Can't get lathe to Feed
5 years 3 months ago - 5 years 3 months ago #213977 by rider-83
Replied by rider-83 on topic Can't get lathe to Feed
OK, so I've done the change, but now I get:
parameter or pin encoder.3.position-scale not found
Last edit: 5 years 3 months ago by rider-83.
5 years 3 months ago #213978 by robertspark
Replied by robertspark on topic Can't get lathe to Feed
you need to define the position scale and add it to your ini file
linuxcnc.org/docs/2.8/html/man/man9/encoder.9.html
5 years 3 months ago #213979 by rider-83
Sorry, I don't understand :(
5 years 3 months ago #213980 by andypugh
Replied by andypugh on topic Can't get lathe to Feed
You only have one encoder, encoder.0. That is because you had "loadrt encoder" which defaults to a single channel.
So you will not have any HAL pins including encoder.3
How many encoders do you need?
5 years 3 months ago #213981 by rider-83
Andy, I've got lost in my own threads. This is the project (Boxford) were you recommended a sensor from RS and I wired it to one input pin ( '10' on my 2nd LPT ) . We then combined the two signals (A & Z) to this pin.
If I remember correctly I think you guided me to some script were I could past it into my .HAL
5 years 3 months ago #213982 by andypugh
Can you attach your current HAL?
Time to create page: 0.420 seconds
