Linux_Mint_22.1_LinuxCNC_2.10.iso
- Thank you received: 7478
15 Mar 2025 01:48 - 09 Aug 2026 14:49 #323976
Linux_Mint_22.1_LinuxCNC_2.10.iso was created by tommylight
WARNING:
- Do NOT go to Linux Mint forums to ask for help regarding this image, NEVER EVER!!!
- This is for anyone wanting to have a Working LinuxCNC installation in Minutes, has no support except here on this forum from me, uses development version so might have issues.
Removed Libreoffice, geoclue, redshift, flatpak, and some other useless stuff
Installed Inkscape, Blender, OBS-Studio, KdenLive, VLC, GIMP, Darktable, GNumeric
Enabled FIREWALL by default!!!
In Live mode when booted from USB it runs with Generic Kernel
After installation to hard drive it runs 6.10.nn RT-Preempt kernel
Warning: WiFi will probably not work with the RT kernel, so reboot and hold down right side SHIFT key, go to advanced options and choose the generic kernel, WiFi works fine with it.
drive.google.com/file/d/12adxkk6DU2fTYJb.../view?usp=drive_link
MD5SUM= 512b3e5226cb71127215bcf65c6a9b46 Linux_Mint_22.1_LinuxCNC_2.10_new.iso
Last edit: 09 Aug 2026 14:49 by tommylight. Reason: more info
The following user(s) said Thank You: billykid, aparecido, dredivan, my1987toyota, scotth, 5G-antry, gitin, unknown, RealPino
- billykid
- Thank you received: 83
15 Mar 2025 20:34 #324023
by billykid
Replied by billykid on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Hi Tom, I tried to make a pendrive with mint but it doesn't boot... then I tried with balena etcher but it says missing partition table. maybe I'm wrong, I haven't done anything for almost a year.
15 Mar 2025 20:36 - 15 Mar 2025 20:41 #324024
Replied by tommylight on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Use Rufus in Windows, or are you using Linux to write the USB?
Edit:
I use Ventoy for everything, give it a try, it is magnificent as it can boot pretty much every ISO and IMG file, even Win98 setup!
www.ventoy.net/en/index.html
After installing Ventoy onto a USB, all you have to do is just copy the ISO to USB, no software, no burning, nothing.
Edit:
Last edit: 15 Mar 2025 20:41 by tommylight. Reason: more info
- billykid
15 Mar 2025 20:41 - 15 Mar 2025 20:42 #324025
by billykid
I used linux then balena etcher on win 10. now I try ventoy
Last edit: 15 Mar 2025 20:42 by billykid.
- gitin
- Thank you received: 9
17 Mar 2025 16:22 #324126
by gitin
Replied by gitin on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Hi Tommy. I installed your build. It works well, loads quickly.
If in the ini file DISPLAY = axis, the screen does not load.
If this is replaced with DISPLAY = gmoccapy or with
DISPLAY = qtvcp qtdragon
PREFERENCE_FILE_PATH = WORKINGFOLDER/qtdragon.pref
it works fine. Maybe I don't understand something.
Translated in Google.
17 Mar 2025 16:35 #324132
Post the error report here.
Did you try running the included Axis sims?
Usually Axis issues are always related to OpenGL not working, so you can try adding or removing the graphic card.
FYI, i have installed this 7-8 times by now, it works as advertised, meaning installs in about 8-12 minutes on some Lenovo i7 6600U and 7600U.
Also axis works always.
The following user(s) said Thank You: gitin
- gitin
17 Mar 2025 17:34 #324137
by gitin
Yes, I launched the included Axis sims on a dell OptiPlex-7780-AIO Intel Core i7-10700.
This ssd has debian 12 and mx23, does this affect mint 22.1?
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.10.0~pre0
Machine configuration directory is '/home/gitin/linuxcnc/configs/sim.axis-1'
Machine configuration file is 'axis_mm.ini'
INIFILE=/home/gitin/linuxcnc/configs/sim.axis-1/axis_mm.ini
VERSION=1.1
PARAMETER_FILE=sim_mm.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins
Starting LinuxCNC...
