system 00:09: [mem 0xfed1c000-0xfed1cfff] has been reserved
[ 0.916299] system 00:09: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.916311] system 00:09: [mem 0xfef00000-0xfeffffff] has been reserved
[ 0.916319] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.921725] pnp: PnP ACPI: found 10 devices
[ 0.921730] ACPI: ACPI bus type pnp unregistered
[ 0.934219] PCI: max bus depth: 1 pci_try_num: 2
[ 0.934281] pci 0000:00:1c.3: BAR 14: can't assign mem (size 0x200000)
[ 0.934291] pci 0000:00:1c.3: BAR 15: can't assign mem pref (size 0x200000)
[ 0.934302] pci 0000:00:1c.3: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.934311] pci 0000:00:1c.2: BAR 14: can't assign mem (size 0x200000)
[ 0.934320] pci 0000:00:1c.2: BAR 15: can't assign mem pref (size 0x200000)
[ 0.934329] pci 0000:00:1c.2: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.934338] pci 0000:00:1c.1: BAR 15: can't assign mem pref (size 0x200000)
[ 0.934347] pci 0000:00:1c.0: BAR 14: can't assign mem (size 0x200000)
[ 0.934356] pci 0000:00:1c.0: BAR 15: can't assign mem pref (size 0x200000)
[ 0.934364] pci 0000:00:1c.0: BAR 13: assigned [io 0x3000-0x3fff]
[ 0.934379] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.934384] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff]
[ 0.934398] pci 0000:00:1c.1: PCI bridge to [bus 02-02]
[ 0.934403] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
[ 0.934411] pci 0000:00:1c.1: bridge window [mem 0xd0600000-0xd06fffff]
[ 0.934421] pci 0000:00:1c.2: PCI bridge to [bus 03-03]
[ 0.934426] pci 0000:00:1c.2: bridge window [io 0x2000-0x2fff]
[ 0.934439] pci 0000:00:1c.3: PCI bridge to [bus 04-04]
[ 0.934444] pci 0000:00:1c.3: bridge window [io 0x1000-0x1fff]
[ 0.934484] pci 0000:00:1c.0: setting latency timer to 64
[ 0.934514] pci 0000:00:1c.1: setting latency timer to 64
[ 0.934536] pci 0000:00:1c.2: setting latency timer to 64
[ 0.934558] pci 0000:00:1c.3: setting latency timer to 64
[ 0.934565] pci_bus 0000:00: resource 4 [io 0x0000-0x006f]
[ 0.934570] pci_bus 0000:00: resource 5 [io 0x0078-0x0cf7]
[ 0.934575] pci_bus 0000:00: resource 6 [io 0x0d00-0xffff]
[ 0.934580] pci_bus 0000:00: resource 7 [mem 0x000a0000-0x000bffff]
[ 0.934585] pci_bus 0000:00: resource 8 [mem 0x000c0000-0x000dffff]
[ 0.934590] pci_bus 0000:00: resource 9 [mem 0x000e0000-0x000fffff]
[ 0.934595] pci_bus 0000:00: resource 10 [mem 0xc0000000-0xd0716ffe]
[ 0.934601] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.934606] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.934611] pci_bus 0000:02: resource 1 [mem 0xd0600000-0xd06fffff]
[ 0.934616] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 0.934621] pci_bus 0000:04: resource 0 [io 0x1000-0x1fff]
[ 0.934784] NET: Registered protocol family 2
[ 0.940770] IP route cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.944352] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.948306] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[ 0.949591] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.949598] TCP reno registered
[ 0.949699] UDP hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.949885] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.950237] NET: Registered protocol family 1
[ 0.950285] pci 0000:00:02.0: Boot video device
[ 0.964643] PCI: CLS 64 bytes, default 64
[ 0.964817] Unpacking initramfs...
[ 1.354067] Freeing initrd memory: 10408k freed
[ 1.359807] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.359816] Placing 64MB software IO TLB between ffff8800a9584000 - ffff8800ad584000
[ 1.359821] software IO TLB at phys 0xa9584000 - 0xad584000
[ 1.361423] audit: initializing netlink socket (disabled)
[ 1.361455] type=2000 audit(1540930868.204:1): initialized
[ 1.381798] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.382412] VFS: Disk quotas dquot_6.5.2
[ 1.382503] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.382711] msgmni has been set to 7336
[ 1.383141] alg: No test for stdrng (krng)
[ 1.383218] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.383226] io scheduler noop registered
[ 1.383230] io scheduler deadline registered
[ 1.383282] io scheduler cfq registered (default)
[ 1.383789] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.383870] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.383875] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 1.385585] intel_idle: does not run on family 6 model 55
[ 1.385643] ERST: Table is not found!
[ 1.385647] GHES: HEST is not enabled!
[ 1.385793] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.406391] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.489120] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.685401] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.753258] 00:08: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.801110] Linux agpgart interface v0.103
[ 1.801520] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.804358] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.804404] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.804919] mousedev: PS/2 mouse device common for all mice
[ 1.805028] rtc_cmos 00:00: RTC can wake from S4
[ 1.805262] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[ 1.805360] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.805396] cpuidle: using governor ladder
[ 1.805401] cpuidle: using governor menu
[ 1.806171] TCP cubic registered
[ 1.806290] NET: Registered protocol family 10
[ 1.808042] Mobile IPv6
[ 1.808049] NET: Registered protocol family 17
[ 1.808061] Registering the dns_resolver key type
[ 1.808464] PM: Hibernation image not present or could not be loaded.
[ 1.808499] registered taskstats version 1
[ 1.809236] rtc_cmos 00:00: setting system clock to 2018-10-30 20:21:09 UTC (1540930869)
[ 1.809481] Initializing network drop monitor service
[ 1.813444] Freeing unused kernel memory: 916k freed
[ 1.813859] Write protecting the kernel read-only data: 6144k
[ 1.818207] Freeing unused kernel memory: 544k freed
[ 1.823475] Freeing unused kernel memory: 652k freed
[ 1.851919] udevd[77]: starting version 175
[ 1.936885] SCSI subsystem initialized
[ 1.948981] usbcore: registered new interface driver usbfs
[ 1.953736] usbcore: registered new interface driver hub
[ 1.955888] usbcore: registered new device driver usb
[ 1.959440] libata version 3.00 loaded.
