Axis configuration not fully working on 2.9.6
1 year 3 weeks ago #335927 by Aciera
I've just built the current 2.9 branch (ie 2.9.6) and tested "halui.machine.is-on" reacting to "halui.machine.on" and "halui.machine.is-off", works for me in both tested guis (axis, gmoccapy)
1 year 3 weeks ago #335932 by Fabse
Hey and thanks for the effort!
I tried a sim config and set the "halui.maschine.on" and I get "halui.maschine.is-on" to change state to on. With off it works in the other direction.
I then tried the same thing with my config (pendant off) and it works! When I turn my pendant on things go down hill... I then press the reset button on the pendant and I can get my "halui.maschine.is-on" to get stuck either on or off. If it is stuck, it does not change whith the GUI button either.
This is beyond confusing to me. Why does my cofig do that from version 2.9.5 onward?
1 year 3 weeks ago #336176 by ChrisB_II
I've gone back to 2.9.4 because of a similar problem with 2.9.5/6.
At first all buttons on the pendant work fine until I try to call an MDI_COMMAND_xx. The command itself is not executed but afterward there is a zombie process and most of the buttons on the pendant stop working. In halshow all buttons and connected signals still show activity - even MDI_COMMAND_xx are getting called - but nothing happens. After restarting linuxcnc everything ist back to normal. With 2.9.4 this does not happen! Seems like something is wrong in 2.9.5/6...
The following user(s) said Thank You: Fabse
1 year 3 weeks ago #336190 by Fabse
Hey and thanks for your reply!
I experimented with version 2.9.6 for a bit, but I can not find the fault that causes my problems. It just does not make sense that my config functions perfectly when running 2.9.4 and then goes broken after updating to 2.9.5/6.
I also noticed that calling MDI commands does not work. I have a command that zeroes my z-axis, which I can activate via a pyvcp button. This does not work anymore.
I am a bit relieved that I am not the only one having issues after updating, but I would love to find a solution to all of this!
As for now, I will stick to 2.9.4..
1 year 3 weeks ago #336228 by andypugh
Can you report this problem on the issue tracker?
github.com/LinuxCNC/linuxcnc/issues
1 year 3 weeks ago #336273 by ChrisB_II
I hope it is understandable - my english is way too rusty to explain such a problem ;-)
github.com/LinuxCNC/linuxcnc/issues/3583
The following user(s) said Thank You: Aciera, Fabse
Time to create page: 0.087 seconds
