Can't get lathe to Feed
5 years 2 months ago #217149 by rider-83
Replied by rider-83 on topic Can't get lathe to Feed
I should very much like to contact the person who has successfully converted this Boxford machine to work with LinuxCNC. It would save me a whole world of frustration.
5 years 2 months ago #217150 by PCW
Replied by PCW on topic Can't get lathe to Feed
# set the HAL encoder to 100 pulses per revolution.
setp encoder.3.position-scale 100
#set the HAL encoder count mode
setp encoder.0.counter-mode 1
# connect the HAL encoder outputs to LinuxCNC.
net spindle-position encoder.0.position-interpolated => spindle.0.revs
net spindle-velocity encoder.0.velocity => spindle.0.speed-in
net spindle-index-enable encoder.0.index-enable <=> spindle.0.index-enable
#Connect HAL Encoder to Parallel Port
net pulse-index-combined parport.1.pin-10-in encoder.0.phase-A encoder.0.phase-Z
A couple mistakes here
1. You cannot use a combined index-Z/A unless you have 1 count per turn
(index must be 1 count/turn)
2. You are using encoder.0.velocity (which is scaled in RPS) rather than encoder.0.velocity-rpm
5 years 2 months ago #217218 by rider-83
I'm not sure what my solution is here:
5 years 2 months ago #217229 by rider-83
Just out of interest, is it possible to use a sensor wheel with only 'one' slot and set the scale to '1'. I'm only asking out of curiosity
5 years 2 months ago #217232 by PCW
Free up a  parallel port input and add an index sensor would be one way.
5 years 2 months ago #217233 by PCW
Yes, of course this cannot compensate for speed variations during the turn so works better at higher speeds and constant loads
Time to create page: 0.270 seconds
