Changing the openGL colors in the Axis GUI
  • KPA
  • New Member
  • New Member
14 years 7 months ago #18406 by KPA
Are you thinking like the 'compass rose'? that shows the origin and axis arrows? or a full grid in all views?
Nice that you've been giving it a shakedown to test it out!
Jay
14 years 7 months ago #18408 by cncbasher
if you need it testing on a larger res screen let me know , mine is 1940 x 1200 and can be turned portrait mode without balancing the montor on my knee LOL
14 years 7 months ago #18411 by cmorley
plotter grid - yes someone did a mod for hot-wire foam cutter display. It had an optional grid IIRC.
I like the DRO off the plotter - I always thought it should be optionally removeable.
14 years 7 months ago #18416 by loboy
KPA - I want a regular grid over the XY plane, like in most CAD applications. I have written one in OpenGL before for another app, so I will probably just move some code over. I will do major grid lines every inch, and minor grid lines everything 1/16 inch, all the way out to the machine limits. I will most likely make it adjustable for different situations, and for both imperial and metric units. I like having a grid, so I have a bit more of a reference.
cncbasher - Once I neaten up the code more, and make it easy to move to another computer for testing, I will be sure to post here. Any thoughts on how to appropriately package the new Axis code is appreciated. I don't know if I should just fork the code, and call it something different...
cmorley - Thanks. Is that person on these forums? Or do know where I can find them or their work? Yes, removing that little DRO was a little cumbersome. Doing fonts in OpenGL is just not worth the work, especially how it constantly needs to redraw the tiny DRO.
14 years 7 months ago #18417 by cmorley
He probably can be found in the dev mail list.
you could search the archives. you should find patch files...
I don't remember his name.
14 years 7 months ago #18427 by loboy
cmorley - Could you point me in the direction of the archives you mentioned? I am not sure which archives you are suggesting. Where exactly do I find these patch files? Thanks.
Time to create page: 0.402 seconds
