if/while ?
15 years 8 months ago #7416 by BigJohnT
Replied by BigJohnT on topic Re:if/while ?
A DO-WHILE loop does the code then checks the while condition. A WHILE-ENDWHILE loop checks the while condition and if true does the code.
So a DO WHILE loop in sudocode
Do
Stuff
Check While condition if true return to top and run again
A WHILE ENDWHILE loop in sudocode
Check While condition if it is True run code if False skip code
Stuff
Endwhile
So your do while loop will always execute at least once. Your test condition is while #2 is greater than #1 so it has to be larger before the loop stops. In other words you must pass up your desired target before the loop exits.
You either have to change your relational operator to one that gives you the correct outcome or the loop.
Hidden in the Binary Operators are the Relational Operators.
www.linuxcnc.org/docview/html/gcode_over...sub:Binary-Operators
15 years 8 months ago #7425 by piasdom
Replied by piasdom on topic Re:if/while ?
i thought that was the case about it having to be bigger than #1.
but it doesn't go over on the second Do. it goes to .04, so i still don't understand this
do'y think :)
15 years 2 months ago #12577 by piasdom
can i get z to move up(from present depth) .1" and move to another position and start
another cut ? like z at -.4.... move z up .1"(-.3").....move to new position.... z-.5. or
do i need a script or mcode ?
o100 if [#<fin_depth> lt #<depth_of_cut>]
z[.1/1]
o100 else
z#<_safeheight>
o100 endif
g0 x.1 y-.1
kenneth
15 years 2 months ago #12580 by andypugh
Replied by andypugh on topic Re:if/while ?
Yes.
o100 if [#<fin_depth> lt #<depth_of_cut>] z[.1/1] o100 else z#<_safeheight> o100 endif g0 x.1 y-.1
You probably need to learn to program in a real programming language, and not G-code. But, this is how I do what I think you want to do.
#<safeheight> = 2 #<startdepth> = 1 #<fin_depth> = 0.5 #<cut> = 0.1 #1 = #<startdepth> Note the use of #1 as a "working" variable to hold current_Z O100 WHILE [#1 GT #<fin_depth>] G0 Z #1 #1 = [#1 - #<cut>] O101 IF [#1 < #<fin_depth>] ; allow for the last cut being less than <cut> above <fin> #1 = #<fin_depth> O101 ENDIF G1 Z#1 .... Various G-code moves go here .... O101 ENDWHILE
15 years 2 months ago #12586 by piasdom
won't this make the end mill go down with each run ? i want the end mill to
come up from current position(-.4 to -.3") - move to new position(x.1 y.1) - go down .1" from
last current position(-.5).
15 years 2 months ago #12589 by andypugh
Why do you need an "if" then?
I really don't get what you are trying to achieve, but you probably need to use a variable for Z (like I did with #1), and keep modifying that before you use it.
#1 = 0.4
G1 Z#1
...some moves...
G0 z -0.3
G0 X0.1 Y0.1
#1 = [#1 - 0.1]
G0 Z#1
I still don't understand what you are wanting to do, though.
Time to create page: 0.296 seconds
