BOXFORD 125 TLC Tool Changer Setup
27 Jan 2021 13:46 #196756 by andypugh
Replied by andypugh on topic BOXFORD 125 TLC Tool Changer Setup
That's a bit wierd.
Possibly an un-matched bracket earlier in the file?
27 Jan 2021 14:21 #196764 by Serg452
Replied by Serg452 on topic BOXFORD 125 TLC Tool Changer Setup
added a parenthesis at the end
if (jog_fwd || jog_rev) return; // require button release to jog again
        if (rev_pulse > 0){
	    motor_fwd = 0;
            motor_rev = 1;
            motor_vel = rev_dc;
            timer = rev_pulse;
	    state = 3;
        } else {
        state = 0;
Now the disc returns, but the tool number does not change, the last from the command remains M6Tx
Sorry for the questions, I'm a really bad programmer)))
27 Jan 2021 23:20 #196846 by andypugh
You mean that the tool number seen in LinuxCNC doesn't change?
No, it won't. There isn't a link between the carousel component and the internal LinuxCNC state.
You can set the tool without a toolchange with the M61 command.
11 May 2021 17:33 - 11 May 2021 17:34 #208568 by gcardinal
Replied by gcardinal on topic BOXFORD 125 TLC Tool Changer Setup
So how do I solve this
Just wanted to ask if you ever ended up solving this? I'm working on almost the same toolchanger and would really appreciate if you could share your configuration.
Last edit: 11 May 2021 17:34 by gcardinal.
11 May 2021 18:49 #208573 by Clive S
Replied by Clive S on topic BOXFORD 125 TLC Tool Changer Setup
forum.linuxcnc.org/38-general-linuxcnc-q...ved?start=100#188519
The following user(s) said Thank You: gcardinal
17 Nov 2024 11:52 #314655 by BoxCNC
Replied by BoxCNC on topic BOXFORD 125 TLC Tool Changer Setup
Hi. Can work with LinuxCNC 2.9.3. Please help if you can.
Time to create page: 0.290 seconds