[ 1.962507] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.962799] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.962809] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 1.962961] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 1.963035] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.966938] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 1.967085] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xd0715000
[ 1.975882] ACPI: Fan [FAN0] (off)
[ 1.980701] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.981055] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.981075] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.981082] usb usb1: Product: EHCI Host Controller
[ 1.981087] usb usb1: Manufacturer: Linux 3.2.0-4-rt-amd64 ehci_hcd
[ 1.981094] usb usb1: SerialNumber: 0000:00:1d.0
[ 1.982848] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.982924] r8169 0000:02:00.0: (unregistered net_device): unknown MAC, using family default
[ 1.982948] r8169 0000:02:00.0: setting latency timer to 64
[ 1.983044] r8169 0000:02:00.0: irq 103 for MSI/MSI-X
[ 1.983697] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.983705] ACPI: Thermal Zone [TZ01] (27 C)
[ 1.988038] hub 1-0:1.0: USB hub found
[ 1.988096] hub 1-0:1.0: 8 ports detected
[ 1.990472] r8169 0000:02:00.0: eth0: RTL8168b/8111b at 0xffffc90000a78000, d0:50:99:a6:d7:74, XID 0c000800 IRQ 103
[ 1.990480] r8169 0000:02:00.0: eth0: jumbo features [frames: 4080 bytes, tx checksumming: ko]
[ 1.992307] xhci_hcd 0000:00:14.0: setting latency timer to 64
[ 1.992316] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.992416] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.993562] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.993623] xhci_hcd 0000:00:14.0: irq 104 for MSI/MSI-X
[ 1.994008] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.994017] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.994022] usb usb2: Product: xHCI Host Controller
[ 1.994027] usb usb2: Manufacturer: Linux 3.2.0-4-rt-amd64 xhci_hcd
[ 1.994032] usb usb2: SerialNumber: 0000:00:14.0
[ 1.997200] xHCI xhci_add_endpoint called for root hub
[ 1.997207] xHCI xhci_check_bandwidth called for root hub
[ 1.998270] hub 2-0:1.0: USB hub found
[ 1.998292] hub 2-0:1.0: 6 ports detected
[ 2.000762] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 2.000786] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 2.000877] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.000884] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.000891] usb usb3: Product: xHCI Host Controller
[ 2.000896] usb usb3: Manufacturer: Linux 3.2.0-4-rt-amd64 xhci_hcd
[ 2.000901] usb usb3: SerialNumber: 0000:00:14.0
[ 2.004125] xHCI xhci_add_endpoint called for root hub
[ 2.004132] xHCI xhci_check_bandwidth called for root hub
[ 2.005322] hub 3-0:1.0: USB hub found
[ 2.005358] hub 3-0:1.0: 1 port detected
[ 2.021437] ahci 0000:00:13.0: version 3.0
[ 2.021557] ahci 0000:00:13.0: irq 105 for MSI/MSI-X
[ 2.036623] ahci 0000:00:13.0: AHCI 0001.0300 32 slots 2 ports 3 Gbps 0x1 impl SATA mode
[ 2.036634] ahci 0000:00:13.0: flags: 64bit ncq led clo pio slum part
[ 2.036645] ahci 0000:00:13.0: setting latency timer to 64
[ 2.042999] scsi0 : ahci
[ 2.043451] scsi1 : ahci
[ 2.043870] ata1: SATA max UDMA/133 abar m2048@0xd0716000 port 0xd0716100 irq 105
[ 2.043879] ata2: DUMMY
[ 2.296608] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 2.356606] Refined TSC clocksource calibration: 1999.999 MHz.
[ 2.356616] Switching to clocksource tsc
[ 2.368607] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.369544] ata1.00: ATA-9: TS16GHSD370, O0918B, max UDMA/133
[ 2.369550] ata1.00: 31277232 sectors, multi 2: LBA48 NCQ (depth 31/32), AA
[ 2.369765] ata1.00: configured for UDMA/133
[ 2.370005] scsi 0:0:0:0: Direct-Access ATA TS16GHSD370 O091 PQ: 0 ANSI: 5
[ 2.380495] sd 0:0:0:0: [sda] 31277232 512-byte logical blocks: (16.0 GB/14.9 GiB)
[ 2.380786] sd 0:0:0:0: [sda] Write Protect is off
[ 2.380794] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.380879] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.381912] sda: sda1 sda2 < sda5 >
[ 2.382968] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.387156] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.429151] usb 1-1: New USB device found, idVendor=8087, idProduct=07e6
[ 2.429162] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.429652] hub 1-1:1.0: USB hub found
[ 2.429776] hub 1-1:1.0: 4 ports detected
[ 2.700595] usb 1-1.1: new low-speed USB device number 3 using ehci_hcd
[ 2.812525] usb 1-1.1: New USB device found, idVendor=03f0, idProduct=034a
[ 2.812532] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.812537] usb 1-1.1: Product: HP Elite USB Keyboard
[ 2.812541] usb 1-1.1: Manufacturer: Chicony
[ 2.830150] input: Chicony HP Elite USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input0
[ 2.830318] generic-usb 0003:03F0:034A.0001: input,hidraw0: USB HID v1.10 Keyboard [Chicony HP Elite USB Keyboard] on usb-0000:00:1d.0-1.1/input0
[ 2.840625] input: Chicony HP Elite USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.1/1-1.1:1.1/input/input1
[ 2.840778] generic-usb 0003:03F0:034A.0002: input,hidraw1: USB HID v1.10 Device [Chicony HP Elite USB Keyboard] on usb-0000:00:1d.0-1.1/input1
[ 2.840827] usbcore: registered new interface driver usbhid
[ 2.840832] usbhid: USB HID core driver
[ 2.884612] usb 1-1.2: new high-speed USB device number 4 using ehci_hcd
[ 2.895317] PM: Starting manual resume from disk
[ 2.895325] PM: Hibernation image partition 8:5 present
[ 2.895328] PM: Looking for hibernation image.
[ 2.895638] PM: Image not found (code -22)
[ 2.895643] PM: Hibernation image not present or could not be loaded.
