Can't get lathe to Feed
5 years 6 months ago #207013 by andypugh
Replied by andypugh on topic Can't get lathe to Feed
This shouldn't be necesssary:
github.com/LinuxCNC/linuxcnc/blob/43ac97...motion/motion.c#L599
The pin defaults to true if not connected.
So it is probably a misconfigured HAL file. Can you attach the HAL file?
5 years 6 months ago #207014 by andypugh
rider-83 wrote: If I type G18 in MDI it changes as required. But as soon as I press Cycle Start in Auto, we are back to G17 !
The program will run in G18. The status shows the interpreter status, and this runs ahead of the actual execution.
The reason that it goes back to G17 is the M30 at the end.
linuxcnc.org/docs/2.8/html/gcode/m-code.html#mcode:m2-m30
If you put % at the start and end and remove the M30 you will see the status remain in G17.
5 years 6 months ago - 5 years 6 months ago #207016 by rider-83
Replied by rider-83 on topic Can't get lathe to Feed
Adding % at both header & footer worked nicely.
We still have the feed holding though.
Experimental HAL File:
############################################################### # BOXFORD B160TCL WITH ATC # ############################################################### loadrt [KINS]KINEMATICS #autoconverted trivkins loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS loadrt hal_parport cfg="0 out" setp parport.0.reset-time 200 loadrt stepgen step_type=0,0,0,0 loadrt pwmgen output_type=1 addf parport.0.read base-thread addf stepgen.make-pulses base-thread addf pwmgen.make-pulses base-thread addf parport.0.write base-thread addf parport.0.reset base-thread addf stepgen.capture-position servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf stepgen.update-freq servo-thread addf pwmgen.update servo-thread ############################################################ # DEFINE SPINDLE # ############################################################ net spindle-cmd-rpm => pwmgen.0.value net spindle-on <= spindle.0.on => pwmgen.0.enable net spindle-pwm <= pwmgen.0.pwm setp pwmgen.0.pwm-freq 1500.0 setp pwmgen.0.scale 2269.23076923 setp pwmgen.0.offset -0.0220338983051 setp pwmgen.0.dither-pwm true net spindle-cmd-rpm <= spindle.0.speed-out net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs net spindle-cmd-rps <= spindle.0.speed-out-rps net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs net spindle-at-speed => spindle.0.at-speed net spindle-cw <= spindle.0.forward net coolant-flood <= iocontrol.0.coolant-flood ########################################### # DEFINE D25 PINS # ########################################### net coolant-flood => parport.0.pin-01-out setp parport.0.pin-01-out-invert 1 net xstep => parport.0.pin-02-out net xdir => parport.0.pin-03-out setp parport.0.pin-02-out-reset 1 net ystep => parport.0.pin-04-out net ydir => parport.0.pin-05-out setp parport.0.pin-04-out-reset 1 net zstep => parport.0.pin-06-out net zdir => parport.0.pin-07-out setp parport.0.pin-06-out-reset 1 net astep => parport.0.pin-08-out net adir => parport.0.pin-09-out setp parport.0.pin-08-out-reset 1 net spindle-pwm => parport.0.pin-14-out net spindle-on => parport.0.pin-16-out net spindle-cw => parport.0.pin-17-out setp parport.0.pin-16-out-invert 1 ############################################################ # EMERGENCY STOP # ############################################################ net estop-ext <= parport.0.pin-10-in-not net estop-out <= iocontrol.0.user-enable-out net estop-ext => iocontrol.0.emc-enable-in ################################################################### # SET UP HOME & LIMITS # ################################################################### net min-home-x joint.0.neg-lim-sw-in <= parport.0.pin-11-in-not net min-home-x => joint.0.home-sw-in <= parport.0.pin-11-in-not net min-home-z joint.2.neg-lim-sw-in <= parport.0.pin-12-in-not net min-home-z => joint.2.home-sw-in <= parport.0.pin-12-in-not #SET UP EXTERNAL HOME BUTTON# net home-all halui.home-all <= parport.0.pin-13-in ################################################################### ################################################################### # SET UP EXTERNAL CYCLESTART BUTTON # net cycle-start-btn halui.program.run <= parport.0.pin-15-in ################################################################### ############################################################ # DEFINE AXIS # ############################################################ ########## # X-AXIS # ########## setp stepgen.0.position-scale [JOINT_0]SCALE setp stepgen.0.steplen 1 setp stepgen.0.stepspace 0 setp stepgen.0.dirhold 34000 setp stepgen.0.dirsetup 34000 setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb net xstep <= stepgen.0.step net xdir <= stepgen.0.dir net xenable joint.0.amp-enable-out => stepgen.0.enable ########## # Y-AXIS # ########## setp stepgen.1.position-scale [JOINT_1]SCALE setp stepgen.1.steplen 1 setp stepgen.1.stepspace 0 setp stepgen.1.dirhold 34000 setp stepgen.1.dirsetup 34000 setp stepgen.1.maxaccel [JOINT_0]STEPGEN_MAXACCEL net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb net ystep <= stepgen.1.step net ydir <= stepgen.1.dir net yenable joint.1.amp-enable-out => stepgen.1.enable ########## # Z-AXIS # ########## setp stepgen.2.position-scale [JOINT_2]SCALE setp stepgen.2.steplen 1 setp stepgen.2.stepspace 0 setp stepgen.2.dirhold 34000 setp stepgen.2.dirsetup 34000 setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL net zpos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd net zpos-fb stepgen.2.position-fb => joint.2.motor-pos-fb net zstep <= stepgen.2.step net zdir <= stepgen.2.dir net zenable joint.2.amp-enable-out => stepgen.2.enable ########## # A-AXIS # ########## setp stepgen.3.position-scale [JOINT_3]SCALE setp stepgen.3.steplen 1 setp stepgen.3.stepspace 0 setp stepgen.3.dirhold 34000 setp stepgen.3.dirsetup 34000 setp stepgen.3.maxaccel [JOINT_3]STEPGEN_MAXACCEL net apos-cmd joint.3.motor-pos-cmd => stepgen.3.position-cmd net apos-fb stepgen.3.position-fb => joint.3.motor-pos-fb net astep <= stepgen.3.step net adir <= stepgen.3.dir net aenable joint.3.amp-enable-out => stepgen.3.enable ################################################################################# # TOOL CHANGE SECTION # ################################################################################# #MY ADAPTATION OF ATC #net tool-number <= iocontrol.0.tool-prep-number #net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared #net tool-change-loopback iocontrol.0.tool-change => iocontrol.0.tool-changed ################################################################################# ################################################################################# #MANUAL CHANGE #loadusr -W hal_manualtoolchange #net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change #net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed #net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number #net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared ################################################################################# ################################################################################# #AUTOMATIC #loadrt toolchanger #addf toolchanger servo-thread #net tool-change iocontrol.0.tool-change => toolchanger.toolchange #net tool-changed iocontrol.0.tool-changed <= toolchanger.toolchanged #net tool-number iocontrol.0.tool-prep-number => toolchanger.toolnumber #net tool-oldnumber iocontrol.0.tool-number => toolchanger.currenttoolnumber #net apos-cmd toolchanger.position-cmd => stepgen.3.position-cmd #net ahomed joint.3.homed => toolchanger.ishomed #net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared ##################################################################################
Last edit: 5 years 6 months ago by andypugh.
5 years 6 months ago #207018 by andypugh
You could try adding a "sets" to set spindle-at-speed true, but it shouldn't be necessary and I am suspecting that the problem is something else.
net spindle-at-speed => spindle.0.at-speed sets spindle-at-speed 1
Is it possible that the feed-override is set to 0% ?
5 years 6 months ago #207020 by rider-83
feed over ride is 100%
I tried ' sets spindle-at-speed 1, '
No change.
5 years 6 months ago #207021 by rider-83
I've created a quick lathe profile with stepconf and the issue is the same there as well.
Time to create page: 2.892 seconds