linuxcncsvr (2832) emcsvr: machine 'LinuxCNC-HAL-SIM-AXIS' version '1.1'
milltask (2845) task: machine 'LinuxCNC-HAL-SIM-AXIS' version '1.1'
halui (2847) halui: machine 'LinuxCNC-HAL-SIM-AXIS' version '1.1'
Found file(lib): /usr/share/linuxcnc/hallib/core_sim.hal
Found file(lib): /usr/share/linuxcnc/hallib/sim_spindle_encoder.hal
Found file(lib): /usr/share/linuxcnc/hallib/axis_manualtoolchange.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
Found file(REL): ./cooling.hal
USRMOT: ERROR: command 30 timeout
emcMotionInit: emcTrajInit failed
Starting DISPLAY program: axis
task: 0 cycles, min=0.000002, max=0.001060, avg=-1.000000, 0 latency excursions (> 10x expected cycle time of 0.001000s)
Debug file information:
Note: Using POSIX realtime
link (updating variable file): Нет такого файла или каталога
File "/usr/bin/axis", line 3007, in <module>
vars = nf.Variables(root_window,
File "/usr/lib/python3/dist-packages/nf.py", line 46, in __init__
setattr(self, name, makevar(master, name, klass))
File "/usr/lib/python3/dist-packages/nf.py", line 70, in makevar
self.set(self._default)
File "/usr/lib/python3.12/tkinter/__init__.py", line 424, in set
return self._tk.globalsetvar(self._name, value)
_tkinter.TclError: can't set "taskfile": can't read "::": no such variable
2835
2845
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Пн 17 мар 2025 19:59:24 MSK
UTC Date: Пн 17 мар 2025 16:59:24 UTC
this program: /usr/bin/linuxcnc_info
uptime: 19:59:24 up 4 min, 1 user, load average: 1,03, 0,92, 0,43
lsb_release -sa: Linuxmint Linux Mint 22.1 22.1 xia
linuxcnc: /usr/bin/linuxcnc
pwd: /home/gitin/linuxcnc/configs/sim.axis-1
USER: gitin
LOGNAME: gitin
HOME: /home/gitin
EDITOR:
VISUAL:
LANGUAGE: ru_RU
TERM: dumb
COLORTERM:
DISPLAY: :0
DESKTOP: mate
display size: 1920x1080 pixels (508x285 millimeters)
PATH: /usr/bin:/home/gitin/linuxcnc/configs/sim.axis-1/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
uname items:
nodename -n: gitin-OptiPlex-7780-AIO
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT_RT Debian 6.10.12-1 (2024-10-01)
machine -m: x86_64
processor -p: x86_64
platform -i: x86_64
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-6.10.12-rt-amd64 root=UUID=0ae8aa4a-3b74-4dae-9243-989492bb833f ro quiet splash
model name: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
cores: 8
cpu MHz: 4558.254
parport:
serial: 0000-0000 : serial
Versions:
gcc: gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
python: Python 3.12.3
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.10.0~pre0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /usr/lib/linuxcnc/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
PYTHON: /usr/bin/python3
dpkg -l '*linuxcnc*':
Желаемый=неизвестно/установить/удалить[r]/вычистить[p]/зафиксировать[h]
| Состояние=не[n]/установлен/настроен[c]/распакован/частично настроен[F]/
частично установлен[H]/trig-aWait/Trig-pend
|/ Ошибка?=(нет)/требуется переустановка[R] (верхний регистр
в полях состояния и ошибки указывает на ненормальную ситуацию)
||/ Имя Версия Архитектура Описание
un linuxcnc <нет> <нет> (описание недоступно)
un linuxcnc-dev <нет> <нет> (описание недоступно)
un linuxcnc-doc <нет> <нет> (описание недоступно)
un linuxcnc-doc-en <нет> <нет> (описание недоступно)
un linuxcnc-doc-es <нет> <нет> (описание недоступно)
un linuxcnc-doc-fr <нет> <нет> (описание недоступно)
un linuxcnc-sim <нет> <нет> (описание недоступно)
un linuxcnc-sim-dev <нет> <нет> (описание недоступно)
ii linuxcnc-uspace 1:2.10.0~pre0 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.10.0~pre0 amd64 PC based motion controller for real-time Linux
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins
2835
2845
pastebin.com
USER: gitin
LOGNAME: gitin
HOME: /home/gitin
EDITOR:
VISUAL:
LANGUAGE: ru_RU
TERM: dumb
COLORTERM:
DISPLAY: :0
DESKTOP: mate
uname items:
machine -m: x86_64
platform -i: x86_64
/proc items:
cores: 8
cpu MHz: 4558.254
parport:
Versions:
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
RTS: uspace
17 Mar 2025 19:59 #324146
Seems like an issue with languages/locales, or missing translation to Russian.
Try to set locale to UTF-8, see if that helps, if not, then short of installing it again in English i am out of ideas.
I did test on my Laptops, Axis works, even the parallel port config works despite not having a parallel port.
- gitin
18 Mar 2025 07:34 #324172
by gitin
Yes, you're right, the problem is with languages/localizations. I installed it in English, there are no problems, it works perfectly. Localization is not necessary for operation. Thanks a lot, Tommy.
23 Mar 2025 23:30 #324709
You are welcomed, always.
Added the md5sum to the first post, sorry, i forgot to add it when uploading.
Time to create page: 0.397 seconds