[ 2.921749] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.978272] usb 1-1.2: New USB device found, idVendor=05e3, idProduct=0608
[ 2.978280] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.978285] usb 1-1.2: Product: USB2.0 Hub
[ 2.978858] hub 1-1.2:1.0: USB hub found
[ 2.979140] hub 1-1.2:1.0: 3 ports detected
[ 3.052600] usb 1-1.3: new full-speed USB device number 5 using ehci_hcd
[ 3.145780] usb 1-1.3: New USB device found, idVendor=1a86, idProduct=7523
[ 3.145788] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 3.145793] usb 1-1.3: Product: USB2.0-Serial
[ 3.216602] usb 1-1.4: new high-speed USB device number 6 using ehci_hcd
[ 3.309523] usb 1-1.4: New USB device found, idVendor=0b05, idProduct=17d2
[ 3.309530] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.309536] usb 1-1.4: Product: 802.11n NIC
[ 3.309540] usb 1-1.4: Manufacturer: Realtek
[ 3.309544] usb 1-1.4: SerialNumber: 123456
[ 3.380616] usb 1-1.2.3: new low-speed USB device number 7 using ehci_hcd
[ 3.458280] udevd[364]: starting version 175
[ 3.480153] usb 1-1.2.3: New USB device found, idVendor=03f0, idProduct=1198
[ 3.480163] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.480169] usb 1-1.2.3: Product: HP USB 1000dpi Laser Mouse
[ 3.480174] usb 1-1.2.3: Manufacturer: HP
[ 3.484671] input: HP HP USB 1000dpi Laser Mouse as /devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.2/1-1.2.3/1-1.2.3:1.0/input/input2
[ 3.484912] generic-usb 0003:03F0:1198.0003: input,hidraw2: USB HID v2.00 Mouse [HP HP USB 1000dpi Laser Mouse] on usb-0000:00:1d.0-1.2.3/input0
[ 3.488146] generic-usb 0003:03F0:1198.0004: hiddev0,hidraw3: USB HID v2.00 Device [HP HP USB 1000dpi Laser Mouse] on usb-0000:00:1d.0-1.2.3/input1
[ 3.686124] ACPI: Requesting acpi_cpufreq
[ 3.707169] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 3.707187] ACPI: Power Button [PWRB]
[ 3.712146] Monitor-Mwait will be used to enter C-1 state
[ 3.712175] Monitor-Mwait will be used to enter C-2 state
[ 3.712221] ACPI: acpi_idle registered with cpuidle
[ 3.728300] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 3.732490] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5
[ 3.732557] ACPI: Sleep Button [SLPB]
[ 3.739893] ACPI: resource 0000:00:1f.3 [io 0xf000-0xf01f] conflicts with ACPI region SMBI [io 0xf000-0xf00f]
[ 3.739901] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 3.755128] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[ 3.755141] ACPI: Power Button [PWRF]
[ 3.864198] snd_hda_intel 0000:00:1b.0: irq 106 for MSI/MSI-X
[ 3.864939] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[ 4.011978] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 4.045835] parport_pc 00:06: reported by Plug and Play ACPI
[ 4.045926] parport0: PC-style at 0x378 (0x778), irq 5 [PCSPP,TRISTATE]
[ 4.599990] usbcore: registered new interface driver usbserial
[ 4.600896] USB Serial support registered for generic
[ 4.602765] usbcore: registered new interface driver usbserial_generic
[ 4.602773] usbserial: USB Serial Driver core
[ 4.609990] USB Serial support registered for ch341-uart
[ 4.610478] ch341 1-1.3:1.0: ch341-uart converter detected
[ 4.617411] usb 1-1.3: ch341-uart converter now attached to ttyUSB0
[ 4.618150] usbcore: registered new interface driver ch341
[ 4.654683] RTL871X: module init start
[ 4.654692] RTL871X: rtl8812au v4.3.13_14061.20150505
[ 4.654702] RTL871X: build time: Mar 7 2017 18:35:59
[ 4.655268] RTL871X:
[ 4.655271] usb_endpoint_descriptor(0):
[ 4.655279] RTL871X: bLength=7
[ 4.655285] RTL871X: bDescriptorType=5
[ 4.655290] RTL871X: bEndpointAddress=81
[ 4.655295] RTL871X: wMaxPacketSize=512
[ 4.655300] RTL871X: bInterval=0
[ 4.655305] RTL871X: RT_usb_endpoint_is_bulk_in = 1
[ 4.655311] RTL871X:
[ 4.655312] usb_endpoint_descriptor(1):
[ 4.655317] RTL871X: bLength=7
[ 4.655322] RTL871X: bDescriptorType=5
[ 4.655327] RTL871X: bEndpointAddress=2
[ 4.655332] RTL871X: wMaxPacketSize=512
[ 4.655337] RTL871X: bInterval=0
[ 4.655341] RTL871X: RT_usb_endpoint_is_bulk_out = 2
[ 4.655347] RTL871X:
[ 4.655348] usb_endpoint_descriptor(2):
[ 4.655353] RTL871X: bLength=7
[ 4.655358] RTL871X: bDescriptorType=5
[ 4.655362] RTL871X: bEndpointAddress=3
[ 4.655367] RTL871X: wMaxPacketSize=512
[ 4.655372] RTL871X: bInterval=0
[ 4.655377] RTL871X: RT_usb_endpoint_is_bulk_out = 3
[ 4.655382] RTL871X:
[ 4.655384] usb_endpoint_descriptor(3):
[ 4.655388] RTL871X: bLength=7
[ 4.655393] RTL871X: bDescriptorType=5
[ 4.655398] RTL871X: bEndpointAddress=4
[ 4.655402] RTL871X: wMaxPacketSize=512
[ 4.655407] RTL871X: bInterval=0
[ 4.655412] RTL871X: RT_usb_endpoint_is_bulk_out = 4
[ 4.655417] RTL871X:
[ 4.655419] usb_endpoint_descriptor(4):
[ 4.655424] RTL871X: bLength=7
[ 4.655428] RTL871X: bDescriptorType=5
[ 4.655433] RTL871X: bEndpointAddress=85
[ 4.655438] RTL871X: wMaxPacketSize=64
[ 4.655443] RTL871X: bInterval=1
[ 4.655448] RTL871X: RT_usb_endpoint_is_int_in = 5, Interval = 1
[ 4.655454] RTL871X: nr_endpoint=5, in_num=2, out_num=3
[ 4.655456]
[ 4.655460] RTL871X: USB_SPEED_HIGH
[ 4.655496] RTL871X: CHIP TYPE: RTL8812
[ 4.655518] RTL871X: register rtw_netdev_ops to netdev_ops
[ 4.655801] RTL871X: ReadChipVersion8812A SYS_CFG(0xF0)=0x04411137
[ 4.655908] RTL871X: Chip Version Info: CHIP_8812_Normal_Chip_TSMC_C_CUT_2T2R_RomVer(0)
[ 4.655918] RTL871X: RF_Type is 2!!
[ 4.655926] RTL871X: _ConfigChipOutEP_8812 OutEpQueueSel(0x07), OutEpNumber(3)
[ 4.655934] RTL871X: ====> ReadAdapterInfo8812AU
[ 4.656039] RTL871X: Boot from EFUSE, Autoload OK !
