Having trouble with Coordinate System on multihead router.
- HueyHQ
- Thank you received: 24
03 Dec 2023 23:31 #287149
by HueyHQ
Once you post your files, I'll take a look at it.
Replied by HueyHQ on topic Having trouble with Coordinate System on multihead router.
Yeah I am, I've been thinking of using something else, particularly with HSM, but I've been strapped for time for ages and haven't gotten around to doing it let alone any actual CNC work. I think Fusion360 does HSM?i have had all the spindles popping down all the wiring side is done so its just the coding side of it now to make do its thing.
are you still using vetric for cad/cam
- craigs711btm
04 Dec 2023 10:21 #287178
by craigs711btm
Replied by craigs711btm on topic Having trouble with Coordinate System on multihead router.
I'm assuming hsm is horizontal drilling ? if so then yes it defiantly does might even be possible from vetric with drawing it as a model and adapting pp to know what to do when it comes to horizontal.
how do I upload files on here I'm new to this forum and cant see it as a option
- HueyHQ
07 Dec 2023 01:03 #287403
by HueyHQ
Not quite - HSM stands for High Speed Machining (I think!) which means the software creates more efficient toolpaths in a way that tries to keep the cutting tool moving at a near constant speed, i.e. reduces acceleration and deceleration like when cutting in straight lines, corners, etc.
- craigs711btm
04 Feb 2024 14:27 #292398
by craigs711btm
not sure if ive done it correctly but heres my config files
Time to create page: 0.123 seconds
