Can't get lathe to Feed
5 years 2 months ago #217953 by rider-83
Replied by rider-83 on topic Can't get lathe to Feed
My thoughts were to blank out two teeth with epoxy, but I'm unsure how to set up this 'missing-teeth'. Is this only available to ver2.9 ?
5 years 2 months ago #217962 by andypugh
Replied by andypugh on topic Can't get lathe to Feed
I think that I would start with tape if it is an optical sensor. If it is inductive then neither tape nor epoxy will work.
Missing-tooth index is, indeed, only available with 2.9. (though it would work with 2.8 if you compiled it for 2.8)
Setup is as simple as connecting just channel-A and using a "setp" in the HAL file to set the number of missing teeth.
The following user(s) said Thank You: HalaszAttila
5 years 2 months ago #217964 by rider-83
Tape is a good idea. Ta.
5 years 2 months ago #218083 by rider-83
Does this look correct?
Swap:
net pulse-index-combined parport.1.pin-10-in encoder.0.phase-A encoder.0.phase-Z
for
setp encoder.0.missing-teeth 2
5 years 2 months ago #218095 by andypugh
Yes, looks right.
5 years 2 months ago #218325 by rider-83
parameter or pin'encoder.0.missing-teeth 2' not found
Hmmm, I think I've done something wrong
Time to create page: 0.202 seconds