[ 4.961907] RTL871X: EEPROM ID=0x8129
[ 4.961917] RTL871X: VID = 0x0B05, PID = 0x17D2
[ 4.961923] RTL871X: Customer ID: 0x00, SubCustomer ID: 0xCD
[ 4.961931] RTL871X: hal_ReadMACAddress_8812AU MAC Address from EFUSE = 9c:5c:8e:b2:b5:a9
[ 4.961945] RTL871X: ==>mpt_GetChnlGroup8812A in 5G, but Channel 163 in Group not found
[ 4.961955] RTL871X: ==>mpt_GetChnlGroup8812A in 5G, but Channel 163 in Group not found
[ 4.961964] RTL871X: ==>mpt_GetChnlGroup8812A in 5G, but Channel 163 in Group not found
[ 4.961973] RTL871X: ==>mpt_GetChnlGroup8812A in 5G, but Channel 163 in Group not found
[ 4.961980] RTL871X: EEPROMRegulatory = 0x1 TxPwrCalibrateRate=0x0
[ 4.961986] RTL871X: Board Type: 0x 0
[ 4.961991] RTL871X: mlmepriv.ChannelPlan = 0x26
[ 4.961997] RTL871X: CrystalCap: 0x2e
[ 4.962002] RTL871X: ThermalMeter = 0x1b
[ 4.962007] RTL871X: Hal_ReadRemoteWakeup_8812A...bSupportRemoteWakeup(0)
[ 4.962013] RTL871X: SWAS: bHwAntDiv = 0, TRxAntDivType = 3
[ 4.962020] RTL871X: pHalData->PAType_2G is 0x33, pHalData->ExternalPA_2G = 1
[ 4.962026] RTL871X: pHalData->PAType_5G is 0x33, pHalData->ExternalPA_5G = 1
[ 4.962032] RTL871X: pHalData->LNAType_2G is 0x88, pHalData->ExternalLNA_2G = 1
[ 4.962038] RTL871X: pHalData->LNAType_5G is 0x88, pHalData->ExternalLNA_5G = 1
[ 4.962044] RTL871X: pHalData->TypeGPA = 0x0
[ 4.962049] RTL871X: pHalData->TypeAPA = 0x0
[ 4.962054] RTL871X: pHalData->TypeGLNA = 0x0
[ 4.962059] RTL871X: pHalData->TypeALNA = 0x0
[ 4.962064] RTL871X: RFE Type: 0x 3
[ 4.962069] RTL871X: PID= 0x17d2, VID= b05
[ 4.962075] RTL871X: PID= 0x17d2, VID= b05
[ 4.962080] RTL871X: Customer ID: 0x23
[ 4.963905] RTL871X: hal_ReadUsbType_8812AU: antenna=2, wmode=3
[ 4.963912] RTL871X: hal_ReadUsbType_8812AU(): EFUSE_HIDDEN_812AU
[ 4.963917] RTL871X: ReadAdapterInfo8812AU <====
[ 4.964044] RTL871X: Hal_ChannelPlanToRegulation ChannelPlan:0x26,Regulation(2_4G/5G):0x00,0x02
[ 4.964053] RTL871X: init_channel_set ChannelPlan ID 26 Chan num:32
[ 4.964878] RTL871X: NR_RECVBUFF: 8
[ 4.964884] RTL871X: MAX_RECVBUF_SZ: 32768
[ 4.964912] RTL871X: NR_PREALLOC_RECV_SKB: 8
[ 4.965128] RTL871X: rtw_alloc_macid(eth%d) if1, hwaddr:ff:ff:ff:ff:ff:ff macid:1
[ 4.965151] RTL871X: rtw_macaddr_cfg mac addr:9c:5c:8e:b2:b5:a9
[ 4.965159] RTL871X: bDriverStopped:1, bSurpriseRemoved:0, bup:0, hw_init_completed:0
[ 4.965180] RTL871X: rtw_ndev_init(wlan0)
[ 4.968078] RTL871X: _rtw_drv_register_netdev, MAC Address (if1) = 9c:5c:8e:b2:b5:a9
[ 4.968170] usbcore: registered new interface driver rtl8812au
[ 4.968178] RTL871X: module init ret=0
[ 5.767280] Adding 686076k swap on /dev/sda5. Priority:-1 extents:1 across:686076k SS
[ 5.813738] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 5.894624] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 5.985554] loop: module loaded
[ 7.872334] RPC: Registered named UNIX socket transport module.
[ 7.872343] RPC: Registered udp transport module.
[ 7.872349] RPC: Registered tcp transport module.
[ 7.872355] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 7.887130] FS-Cache: Loaded
[ 7.901538] FS-Cache: Netfs 'nfs' registered for caching
[ 7.911463] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 9.250465] Bluetooth: Core ver 2.16
[ 9.250508] NET: Registered protocol family 31
[ 9.250513] Bluetooth: HCI device and connection manager initialized
[ 9.250519] Bluetooth: HCI socket layer initialized
[ 9.250525] Bluetooth: L2CAP socket layer initialized
[ 9.250542] Bluetooth: SCO socket layer initialized
[ 9.258289] Bluetooth: RFCOMM TTY layer initialized
[ 9.258303] Bluetooth: RFCOMM socket layer initialized
[ 9.258309] Bluetooth: RFCOMM ver 1.11
[ 9.264291] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.264298] Bluetooth: BNEP filters: protocol multicast
[ 9.425266] r8169 0000:02:00.0: eth0: link down
[ 9.425284] r8169 0000:02:00.0: eth0: link down
[ 9.426576] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.433959] RTL871X: LeaveAllPowerSaveMode(wlan0): bup=0 Skip!
[ 9.433966] RTL871X: rtw_wx_set_scan: bDriverStopped=1, bup=0, hw_init_completed=0
[ 9.435343] RTL871X: +871x_drv - drv_open, bup=0
[ 9.435650] RTL871X: power-on :REG_SYS_CLKR 0x09=0xfc. REG_CR 0x100=0xff.
[ 9.435655] RTL871X: MAC has already power on.
[ 9.438580] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 9.444904] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=1
[ 9.509779] RTL871X: FirmwareDownload8812 fw source from Header
[ 9.509793] RTL871X: FirmwareDownload8812 fw:NIC, size: 31936
[ 9.509801] RTL871X: FirmwareDownload8812: fw_ver=38 fw_subver=0 sig=0x9501
[ 9.553034] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00070705
[ 9.554901] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 9.582907] RTL871X: _FWFreeToGo8812: Polling FW ready OK! (224, 28ms), REG_MCUFWDL:0x000707c6
[ 9.582917] RTL871X: FWDL success. write_fw:1, 72ms
[ 9.582926] RTL871X: rtl8812au_hal_init: Download Firmware Success!!
[ 9.607904] RTL871X: ===> phy_BB8812_Config_ParaFile() EEPROMRegulatory 1
[ 9.929290] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 10.643779] RTL871X: pDM_Odm TxPowerTrackControl = 1
[ 10.645780] RTL871X: MAC Address from REG_MACID = 9c:5c:8e:b2:b5:a9
[ 10.645791] RTL871X: rtl8812au_hal_init in 1212ms
[ 10.646279] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 10.646779] RTL871X: MAC Address = 9c:5c:8e:b2:b5:a9
[ 10.646947] RTL871X: -871x_drv - drv_open, bup=1
[ 10.648055] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.730133] RTL871X: [rtw_wx_set_pmkid] IW_PMKSA_FLUSH!
[ 10.730147] RTL871X: set_mode = IW_MODE_INFRA
[ 10.730225] RTL871X: set bssid:00:00:00:00:00:00
[ 10.730299] RTL871X: =>rtw_wx_set_essid
[ 10.730303] RTL871X: ssid=g\xffffffc6isQ\xffffffffJ\xffffffec)\xffffffcd\xffffffba\xffffffba\xffffffab\xfffffff2\xfffffffb\xffffffe3F|\xffffffc2T\xfffffff8\x1b\xffffffe8\xffffffe7\xffffff8dvZ.c3\xffffff9f\xffffffc9\xffffff9a\xffffff9a, len=32
[ 10.730310] RTL871X: set ssid [g\xffffffc6isQ\xffffffffJ\xffffffec)\xffffffcd\xffffffba\xffffffba\xffffffab\xfffffff2\xfffffffb\xffffffe3F|\xffffffc2T\xfffffff8\x1b\xffffffe8\xffffffe7\xffffff8dvZ.c3\xffffff9f\xffffffc9\xffffff9a\xffffff9a\x13;z\x0f] fw_state=0x00000008
[ 10.730314] RTL871X: Set SSID under fw_state=0x00000008
[ 10.730324] RTL871X: <=rtw_wx_set_essid, ret 0
[ 10.730646] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 10.749151] RTL871X: [rtw_wx_set_pmkid] IW_PMKSA_FLUSH!
