Can't get lathe to Feed
5 years 2 months ago #217307 by rider-83
Replied by rider-83 on topic Can't get lathe to Feed
Yes to G95 F0.1
scaled is RPM, not RPS
It was RPS but I changed it because I didn't understand what was happing with an issue earlier on. I will swap it back
5 years 2 months ago #217680 by rider-83
I switched back to RPS and used ABS, now we are feeding in G1 with both M3 & M4.
Thanks fella's
5 years 2 months ago #217691 by rider-83
I've run some more test and have been successful with G71 in G96 CSS mode.
Next is to get a functioning G76.
I've wrote a small program to test, and the syntax is correct, only the machine now sits presumably waiting for the strobe signal to begin its traverse .
How do I now set up for this signal using ver2.9?
5 years 2 months ago #217860 by rider-83
Andy,
Ref: encoder.N.missing-teeth
My encoder disc has 100 slots. Should I blank out two slots and use this method?
Do we leave the 'scale' still set at 100 ?
5 years 2 months ago #217877 by Clive S
Replied by Clive S on topic Can't get lathe to Feed
Andy,
I have added my config and pics of the Boxford 125
forum.linuxcnc.org/38-general-linuxcnc-q...ved?start=110#217847
5 years 2 months ago #217932 by andypugh
Replied by andypugh on topic Can't get lathe to Feed
Yes, the scale still stays at however many teeth there would be.
You can blank out one or more teeth.
Time to create page: 0.316 seconds
