Linux_Mint_22.1_LinuxCNC_2.10.iso
- scotth
- Thank you received: 62
24 Mar 2025 22:33 #324842
by scotth
Replied by scotth on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
You are right, Rufus is the way to go on building the USB drive.
The only problem I'm having is the Software Manager hangs up and says "Loading please wait".
Linuxcnc loaded my old config files and started with no problems.
- Online
- Thank you received: 7478
24 Mar 2025 23:06 #324845
sudo apt install flatpak
That is the reason software manager does not start and i mentioned that i removed it as i never use it, i use terminal exclusively.
Replied by tommylight on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
In a terminalThe only problem I'm having is the Software Manager hangs up and says "Loading please wait".
The following user(s) said Thank You: scotth
- bartwaw
25 Mar 2025 23:23 - 25 Mar 2025 23:24 #324930
by bartwaw
Replied by bartwaw on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
After few years i'm slowly gatherig new stuff to make comeback to linuxcnc.
Generally i'm little bit affraid to getting back my small and lost knowledge
Now i got some sort of problem. Trying to get my WiFi dongle work after installing mint.
On Live this dongle works, but after instaling Mint on my M720q Mint shows on Advanced network connections WiFi (with known my network which i've provided during instalation from LIVE).
But on taskbar it only shows Ethernet.
Last edit: 25 Mar 2025 23:24 by bartwaw.
- scotth
25 Mar 2025 23:35 - 25 Mar 2025 23:44 #324933
by scotth
With the dongle in, try running Driver Manager.
Look at www.fosslinux.com/134500/how-to-install-...rs-on-linux-mint.htm
It covers Wi-Fi drivers.
Last edit: 25 Mar 2025 23:44 by scotth.
- Online
26 Mar 2025 00:50 - 26 Mar 2025 00:53 #324938
Yeah, forgot to mention that, most WiFi i have do not work with this kernel, while they all work with 4.9.n and 6.8.n RT kernels.
Did not bother with why at all, as i can reboot and choose the generic kernel where everything works.
Adding this to original post, thank you for reminding me.
Edit
Also added how to get to GRUB to choose the generic kernel in the original post.
Edit
Last edit: 26 Mar 2025 00:53 by tommylight. Reason: more info
The following user(s) said Thank You: bartwaw
- wdcnc
28 Mar 2025 12:25 #325158
by wdcnc
Replied by wdcnc on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
I'm currently running Mint 19.3 and the 2.9.0 pre-release with the 5.something RTAI kernel. Is there value in upgrading to mint 22.1 with the RT-preemtive kernel?
I don't have issue with version 2.9.0 pre-release but lack of 19.3 support concerns me since this system does have network connectivity for transferring files.
Thoughts?
Thoughts?
- Online
28 Mar 2025 12:53 #325159
No worries, it is Linux and 19.3 still gets security updates and Firefox also updates regularly.
I have probably over 10 machines on 19.3 in daily use, connected to internet with no issues.
The following user(s) said Thank You: wdcnc
- Online
29 Mar 2025 23:24 #325290
Had to change the RT kernel to 6.13 as when disabling BIOS stuff the 6.10 would fail to boot some 70% of the time.
This was on 2 laptops (Lenovo X1 Yoga and Yoga 370) and my main PC (14400 with RX6800).
So far tested on laptops only, will do more installs and if all is good, replace the ISO.
Stay tuned.
FYI:
6.10 works fine for Mesa boards, even with default BIOS settings, but will do 170000-280000 in latency, and that is on the limit of what i consider safe, disabling just Hyperthreading and ATM (or AMT?) would bring that down to safe numbers.
With everything in BIOS of Y370 disabled and CPU in powersave mode on batteries, i could get the latency under 100000 and testing with base period of 100000 would show no warnings for hours. Did not test with power attached.
Stay tuned.
FYI:
- scotth
30 Mar 2025 00:05 #325294
by scotth
The download still claims 2.10 rather than 2.13.
- Online
30 Mar 2025 00:31 #325295
Kernel is changed from 6.10.nn to 6.13.nn.
LinuxCNC is still the same 2.10 version, there is no "2.13" version of it.
I have not updated the download yet, only i after i do over 10 successful installs.
Time to create page: 0.230 seconds
