Life chat scares me with my broken English
This is what I tried so far:
I copied file toolchanger.comp to my linuxcnc/configs/Lathe_Orac folder
Then copied:
# .ini file for axis - ATC set up as axis A angular
[AXIS_3]
TYPE = ANGULAR
HOME = 0.0
MAX_VELOCITY = 2.5
MAX_ACCELERATION = 5
STEPGEN_MAXACCEL = 5
SCALE = 80.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -99999
MAX_LIMIT = 99999
HOME_OFFSET = 0.0
to the end of my Lathe_Orac.ini file
Then I copied:
# example Hal linkages required:-
setp stepgen.3.position-scale [AXIS_3]SCALE
setp stepgen.3.steplen 1
setp stepgen.3.stepspace 0
setp stepgen.3.dirhold 16000
setp stepgen.3.dirsetup 31000
## make sure accel and velocity are sensibly low or it will take off!
setp stepgen.3.maxaccel [AXIS_3]STEPGEN_MAXACCEL
### must unlink these 2 to access stepgen.3.position-cmd
### and prevent continual following errors if motor-pos-fb left linked
#net apos-cmd axis.3.motor-pos-cmd => stepgen.3.position-cmd
#net apos-fb stepgen.3.position-fb => axis.3.motor-pos-fb
net astep <= stepgen.3.step
net adir <= stepgen.3.dir
net aenable axis.3.amp-enable-out => stepgen.3.enable
# loading the toolchange component in .hal file
loadrt toolchanger
addf toolchanger servo-thread
net tool-change iocontrol.0.tool-change => toolchanger.toolchange
net tool-changed iocontrol.0.tool-changed <= toolchanger.toolchanged
net tool-number iocontrol.0.tool-prep-number => toolchanger.toolnumber
net tool-oldnumber iocontrol.0.tool-number => toolchanger.currenttoolnumber
net apos-cmd toolchanger.position-cmd => stepgen.3.position-cmd
net ahomed axis.3.homed => toolchanger.ishomed
In to my Lathe_Orac.hal file
I don’t understand this part:
Now when I try to run Linuxcnc I got this message:
/Lathe_Orac.hal:87: parameter or pin ‘stepgen.3.positio-scale’ not found
