Spindle location on the opposite side
18 Jan 2025 15:03 - 18 Jan 2025 15:03 #319287 by Murphy
I'm complete newbie with linuxcnc, CNC in general. Can somebody tell me when I load the pawn example from the files. The pawn is loaded in the opposite direction. How do I reverse it
Last edit: 18 Jan 2025 15:03 by Murphy.
18 Jan 2025 21:09 #319316 by cakeslob
Replied by cakeslob on topic Spindle location on the opposite side
is the cutter in the same place in the preview as your machine?
18 Jan 2025 22:28 #319322 by Murphy
Replied by Murphy on topic Spindle location on the opposite side
Yes, the tool moves from bottom to top towards the center line.
20 Jan 2025 15:36 #319467 by Murphy
Do I need to change something in the pawn example G code so the base of the pawn is facing to the left rather than the right ?
20 Jan 2025 16:25 #319468 by Aciera
Replied by Aciera on topic Spindle location on the opposite side
I think it's actually the gcode example that is 'inverted' as it really creates a negative of a chess pawn.
20 Jan 2025 17:44 - 20 Jan 2025 20:22 #319473 by Murphy
Thanks Aciera
Last edit: 20 Jan 2025 20:22 by Murphy.
21 Jan 2025 11:10 - 21 Jan 2025 13:42 #319546 by Murphy
I modeled up a pawn in fusion 360 and opened up the post in linuxcnc and it's still the same. Anybody have any ideas how to change the Z so the base of the pawn is on the left
When I home the machine the switches are activated on x when it moves down(x+) away from the spindle. Z homes towards the spindle and hits the switches. It then marks where g54 is.
The cutter is also cutting in the opposite direction.(In axis preview )But the axis are moving in the correct direction. X axis moves from X+ to X-(towards center line) Z moves from Z+ to Z- (towards spindle)
I have attached my ini file
Last edit: 21 Jan 2025 13:42 by Murphy.
21 Jan 2025 17:46 #319580 by Aciera
Looks ok to me, the base of the pawn (ie the wider part) is on the left.
The green/blue X/Z indicator shows your current work offset origin.
X+ should move the tool away from the center line.
Z+ should move the tool away from the spindle.
21 Jan 2025 19:45 - 21 Jan 2025 19:48 #319584 by Murphy
The wider part(base) is on right in linuxcnc as in the pic. It should be on the left the wider part is supposed to be held in the spindle. My spindle is on the left
It's supposed to machine the head first and move down to the base. But it's flipped around. I'll try and take a video of it,
Last edit: 21 Jan 2025 19:48 by Murphy.
21 Jan 2025 20:11 #319586 by Murphy
This is my crude explanation
youtube.com/shorts/nY0A_utbBd4?si=7yU3tGuBq7IW74BQ
Time to create page: 1.042 seconds
