Can't get lathe to Feed
5 years 6 months ago #207085 by andypugh
Replied by andypugh on topic Can't get lathe to Feed
A CNC lathe without threading is a very limited lathe, though.
5 years 6 months ago #207088 by rider-83
Replied by rider-83 on topic Can't get lathe to Feed
You are making me feel bad
5 years 6 months ago #207091 by andypugh
If you can find even one pin for a single pulse per rev (drive A and Z from one pin), then you can get threading working without much effort.
2 pins would be better (separate A and Z) though.
5 years 6 months ago #207125 by PCW
Replied by PCW on topic Can't get lathe to Feed
Theoretically you could get 2 PPR with 1 A+Z pin (and a 1/2 disk encoder wheel)
if the encoder component could be taught to count rising and falling edges of A
5 years 6 months ago #207126 by andypugh
PCW wrote: Theoretically you could get 2 PPR with 1 A+Z pin (and a 1/2 disk encoder wheel)
To stray off the subject of this thread, we could also look at doing what the car industry do, and using a missing-pulse for index.
There are even systems that give position, index and direction on a single line, by changing the duty cycle of the square wave to indicate direction.
5 years 6 months ago #207129 by PCW
There are also some of the magnetic encoders that use PWM for absolute 1 turn data
Time to create page: 0.263 seconds
