BOXFORD 125 TLC Tool Changer Setup
- pl7i92
- Thank you received: 358
16 Apr 2019 14:49 #130982
by pl7i92
Replied by pl7i92 on topic BOXFORD 125 TLC Tool Changer Setup
with the carusell component y0u woudt be better up
as it has all inside what you need as the image post 1 shows
- garulus
16 Apr 2019 16:52 #130986
by garulus
Replied by garulus on topic BOXFORD 125 TLC Tool Changer Setup
Hi mate! No I haven’t! If you help me to make it work, I’ll give you my first born child!
Hope the process is simple, coz I’m....
- Thank you received: 4648
16 Apr 2019 20:49 #131003
Replied by andypugh on topic BOXFORD 125 TLC Tool Changer Setup
I added features to Carousel last summer for the changer on a Denford Orac. It should work for most of that style now.
- fieldofcows
16 Apr 2019 21:56 #131009
by fieldofcows
Replied by fieldofcows on topic BOXFORD 125 TLC Tool Changer Setup
Just reviewed those changes to the carousel and this would definitely be the way forward for @garulus to get this working. I'm tempted to update my configuration but it's working at the moment and I am just about to put the lathe up for sale so I might just leave it alone.
@garulus - I can't remember exactly how I solved it myself but I do have the configuration saved so can take a look to remind myself and either help you set it up the same way as me or using the changes to the carousel code that andypugh made.
- garulus
17 Apr 2019 17:39 #131063
by garulus
Unfortunately I’m not programmer, so it will not help me. But if I may ask...would you be so kind and post your config files(folder)?
20 Apr 2019 22:30 #131333
You don't need to be a programmer. You can download the new version of carousel.comp
at this link
Save that file somewhere on your PC, then runfrom the folder where you saved the file, and your carousel.comp will be the new version.
sudo halcompile --install carousel.compPlease Log in or Create an account to join the conversation.
- deanforbes
21 Aug 2020 22:40 #178963
by deanforbes
Replied by deanforbes on topic BOXFORD 125 TLC Tool Changer Setup
The BOXFORD 125 TLC Tool Changer
1) Does not have any feed back what so ever as to the tool selected or an index position
2) Is driven by a stepper motor
3) Is mechanically similar to the orac as in it moves in one direction and then the other to lock against a pawl
- Has anyone set one of these up with the current version of carousel.comp - is this the correct component to be using?
- As it does not know which tool is selected I assume you would change the tool till you were at a predefined tool and then "home" it at this point - how have others addressed this problem ?
21 Aug 2020 22:55 #178966
Are you sure that there is no feedback? Could some be added?
carousel might be the correct component. I am committed to making it work with (nearly) all common toolchangers.
But if the TLC really does just pulse a fixed number of steps forwards then reverses to stall then maybe carousel is too capable (it mainly aims to cover all the feedback types)
A custom component to drive this feels like an easy job. But adding two sensors seems like a better plan.
The following user(s) said Thank You: deanforbes
- deanforbes
22 Aug 2020 06:42 - 22 Aug 2020 06:43 #178979
by deanforbes
I am sure that it does not have any feed back - which is I agree not the ideal way to go
The 125 and 160 have the same turret (I believe)
www.boxford-software.com/spares/160Turret3.html
www.boxford-software.com/spares/160menu.html
Last edit: 22 Aug 2020 06:43 by deanforbes.
- Clive S
- Thank you received: 486
22 Aug 2020 08:29 #178983
by Clive S
Replied by Clive S on topic BOXFORD 125 TLC Tool Changer Setup
I am about to do one of these, so will be watching with interest.
Time to create page: 0.159 seconds
