Can't get lathe to Feed
5 years 5 months ago #207798 by Clive S
Replied by Clive S on topic Can't get lathe to Feed
rider-83 wrote: Hey Andy,
I'm teaching you to suck eggs here!.
I've just looked at the HAL carousel componet (Which I never knew existed)
and its been written by a guy called Andy Pugh. Thats a coincidence, because thats your name as well !
If this helps:- Boxford 125 PPort no sensors on the turret With help from Andy and Aciera
forum.linuxcnc.org/49-basic-configuratio...home?start=70#192352
5 years 5 months ago #207800 by andypugh
Replied by andypugh on topic Can't get lathe to Feed
Yes, looking through a previous thread it seems that the carousel component isn't particularly useful for the Boxford TCL. However there is an existing component for the job.
forum.linuxcnc.org/38-general-linuxcnc-q...etup?start=10#178963
I suggest reading from that point, and then stop when someone starts talking about sensors in his toolchanger, as that's a thread shift to a different changer.
5 years 4 months ago #213216 by rider-83
Replied by rider-83 on topic Can't get lathe to Feed
I've been away from the project for a short while wilst I dealt with something else.
I have the encoder set up on the lathe and have performed a simple test for signals using the LPT port tester, and it is working correctly.
However, before I continue I need to set up the spindle speed control and will need some guidance understanding PWM. I will start a new thread on this topic before returning to this one in order to continue.
5 years 3 months ago #213875 by rider-83
I've added the below section to my .HAL file but get the message:
encoder.0.update-counters base-thread NOT FOUND
I'm getting a little snow blind here, can anyone point out my error?
# SPINDLE ENCODER SYNCHRONISATION #
#Add Encoder detail
loadrt encoder
addf encoder.0.update-counters base-thread
addf encoder.0.capture-position servo-thread
# set the HAL encoder to 100 pulses per revolution.
setp encoder.3.position-scale 100
#set the HAL encoder count mode
setp encoder.0.counter-mode 1
# connect the HAL encoder outputs to LinuxCNC.
net spindle-position encoder.0.position-interpolated => spindle.0.revs
net spindle-velocity encoder.0.velocity => spindle.0.speed-in
net spindle-index-enable encoder.0.index-enable <=> spindle.0.index-enable
#Connect HAL Encoder to Parallel Port
net pulse-index-combined parport.1.pin-10-in encoder.0.phase-A encoder.0.phase-Z
#SPINDLE AT SPEED DETAIL
# load a near component and attach it to a thread
loadrt near
addf near.0 servo-thread
# connect one input to the commanded spindle speed
net spindle-cmd => near.0.in1
# connect one input to the encoder-measured spindle speed
net spindle-velocity => near.0.in2
# connect the output to the spindle-at-speed input
net spindle-at-speed spindle.0.at-speed <= near.0.out
# set the spindle speed inputs to agree if within 1%
setp near.0.scale 1.01
5 years 3 months ago #213876 by andypugh
It appears that there is only one "encoder" module which updates all its channels at the same time.
So change encoder.0.update-counters to encoder.update-counters (and the same for capture-position)
5 years 3 months ago #213877 by rider-83
Thanks Andy, I'll give it a try but it will be later or tomorrow now. I was actually looking at the '0' and wondering if that was the issue but I didn't want to mess with it until I was sure.
Time to create page: 0.363 seconds
