Is there a way to print a message to AXIS?
  • garymcrobertpdx
  • Premium Member
  • Premium Member
17 Jan 2012 21:48 #16859 by garymcrobertpdx
Is there a way to print a message to AXIS? was created by garymcrobertpdx
Is there a way to print a message from a G code program to the AXIS screen?
It would be nice to be able to prompt the operator when the machine pauses
for a manual part reorientation in the vice.
17 Jan 2012 21:59 #16861 by BigJohnT
  • garymcrobertpdx
  • Premium Member
  • Premium Member
17 Jan 2012 22:32 #16863 by garymcrobertpdx
Replied by garymcrobertpdx on topic Re:Is there a way to print a message to AXIS?
Yes I have that part. I failed to explain that I was hoping for is a way to make the message large
enough to be seen from a distance, say ten feet the distance from my Bridgeport mill to the CNC
rig.
18 Jan 2012 00:19 #16865 by BigJohnT
Replied by BigJohnT on topic Re:Is there a way to print a message to AXIS?
The you want to check out GladeVCP, it is quite versatile. That is in 2.5 btw...
linuxcnc.org/docview/2.5/html/gui/gladevcp.html
and
linuxcnc.org/index.php/english/component...ew&catid=48&id=16439
18 Jan 2012 11:44 - 18 Jan 2012 11:45 #16878 by ArcEye
Hi
Another easy way to do this is to use a 'user M code'.
The zip contains a .png image which contains the text "Re-orientate part in vice!!"
Place this together with the file M112 contained in the .zip in the directory specified in your .ini file under PROGRAM_PREFIX=
You may need to edit M112 if the location of the image differs or if you use a different viewer in place of qiv
(make sure you leave it executable - chmod 755)
To run you just have to use the M112 in your g code program.
Very simple and save messing about with glade if you don't use it for anything else.
Just one of the many ways to skin this particular cat!
File Name: M112.zip
File Size:40 KB
Last edit: 18 Jan 2012 11:45 by ArcEye.
18 Jan 2012 11:49 #16879 by BigJohnT
That's pretty neat!
18 Jan 2012 12:04 #16881 by BigJohnT
On a stock install from the LiveCD you might want to use the following line
eog /home/computername/emc2/nc_files/message.png
eog is Eye of Gnome which comes installed with the LiveCD.
18 Jan 2012 17:27 #16894 by ArcEye
Thanks John,
My installation is on Lenny with a different rtai kernel, so is far from 'stock' anything!
18 Jan 2012 18:54 #16897 by BigJohnT
I kinda figured that or your some kind of super geek LOL... anyhow I just tossed that out for newbie's to not stumble too much trying to make it work. It's a pretty neat idea!
Maybe the guy that wanted the computer to holler at him when done could do something similar.
19 Jan 2012 08:53 #16926 by ArcEye
Yeah, mpg123 Hey_Come_and_Reposition_the_Workpiece.mp3 would do it :woohoo:
