G76, Troubleshooting needed!
- Victor
08 Nov 2018 09:05 #120270
by Victor
Replied by Victor on topic G76, Troubleshooting needed!
Hi Andy,
Ok, and when we say counts per rev do we mean 2048ppr=2048 counts? or should i make that 4x due to the quadrature? = 2048x4=8192?
If ok i will go with a 2048ppr encoder.
Well i have tried to do as much reading as possible on the subject and i have noticed that line-driver is recommended. And the encoder i suggested do use line-driver if i'm not mistaken?
Br Victor
Br Victor
- Thank you received: 4656
08 Nov 2018 09:22 #120272
In this case it doesn't matter if the 2048 count is 2048 pulses our 8192 pusles, it's still comfortably under the 2Mhz count rate. (and with the filter off I think you can have 10MHz)
Replied by andypugh on topic G76, Troubleshooting needed!
I was deliberately ducking that question. The limit is in counts per second, 4 x slots, but it can be hard to tell whether a given encoder is using slots or counts in the spec.Ok, and when we say counts per rev do we mean 2048ppr=2048 counts? or should i make that 4x due to the quadrature? = 2048x4=8192?
It is. But is also seems to have UVW commutation outputs (which you don't need) and is in a somewhat inconvenient package.Well i have tried to do as much reading as possible on the subject and i have noticed that line-driver is recommended. And the encoder i suggested do use line-driver if i'm not mistaken?
Time to create page: 0.096 seconds