[ 11.078158] r8169 0000:02:00.0: eth0: link up
[ 11.079149] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.388784] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 14.787782] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 14.822411] RTL871X: survey done event(3) band:0 for wlan0
[ 14.822432] RTL871X: rtw_select_and_join_from_scanned_queue: return _FAIL(candidate == NULL)
[ 14.822440] RTL871X: try_to_join, but select scanning queue fail, to_roam:0
[ 14.822447] RTL871X: indicate disassoc
[ 14.822605] RTL871X: rtw_indicate_scan_done(wlan0)
[ 14.822715] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(0)
[ 14.822728] RTL871X: beamforming_deinit_entry Idx 0
[ 14.822736] RTL871X: beamforming_notify BeamformState 0 bSounding 0
[ 14.830130] RTL871X: ==>rtw_ps_processor .fw_state(8)
[ 14.830141] RTL871X: ==>ips_enter cnts:1
[ 14.830146] RTL871X: nolinked power save enter
[ 14.830153] RTL871X: ===> rtw_ips_pwr_down...................
[ 14.830160] RTL871X: ====> rtw_ips_dev_unload...
[ 14.841199] RTL871X: usb_read_port_cancel
[ 14.841274] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.841393] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.841517] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.841640] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.841766] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.841892] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.842019] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.842143] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.842155] RTL871X: usb_write_port_cancel
[ 14.842178] RTL871X: ==> rtl8812au_hal_deinit
[ 14.843136] RTL871X: hal_poweroff_8812au
[ 14.847765] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 14.854015] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=0
[ 14.854262] RTL871X: <=== rtw_ips_pwr_down..................... in 24ms
[ 14.922999] RTL871X: _rtw_pwr_wakeup call ips_leave....
[ 14.923009] RTL871X: ==>ips_leave cnts:1
[ 14.923015] RTL871X: ===> rtw_ips_pwr_up..............
[ 14.923026] RTL871X: ===> ips_netdrv_open.........
[ 14.923485] RTL871X: power-on :REG_SYS_CLKR 0x09=0xb0. REG_CR 0x100=0xea.
[ 14.923493] RTL871X: MAC has not been powered on yet.
[ 14.929407] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=1
[ 14.993781] RTL871X: FirmwareDownload8812 fw source from Header
[ 14.993790] RTL871X: FirmwareDownload8812 fw:NIC, size: 31936
[ 14.993798] RTL871X: FirmwareDownload8812: fw_ver=38 fw_subver=0 sig=0x9501
[ 15.037657] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00070705
[ 15.039526] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 15.067646] RTL871X: _FWFreeToGo8812: Polling FW ready OK! (219, 28ms), REG_MCUFWDL:0x000707c6
[ 15.067651] RTL871X: FWDL success. write_fw:1, 72ms
[ 15.067656] RTL871X: rtl8812au_hal_init: Download Firmware Success!!
[ 15.092893] RTL871X: ===> phy_BB8812_Config_ParaFile() EEPROMRegulatory 1
[ 15.412285] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 16.129410] RTL871X: pDM_Odm TxPowerTrackControl = 1
[ 16.131405] RTL871X: MAC Address from REG_MACID = 9c:5c:8e:b2:b5:a9
[ 16.131414] RTL871X: rtl8812au_hal_init in 1208ms
[ 16.131903] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 16.132438] RTL871X: <=== rtw_ips_pwr_up.............. in 1208ms
[ 16.132445] RTL871X: nolinked power save leave
[ 16.132530] RTL871X: ==> ips_leave.....LED(0x00028228)...
[ 16.132539] RTL871X: IW_SCAN_THIS_ESSID, ssid=Shadownetwork 2.4Ghz, len=20
[ 17.784899] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 20.187278] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 20.221897] RTL871X: survey done event(4) band:0 for wlan0
[ 20.221912] RTL871X: rtw_indicate_scan_done(wlan0)
[ 20.222346] RTL871X: wpa_set_auth_algs, AUTH_ALG_OPEN_SYSTEM
[ 20.222354] RTL871X: set_mode = IW_MODE_INFRA
[ 20.222381] RTL871X:
[ 20.222382] wpa_ie(length:22):
[ 20.222387] RTL871X: 0x30 0x14 0x01 0x00 0x00 0x0f 0xac 0x04
[ 20.222392] RTL871X: 0x01 0x00 0x00 0x0f 0xac 0x04 0x01 0x00
[ 20.222396] RTL871X: 0x00 0x0f 0xac 0x02 0x00 0x00 0x00 0x00
[ 20.222897] RTL871X: SetHwReg8812A, 5710, RCR= f40060ca
[ 20.223019] RTL871X: rtw_wx_set_freq: set to channel 10
[ 20.223046] RTL871X: =>rtw_wx_set_essid
[ 20.223050] RTL871X: ssid=Shadownetwork 2.4Ghz, len=20
[ 20.223059] RTL871X: set ssid [Shadownetwork 2.4Ghz] fw_state=0x00000008
[ 20.223063] RTL871X: Set SSID under fw_state=0x00000008
[ 20.223071] RTL871X: [by_bssid:0][assoc_ssid:Shadownetwork 2.4Ghz][to_roam:0] new candidate: Shadownetwork 2.4Ghz(08:60:6e:be:f2:60, ch10) rssi:-56
[ 20.223077] RTL871X: rtw_select_and_join_from_scanned_queue: candidate: Shadownetwork 2.4Ghz(08:60:6e:be:f2:60, ch:10)
[ 20.223085] RTL871X: link to Broadcom AP
[ 20.223092] RTL871X: [HT] HAL Support STBC = 0x01
[ 20.223096] RTL871X: [HT] Declare supporting RX STBC_2R
[ 20.223101] RTL871X: [VHT] Support STBC = 0x03
[ 20.223105] RTL871X: [VHT] Support Beamformee
[ 20.223111] RTL871X: <=rtw_wx_set_essid, ret 0
[ 20.223137] RTL871X: set bssid:08:60:6e:be:f2:60
[ 20.223140] RTL871X: Set BSSID under fw_state=0x00000088
[ 20.223290] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 20.223906] RTL871X: start_join_set_ch_bw: ch=10, bwmode=0, ch_offset=0
[ 20.463228] RTL871X: OnBeacon: beacon keys ready
[ 20.463238] RTL871X: link to Broadcom AP
[ 20.463242] RTL871X: start auth
[ 20.463249] RTL871X: issue_auth
[ 20.466074] RTL871X: OnAuthClient
[ 20.466079] RTL871X: auth success, start assoc
[ 20.466091] RTL871X: network.SupportedRates[0]=82
[ 20.466094] RTL871X: network.SupportedRates[1]=84
[ 20.466097] RTL871X: network.SupportedRates[2]=8B
[ 20.466100] RTL871X: network.SupportedRates[3]=96
[ 20.466103] RTL871X: network.SupportedRates[4]=24
[ 20.466106] RTL871X: network.SupportedRates[5]=30
[ 20.466109] RTL871X: network.SupportedRates[6]=48
[ 20.466112] RTL871X: network.SupportedRates[7]=6C
[ 20.466115] RTL871X: network.SupportedRates[8]=0C
[ 20.466118] RTL871X: network.SupportedRates[9]=12
[ 20.466121] RTL871X: network.SupportedRates[10]=18
[ 20.466124] RTL871X: network.SupportedRates[11]=60
[ 20.466127] RTL871X: bssrate_len = 12
[ 20.470705] RTL871X: OnAssocRsp
[ 20.470719] RTL871X: report_join_res(8)
[ 20.470724] RTL871X: rtw_joinbss_update_network
[ 20.470729] RTL871X: +rtw_update_ht_cap()
[ 20.470741] RTL871X: rtw_alloc_macid(wlan0) if1, hwaddr:08:60:6e:be:f2:60 macid:0
[ 20.470745] RTL871X: rtw_joinbss_update_stainfo
[ 20.470752] RTL871X: supp_mcs_set = ff, ff, 00, rf_type=2, tx_ra_bitmap=000000000fffffff
[ 20.470756] RTL871X: ### Set STA_(0) info ###
[ 20.470763] RTL871X: assoc success
[ 20.471377] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 20.471522] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 20.472523] RTL871X: WMM(0): 0, a42b
[ 20.472644] RTL871X: WMM(1): 0, a44f
[ 20.472949] RTL871X: WMM(2): 0, 5e4322
[ 20.473159] RTL871X: WMM(3): 0, 2f3222
[ 20.473164] RTL871X: wmm_para_seq(0): 0
[ 20.473167] RTL871X: wmm_para_seq(1): 1
[ 20.473170] RTL871X: wmm_para_seq(2): 2
