Hi
Thanks! I installed this file and I can now jog and reset Z before continuing after a tool change.
You're welcome.
I have a touch plate ( a piece of copper-clad PC card) that (together with the milling bit) acts as a switch connected to a parallel port input pin, but I do not yet understand how Axis interprets this.
The short answer is that Axis doesn't interpret it, you have to do something with it.
The simplest would be to create a pyvcp LED linked to that input and then when that activates you can set your Z height to the thickness of the touch off plate (assuming it sits directly on the work piece).
You might need to try interposing a debounce component for a consistent on/off.
I know from experience using electromechanical touch sensors, that atmospheric humidity, dust or moisture on the cutter or sensor, all cause inconsistencies in touching off, despite the most careful cleaning.
It often takes several touches and back-offs to arrive at a mean, where you have a consistent full illumination of the led for a given position.
A more complicated version of this could set the Z tool height automatically to the plate thickness, but that would require a bit more programming.
This facility will be very useful to you for tool setting.
However the more you use your machine, unless it is just for repetition component production, the more you will come back to what John and Rick were saying about just splitting your program.
I have a lathe with 8 station ATC, but rarely actually program a tool change mid-program, because apart from anything else, I want to double check the work piece dimensions before moving to the next stage.
If I had a rock steady proven program, bar feed and hundreds of components to make that would be different, but I seldom make more than a couple of the same thing!
