Gcode went wrong
- mane
7 years 10 months ago - 7 years 10 months ago #122958
by mane
Replied by mane on topic Gcode went wrong
With XY move directly after G41 the program works without failure. Is this a bug?
Thanks.
Thanks.
G21 G17 G40 G49 G61 G90 G54
F56
G0 Z5
G0 X-20 Y-20
G1 Z1
G41 X-15 Y-15 D10
G1 X0.5 Y0.5
G1 X0.5 Y24.5
G1 X56.5 Y24.5
G1 X56.5 Y0.5
G1 X0.5 Y0.5
M30
Last edit: 7 years 10 months ago by mane. Reason: spelling corrected
- mane
7 years 9 months ago #123405
by mane
I tried to start the g-code several times but something is wrong.
I use the AXIS GUI and followed this sequence described in the documentation under 4.1.2.1
After homing the axes and loading the g-code i touch off the workpiece in x,y,z each 0.000 mm with G54
Then i run the program line by line. But at line "G41 X0 D10" there is an offset of about 5mm as shown in the picture.
G17 G21 G40 G61 G54 F200
#1 = 56
#2 = 24
G0 Z3
G0 X-20 Y-20
G0 Z-5
G41 X0 D10
- MaHa
- Thank you received: 241
7 years 9 months ago #123421
by MaHa
Replied by MaHa on topic Gcode went wrong
If your touch off tool has radius greater 0 . Then this radius must be entered on touch off. Tool centerpoint should be on X0 Y0. Retract Z, G0 G54 X0 Y0 to check. After your cutter compensation is applied. If you don't want toolchange M6, maybe at least load Tool M61 Q10. Then this tooldata will be respected, using G43, G41, G42. Possibly reducing source for faults.
- mane
7 years 9 months ago #123465
by mane
Thanks a lot. Now its working.
Time to create page: 1.235 seconds