[ 20.473173] RTL871X: wmm_para_seq(3): 3
[ 20.473176] RTL871X: HTOnAssocRsp
[ 20.473271] RTL871X: VHTOnAssocRsp
[ 20.473281] RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x00, WirelessMode:0x0b, rate_bitmap:0x0f8ff005
[ 20.473286] RTL871X: UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x0fffffff
[ 20.473288] ==> rssi_level:0, rate_bitmap:0x0f8ff005, psta->raid=2
[ 20.474399] RTL871X: [MacId], Set MacId Ctrl(original) = 0x10000
[ 20.475521] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 20.476663] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(1)
[ 20.477897] RTL871X: rtw_hal_set_fw_rsvd_page PageSize: 512, RsvdPageNUm: 7
[ 20.477906] RTL871X: LocPsPoll: 2
[ 20.477910] RTL871X: LocNullData: 3
[ 20.477914] RTL871X: LocQosNull: 4
[ 20.478144] RTL871X: rtw_hal_set_fw_rsvd_page: Set RSVD page location to Fw ,TotalPacketLen(2634), TotalPageNum(5)
[ 20.478149] RTL871X: RsvdPageLoc: ProbeRsp=0 PsPoll=2 Null=3 QoSNull=4 BTNull=0
[ 20.478193] RTL871X: OnAction_back
[ 20.478198] RTL871X: OnAction_back, action=0
[ 20.478213] RTL871X: issue_addba_rsp(wlan0) ra=08:60:6e:be:f2:60 status=0, tid=0, size=64
[ 20.479142] RTL871X: wlan0: 1 DL RSVD page success! DLBcnCount:1, poll:1
[ 20.479889] RTL871X: Set RSVD page location to Fw.
[ 20.480049] RTL871X: =>mlmeext_joinbss_event_callback
[ 20.480065] RTL871X: recv eapol packet
[ 20.482167] RTL871X: send eapol packet
[ 20.489207] RTL871X: recv eapol packet
[ 20.489398] RTL871X: send eapol packet
[ 20.489438] RTL871X: ~~~~set sta key:unicastkey
[ 20.489543] RTL871X: ~~~~set sta key:groupkey
[ 20.489549] RTL871X: ==> rtw_set_key algorithm(4),keyid(2),key_mask(0)
[ 20.491467] RTL871X: set pairwise key camid:4, addr:08:60:6e:be:f2:60, kid:0, type:AES
[ 20.494520] RTL871X: set group key camid:5, addr:08:60:6e:be:f2:60, kid:2, type:AES
[ 20.497246] RTL871X: SetHwReg8812A, 5703, RCR= f40060ce
[ 21.116584] eth0: no IPv6 routers present
[ 22.232653] RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x02, WirelessMode:0x0b, rate_bitmap:0x0f8ff000
[ 22.232660] RTL871X: UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x0fffffff
[ 22.232662] ==> rssi_level:2, rate_bitmap:0x0f8ff000, psta->raid=2
[ 24.067077] RTL871X: rtw_issue_addbareq_cmd, p=0
[ 24.067127] RTL871X: BA_starting_seqctrl = 132 for TID=0
[ 24.067162] RTL871X: issue_addba_req(wlan0) ra=08:60:6e:be:f2:60 tid=0
[ 24.074885] RTL871X: OnAction_back
[ 24.074892] RTL871X: OnAction_back, action=1
[ 24.074895] RTL871X: agg_enable for TID=0
[ 31.336861] wlan0: no IPv6 routers present
[ 32.155614] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 33.906285] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 34.258287] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 34.290907] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 36.265905] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 36.298663] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 36.366913] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 36.402663] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 36.405035] RTL871X: survey done event(7) band:0 for wlan0
[ 36.405129] RTL871X: rtw_indicate_scan_done(wlan0)
[ 44.273706] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 44.277343] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 48.281772] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 48.281785] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 50.285847] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 50.285861] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 72.155200] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 72.155214] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 72.157541] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 73.937660] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 74.352037] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 74.386037] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 76.340662] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 76.376042] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 76.383285] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 76.415535] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 76.449161] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 76.451158] RTL871X: survey done event(4) band:0 for wlan0
[ 76.451268] RTL871X: rtw_indicate_scan_done(wlan0)
[ 80.345576] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 80.345590] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 84.353046] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 84.353059] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 88.363392] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 88.363407] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 89.981873] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 132.154779] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 132.154793] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 132.159947] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 133.948028] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 134.474907] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 134.507779] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 136.315153] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 136.348900] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 136.351152] RTL871X: survey done event(2) band:0 for wlan0
[ 136.351207] RTL871X: rtw_indicate_scan_done(wlan0)
[ 136.456789] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 136.456798] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 140.469772] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 140.469786] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 142.475051] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 142.475065] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 166.521958] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 174.537878] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 174.537891] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 178.547644] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 178.547658] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 180.549550] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 180.549564] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 182.554492] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 182.554506] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 198.586169] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 212.157511] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 212.157525] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 212.160543] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 213.903161] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 214.620540] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 214.653158] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 216.353659] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 216.387160] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 216.389660] RTL871X: survey done event(4) band:0 for wlan0
