Linux_Mint_22.1_LinuxCNC_2.10.iso
- BlownCorona
- Thank you received: 3
14 Jul 2026 07:18 - 14 Jul 2026 07:23 #347757
by BlownCorona
Replied by BlownCorona on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
To be fair to Tommy, I've used this ISO successfully for a while now, this is the first issue I've come across and its not anything to do with linuxcnc, and sounds like I can resolve it.
In fact the synaptics displaylink drivers are only officially offered for ubuntu, while there is a community Debian option available, and the second computer I have that I set up a Debian build on is struggling to get the screen to show anything, where as this Mint ISO already allows the screen to display and operate with single point touch only, which would actually be sufficient for a cnc mill, but less refined than the screen could be.
This goes to show that there are pros and cons to all options and its not at all accurate to claim we must stick with Debian.
With that said, i am wanting to try Probe Basic, and being that this was developed for Debian may be the way i go, hence the aforementioned debian unit.
To all that replied with useful information, greatly appreciated. Ill report back with results.
Last edit: 14 Jul 2026 07:23 by BlownCorona.
- BlownCorona
14 Jul 2026 07:27 #347758
by BlownCorona
Heh.. the very next search i did after replying lead me to the info that the displaylink driver doesn't handle touch, Linux kernals hud-multitouch does.
always something new to learn eh.. though its pretty obveous in hindsight
- Thank you received: 7478
14 Jul 2026 13:50 #347764
Replied by tommylight on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
See what Tuxedo OS uses for touch, i am sure it worked on Mint also as i tested on a Lenovo X1 Yoga a while back, but do not recall what the package name was.
- tuxcnc
- Thank you received: 52
14 Jul 2026 14:57 #347767
by tuxcnc
Replied by tuxcnc on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
The first problem is Python.
Python is powerfull, but permanently developed, so python scripts are version sensitive.
LinuxCNC depends on Python...
Debian is conservative, Ubuntu is progressive, so there must be version mismatches.
Sometimes old programs not works with new OS, but worst is when works, but not properly, become unstable or some functionality gone....
Believe me, experiments like LinuxCNC+Ubuntu are not worth wasted time.
- Holzwurm56
- Thank you received: 9
02 Aug 2026 08:15 - 02 Aug 2026 08:20 #348377
by Holzwurm56
Replied by Holzwurm56 on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Hi Tommy, I downloaded the ISO from your first post. Which software did you use to calculate the MD5? I’m using MD5-Check and getting a different MD5. Or did you post a newer version in another thread? The UEFI installation method seems outdated—do I need to disable Secure Boot?
Many thanks,
Hans
Many thanks,
Hans
Last edit: 02 Aug 2026 08:20 by Holzwurm56.
- tightmopedman9
- Thank you received: 8
09 Aug 2026 06:13 #348584
by tightmopedman9
Replied by tightmopedman9 on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
MD5 is MD5 - if the hash changed due to the program used it wouldn't be a very good hash, ha. My guess is that the checksum wasn't updated after the .iso had been modified. I downloaded it twice and got the same checksum on both files: 512B3E5226CB71127215BCF65C6A9B46Hi Tommy, I downloaded the ISO from your first post. Which software did you use to calculate the MD5? I’m using MD5-Check and getting a different MD5. Or did you post a newer version in another thread? The UEFI installation method seems outdated—do I need to disable Secure Boot?
Many thanks,
Hans
09 Aug 2026 14:51 #348603
Sorry guys my bad, i apparently forgot to update the md5sum when i uploaded the new version.
Corrected and updated, thank you.
P.S.
I just downloaded fro google and checked the md5sum against the original in my NAS, md5sum checks fine for both as
512b3e5226cb71127215bcf65c6a9b46
P.S.
Time to create page: 1.128 seconds
