Touch off don`t work "file not open"
1 year 3 months ago - 1 year 3 months ago #332622 by dredivan
Replied by dredivan on topic Touch off don`t work "file not open"
[RS274NGC] PARAMETER_FILE = linuxcnc.var
I use clean configuration created by PNCCONF.
My linuxcnc version is 2.10
If I don't enter anything from the keyboard and just press the OK button in the window, the coordinates are reset.
but if I enter any number, the option to confirm with the OK button disappears.
After I click the OK button, I open the linuxcnc.var file and see that the values have been written
5221    37.000000 5222    0.000000 5223    -10.443750
But if I enter any number from the keyboard, the option to confirm disappears, and I see the inscription "File not open"
linuxcnc.var
Log of run configuration
Last edit: 1 year 3 months ago by dredivan.
1 year 2 months ago #332745 by andypugh
Replied by andypugh on topic Touch off don`t work "file not open"
As an experiment, is it all OK until you enter a decimal separator?
Do you definitely have a linuxcnc.var file in the config directory (ie the directory that the INI file is in?)
If you "ls -al" the config folder, do all the files belong to the same user?
There is something funny going on here, and it's not something we have seen before.
1 year 2 months ago #332809 by dredivan
I did a clean install with Linux_Mint_22.1_LinuxCNC_2.10.iso
and now this problem is gone
Befor I did install clean debian 12 and linuxcnc 2.10
4 months 3 hours ago #347437 by jcbryant
Replied by jcbryant on topic Touch off don`t work "file not open"
I'm now running into exactly the same problem and aren't at all keen on having to resort to a clean install.
Hopefully somebody has an explanation and an easier solution......
  • Aciera
  • Administrator
  • Administrator
3 months 4 weeks ago #347440 by Aciera
Replied by Aciera on topic Touch off don`t work "file not open"
What version of LinuxCNC are you running?
3 months 4 weeks ago #347450 by jcbryant
LinuxCNC 2.9.5
Time to create page: 0.777 seconds
