Is there a way to print a message to AXIS?
21 Feb 2012 10:00 #17905 by andypugh
Replied by andypugh on topic Re:Is there a way to print a message to AXIS?
ArcEye wrote:
Rectifying this produces the result you wanted
Not for me. It works for me from the command line ( ./m112) But EMC2 is not finding it.
I tried making it executable in the GUI, and with chmod.
Where have you put the files? Does this correspond to an INI file entry?
21 Feb 2012 12:15 #17906 by beltramidave
Replied by beltramidave on topic Re:Is there a way to print a message to AXIS?
Interesting.....As stated earlier:
1. I put my files (stopmessage.png and M112) in the following directory: /home/dave/emc2/nc_files.
2. My M112 files is this:
#!/bin/bash
eog /home/dave/emc2/nc_files/stopmessage.png
exit 0
3. I put "M112" in my .ngc program
Not sure how to make the M112 file executable. When I checked the files properties under Permissions, the check box is checked as being an executable.
21 Feb 2012 12:38 #17907 by BigJohnT
Replied by BigJohnT on topic Re:Is there a way to print a message to AXIS?
On my 10.04 computer in the beer cave I can only get eog to work like this
cd emc2/nc_files
When I try and run your M112 file I get a strange error
bash: ./M112: /bin/bash^M: bad interpreter: No such file or directory
When I created a new file using gedit I get a slightly different error...
bash: ./M113: bin/bash: bad interpreter: No such file or directory
something is bashed for sure...
21 Feb 2012 12:41 #17908 by beltramidave
Got it working!!
You were correct in that I had created the M112 file in Windows, but when I used Gedit to open (on my computer running Ubuntu) it opened and looked just the same as if I opened it with Windows.
I re-created it with Gedit and was able to display my message both in MDI and calling it from my Gcode. I had no doubt that it would be something very simple, but I had no way of knowing. This has/had been my first attempt to do anything like this.
I appreciate everyone sticking with me until I figured it out!!
Dave
21 Feb 2012 12:46 #17909 by BigJohnT
I found this doing a google search
shell does not like CR/LF, if you created your scripot in Windows and transferred it into Linux machine then you have CR/LFs in you shell script that you have to remove.
21 Feb 2012 12:47 - 21 Feb 2012 17:57 #17910 by BigJohnT
I am glad you finally got this to work.
Last edit: 21 Feb 2012 17:57 by BigJohnT.
21 Feb 2012 13:00 #17911 by beltramidave
I'm going to push my luck, now.
Is there a SIMPLE way of closing the message window by using the 'Enter' key instead of using the mouse and pressing 'x'?
21 Feb 2012 14:37 #17913 by ArcEye
Alt F4
Using the enter key to close anything, assumes that there is a 'Close' button and that it has keyboard focus, neither of which pertain.
22 Feb 2012 11:59 #17932 by BigJohnT
Instead of using bash could you use a python program to get the desired result?
Just thinking out loud...
22 Feb 2012 12:23 #17933 by beltramidave
As I know nothing about programming (as obvious from all my posts on this subject), I don't think that it would be a good idea to try Python. I have looked through the documentation and really wish that I understood it more to give it a try. Would be really nice to be able to create custom panels. Maybe down the road.
Time to create page: 0.093 seconds