[ 216.389721] RTL871X: rtw_indicate_scan_done(wlan0)
[ 216.624122] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 216.628649] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 216.628661] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 232.654020] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 238.697044] RTL871X: issue_probereq_ex(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 32 ms
[ 238.697218] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 252.718816] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 254.717721] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 256.721041] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 258.732702] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 259.468476] RTL871X: not match packet_index=1, install_index=2
[ 259.532793] RTL871X: recv eapol packet
[ 259.533168] RTL871X: ~~~~set sta key:groupkey
[ 259.533180] RTL871X: ==> rtw_set_key algorithm(4),keyid(1),key_mask(0)
[ 259.533250] RTL871X: send eapol packet
[ 259.536657] RTL871X: set group key camid:6, addr:08:60:6e:be:f2:60, kid:1, type:AES
[ 259.537251] RTL871X: SetHwReg8812A, 5703, RCR= f40760ce
[ 260.391192] RTL871X: OnDeAuth(wlan0) reason=16, ta=08:60:6e:be:f2:60, ignore=0
[ 260.391201] RTL871X: receive_disconnect
[ 260.391213] RTL871X: report_del_sta_event: delete STA, mac_id=0
[ 260.391308] RTL871X: rtw_stadel_event_callback(mac_id=0)=08:60:6e:be:f2:60
[ 260.391318] RTL871X: [MacId], Set MacId Ctrl(original) = 0x0
[ 260.393993] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 260.397827] RTL871X: ### Clean STA_(0) info ###
[ 260.397839] RTL871X: free disconnecting network
[ 260.397857] RTL871X: indicate disassoc
[ 260.397916] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_DISCONNECT
[ 260.397925] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 260.399405] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(0)
[ 260.399418] RTL871X: beamforming_deinit_entry Idx 0
[ 260.399426] RTL871X: beamforming_notify BeamformState 0 bSounding 0
[ 262.229535] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 264.671785] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 264.705784] RTL871X: survey done event(2) band:0 for wlan0
[ 264.705804] RTL871X: rtw_indicate_scan_done(wlan0)
[ 264.706436] RTL871X: wpa_set_auth_algs, AUTH_ALG_OPEN_SYSTEM
[ 264.706450] RTL871X: set_mode = IW_MODE_INFRA
[ 264.706490] RTL871X:
[ 264.706492] wpa_ie(length:22):
[ 264.706500] RTL871X: 0x30 0x14 0x01 0x00 0x00 0x0f 0xac 0x04
[ 264.706507] RTL871X: 0x01 0x00 0x00 0x0f 0xac 0x04 0x01 0x00
[ 264.706514] RTL871X: 0x00 0x0f 0xac 0x02 0x00 0x00 0x00 0x00
[ 264.707539] RTL871X: SetHwReg8812A, 5710, RCR= f40060ca
[ 264.707700] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 264.707723] RTL871X: rtw_wx_set_freq: set to channel 10
[ 264.707755] RTL871X: =>rtw_wx_set_essid
[ 264.707762] RTL871X: ssid=Shadownetwork 2.4Ghz, len=20
[ 264.707776] RTL871X: set ssid [Shadownetwork 2.4Ghz] fw_state=0x00000008
[ 264.707782] RTL871X: Set SSID under fw_state=0x00000008
[ 264.707795] RTL871X: [by_bssid:0][assoc_ssid:Shadownetwork 2.4Ghz][to_roam:0] new candidate: Shadownetwork 2.4Ghz(08:60:6e:be:f2:60, ch10) rssi:-58
[ 264.707805] RTL871X: rtw_select_and_join_from_scanned_queue: candidate: Shadownetwork 2.4Ghz(08:60:6e:be:f2:60, ch:10)
[ 264.707818] RTL871X: link to Broadcom AP
[ 264.707827] RTL871X: [HT] HAL Support STBC = 0x01
[ 264.707834] RTL871X: [HT] Declare supporting RX STBC_2R
[ 264.707841] RTL871X: [VHT] Support STBC = 0x03
[ 264.707846] RTL871X: [VHT] Support Beamformee
[ 264.707857] RTL871X: <=rtw_wx_set_essid, ret 0
[ 264.707899] RTL871X: set bssid:08:60:6e:be:f2:60
[ 264.707906] RTL871X: Set BSSID under fw_state=0x00000088
[ 264.708562] RTL871X: start_join_set_ch_bw: ch=10, bwmode=0, ch_offset=0
[ 265.098741] RTL871X: OnBeacon: beacon keys ready
[ 265.098760] RTL871X: link to Broadcom AP
[ 265.098768] RTL871X: start auth
[ 265.098778] RTL871X: issue_auth
[ 265.102008] RTL871X: OnAuthClient
[ 265.102016] RTL871X: auth success, start assoc
[ 265.102030] RTL871X: network.SupportedRates[0]=82
[ 265.102036] RTL871X: network.SupportedRates[1]=84
[ 265.102041] RTL871X: network.SupportedRates[2]=8B
[ 265.102047] RTL871X: network.SupportedRates[3]=96
[ 265.102052] RTL871X: network.SupportedRates[4]=24
[ 265.102058] RTL871X: network.SupportedRates[5]=30
[ 265.102063] RTL871X: network.SupportedRates[6]=48
[ 265.102069] RTL871X: network.SupportedRates[7]=6C
[ 265.102074] RTL871X: network.SupportedRates[8]=0C
[ 265.102080] RTL871X: network.SupportedRates[9]=12
[ 265.102085] RTL871X: network.SupportedRates[10]=18
[ 265.102091] RTL871X: network.SupportedRates[11]=60
[ 265.102097] RTL871X: bssrate_len = 12
[ 265.103754] RTL871X: OnAuthClient
[ 265.106385] RTL871X: OnAuthClient
[ 265.114637] RTL871X: OnAssocRsp
[ 265.114655] RTL871X: report_join_res(8)
[ 265.114664] RTL871X: rtw_joinbss_update_network
[ 265.114672] RTL871X: +rtw_update_ht_cap()
[ 265.114690] RTL871X: rtw_alloc_macid(wlan0) if1, hwaddr:08:60:6e:be:f2:60 macid:0
[ 265.114696] RTL871X: rtw_joinbss_update_stainfo
[ 265.114732] RTL871X: supp_mcs_set = ff, ff, 00, rf_type=2, tx_ra_bitmap=000000000fffffff
[ 265.114740] RTL871X: ### Set STA_(0) info ###
[ 265.114751] RTL871X: assoc success
[ 265.114813] RTL871X: OnAction_back
[ 265.114820] RTL871X: OnAction_back, action=0
[ 265.114842] RTL871X: issue_addba_rsp(wlan0) ra=08:60:6e:be:f2:60 status=0, tid=0, size=64
[ 265.114868] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 265.115899] RTL871X: WMM(0): 0, a42b
[ 265.116021] RTL871X: WMM(1): 0, a44f
[ 265.116153] RTL871X: WMM(2): 0, 5e4322
[ 265.116791] RTL871X: WMM(3): 0, 2f3222
[ 265.116799] RTL871X: wmm_para_seq(0): 0
[ 265.116805] RTL871X: wmm_para_seq(1): 1
[ 265.116811] RTL871X: wmm_para_seq(2): 2
[ 265.116819] RTL871X: wmm_para_seq(3): 3
[ 265.116825] RTL871X: HTOnAssocRsp
[ 265.117153] RTL871X: VHTOnAssocRsp
[ 265.117168] RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x00, WirelessMode:0x0b, rate_bitmap:0x0f8ff005
[ 265.117178] RTL871X: UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x0fffffff
[ 265.117181] ==> rssi_level:0, rate_bitmap:0x0f8ff005, psta->raid=2
[ 265.120114] RTL871X: [MacId], Set MacId Ctrl(original) = 0x10000
[ 265.121660] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 265.123156] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(1)
[ 265.124280] RTL871X: rtw_hal_set_fw_rsvd_page PageSize: 512, RsvdPageNUm: 7
[ 265.124292] RTL871X: LocPsPoll: 2
[ 265.124298] RTL871X: LocNullData: 3
[ 265.124304] RTL871X: LocQosNull: 4
[ 265.124531] RTL871X: rtw_hal_set_fw_rsvd_page: Set RSVD page location to Fw ,TotalPacketLen(2634), TotalPageNum(5)
[ 265.124542] RTL871X: RsvdPageLoc: ProbeRsp=0 PsPoll=2 Null=3 QoSNull=4 BTNull=0
[ 265.125532] RTL871X: wlan0: 1 DL RSVD page success! DLBcnCount:1, poll:1
[ 265.126278] RTL871X: Set RSVD page location to Fw.
