- Thank you received: 9
if/while ?
- piasdom
- Banned
15 years 2 months ago #12591
by piasdom
Replied by piasdom on topic Re:if/while ?
i didn't know which to use ... if ....do ... else.. whoever don't even know if possible
i'm cutting pockets and i don't want the end mill moving along the bottom
as it goes to the next depth. that's it, want to to come up .1" from whatever depth,
move to x.1 y.1 and go deeper .1".
15 years 2 months ago #12592
Replied by andypugh on topic Re:if/while ?
piasdom wrote:
So, you want to do it every time? In that case, there is no need for any logic structure at all. Inserted into my code it is just
O100 WHILE [#1 GT #<fin_depth>]
G0 Z #1
#1 = [#1 - #<cut>]
O101 IF [#1 < #<fin_depth>] ; allow for the last cut being less than <cut> above <fin>
#1 = #<fin_depth>
O101 ENDIF
G1 Z#1
Various G-code moves go here
G0 Z[#1 + 0.1]
O101 ENDWHILE
G0 Z #1
#1 = [#1 - #<cut>]
#1 = #<fin_depth>
O101 ENDIF
G1 Z#1
G0 Z[#1 + 0.1]
O101 ENDWHILE
- piasdom
- Banned
15 years 2 months ago #12601
by piasdom
Thanks andy !
but i'm not very clear, i'm sorry. i had that before and it works great for what i wanted then.
now i cutting a pocket -.941 deep with a step at -.866. i make a rough cut along the inside edge
(about .02" away from fin) at -.1. then i go to -.2 and do the same. THEN i want to clean center.
so i thought there may be 'something' i could use every .2. i clean from out to inside, so the end mill
ends up at the center. i wanted something(if possible) to put every .2 deep that would raise the end mill .1
from where it's at then move to x.1 y.1, go another -.1 and then start .1(would be -.3) then .2 (-.4) then clean again.
Thanks !
kenneth
Thanks !
kenneth
- BigJohnT
- Thank you received: 994
15 years 2 months ago #12602
by BigJohnT
Replied by BigJohnT on topic Re:if/while ?
You just have to program what you want. You can use subroutine for your clean center part just program your tool to be in the correct position then call your subroutine.
o100 sub
lots of code to cut the center out
o100 endsub
code to cut the outside of the box
code to put the cutter in the correct position for XY&Z
o100 call
o100 call
repeat for each level
M2
o100 sub
o100 endsub
o100 call
o100 call
M2
- piasdom
- Banned
15 years 2 months ago #12605
by piasdom
Thanks BigJohnT and andy,
that's what i've been doing, just thought there was a command,script or something that
would do that. i'll keep what i have.
kenneth
kenneth
- piasdom
- Banned
14 years 7 months ago - 14 years 7 months ago #18236
by piasdom
shouldn't this work ?
been trying if/else and do/while. but to me this should work.
it only goes to 1" then 0". and stops. i think it should go to 1"
then 0", then 2" then 0 ....etc. to 6". and i tried all
the operators. most freezes emc2.5.
g17 g20 g40 g49 g54 g80 g90 g94 g92.1
#<start> = 2
#<travel_ing> = 1
#<final_distant> = 6
#<feed_rate> = 18
o100 do
#<start> = [#<start> - #<travel_ing>]
g1 f#<feed_rate> x#<start>
x0
o100 while [#<start> ge #<final_distant>]
m2
Thanks for looking.
kenneth
#<start> = 2
#<travel_ing> = 1
#<feed_rate> = 18
o100 do
x0
m2
Thanks for looking.
kenneth
Last edit: 14 years 7 months ago by piasdom.
Time to create page: 0.185 seconds