[ 265.126403] RTL871X: =>mlmeext_joinbss_event_callback
[ 265.130080] RTL871X: recv eapol packet
[ 265.132541] RTL871X: send eapol packet
[ 265.150708] RTL871X: recv eapol packet
[ 265.150939] RTL871X: send eapol packet
[ 265.150993] RTL871X: ~~~~set sta key:unicastkey
[ 265.151072] RTL871X: set pairwise key camid:4, addr:08:60:6e:be:f2:60, kid:0, type:AES
[ 265.151140] RTL871X: ~~~~set sta key:groupkey
[ 265.151150] RTL871X: ==> rtw_set_key algorithm(4),keyid(1),key_mask(0)
[ 265.154660] RTL871X: set group key camid:5, addr:08:60:6e:be:f2:60, kid:1, type:AES
[ 265.155026] RTL871X: SetHwReg8812A, 5703, RCR= f40060ce
[ 266.716533] RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x02, WirelessMode:0x0b, rate_bitmap:0x0f8ff000
[ 266.716541] RTL871X: UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x0fffffff
[ 266.716543] ==> rssi_level:2, rate_bitmap:0x0f8ff000, psta->raid=2
[ 274.728978] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 274.728992] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 284.750474] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 284.750483] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 288.757273] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 288.757287] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 292.765919] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 292.765933] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 298.777930] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 298.777945] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 300.781237] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 300.781251] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 304.790004] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 304.790019] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 308.828453] RTL871X: issue_probereq_ex(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 32 ms
[ 308.828831] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 312.153530] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 312.153540] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 312.158146] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 313.984660] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 314.814035] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 314.848034] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 316.403534] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 316.438399] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 316.440902] RTL871X: survey done event(1) band:0 for wlan0
[ 316.440951] RTL871X: rtw_indicate_scan_done(wlan0)
[ 316.813099] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 316.813116] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 336.853989] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 352.886160] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 368.918123] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 384.950276] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 400.982142] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 417.014125] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 432.155154] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 432.155167] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 432.161422] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 433.881288] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 435.056659] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 435.089282] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 436.292907] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 436.326783] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 436.328911] RTL871X: survey done event(4) band:0 for wlan0
[ 436.328931] RTL871X: rtw_indicate_scan_done(wlan0)
[ 437.053428] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 437.053442] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 447.074034] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 463.106107] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 479.138422] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 495.173854] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 511.206080] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 551.286462] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 552.155139] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 552.155153] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 552.157811] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 553.881284] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 555.308910] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 555.341533] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 556.285032] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 556.318787] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 556.321410] RTL871X: survey done event(8) band:0 for wlan0
[ 556.321431] RTL871X: rtw_indicate_scan_done(wlan0)
[ 557.297796] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 557.297810] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 567.317590] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 583.350096] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 599.382104] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 615.414192] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 647.478216] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 663.644885] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 663.644900] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 665.513799] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 665.513813] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 672.153352] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 672.153365] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 672.156360] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 673.876293] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 675.558413] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 675.590162] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 675.597410] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 676.292163] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 676.325660] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 676.327659] RTL871X: survey done event(6) band:0 for wlan0
[ 676.327679] RTL871X: rtw_indicate_scan_done(wlan0)
[ 677.537660] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 677.537675] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 691.566095] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 707.597968] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 723.630047] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 745.674005] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 761.706024] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 777.738214] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 792.154195] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 792.154208] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 792.156437] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 793.803914] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 793.876663] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 795.776665] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 795.809410] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 796.349039] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 796.382536] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 796.384912] RTL871X: survey done event(6) band:0 for wlan0
[ 796.384932] RTL871X: rtw_indicate_scan_done(wlan0)
[ 797.777644] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 797.777658] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 809.801980] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 825.833866] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 847.878017] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 863.909839] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 879.942169] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 895.974088] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 912.005952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 912.154731] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 912.154743] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 912.158325] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 913.276694] RTL871X: Drop duplicate management frame with seq_num = 1187.
[ 913.280444] RTL871X: Drop duplicate management frame with seq_num = 1187.
[ 913.876179] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 914.031913] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 914.064535] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 916.017040] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 916.049911] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 916.337539] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 916.371410] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 916.373537] RTL871X: survey done event(8) band:0 for wlan0
[ 916.373558] RTL871X: rtw_indicate_scan_done(wlan0)
[ 918.017645] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 918.017659] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 928.037793] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 946.073667] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 962.106371] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 978.138020] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 994.169843] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1010.201655] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1026.233694] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1032.154563] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1032.154576] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1032.158704] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1033.884535] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1034.252411] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1034.285287] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1036.255161] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1036.287038] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1036.294282] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1036.352410] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1036.385911] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1036.388157] RTL871X: survey done event(9) band:0 for wlan0
[ 1036.388178] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1038.257877] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1038.257892] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1050.280669] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1050.280682] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1052.038641] RTL871X: rtw_issue_addbareq_cmd, p=0
[ 1052.038739] RTL871X: BA_starting_seqctrl = 319 for TID=0
[ 1052.038769] RTL871X: issue_addba_req(wlan0) ra=08:60:6e:be:f2:60 tid=0
[ 1052.042076] RTL871X: OnAction_back
[ 1052.042086] RTL871X: OnAction_back, action=1
[ 1052.042092] RTL871X: agg_enable for TID=0
[ 1056.293459] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1056.293474] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1058.296643] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1058.296652] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1062.305361] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1062.305375] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1064.308611] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1064.308625] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1066.313499] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1066.313514] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1082.345711] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1098.377733] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1114.410176] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000Br Victor
- Thank you received: 4656
30 Oct 2018 15:36 #119664
Replied by andypugh on topic G76, Troubleshooting needed!
Turn twopass off. And have only _one_ loadrt lowpass in the main HAL file. (both names on the same line, ie
loadrt lowpass names=lowpass.spindle,lowpass.0
The following user(s) said Thank You: Victor
Time to create page: 0.382 seconds
