- Thank you received: 83
mirror backplot
- billykid
4 months 2 weeks ago #347039
by billykid
Replied by billykid on topic mirror backplot
In the screenshot of the first post the view is that of the real machine, with x0 y0 at the top right but y moving away becomes negative and if I modify the axis to make it positive, home moves to the left and the backplot is mirrored.
- Online
- Thank you received: 2177
4 months 2 weeks ago - 4 months 2 weeks ago #347044
Replied by Aciera on topic mirror backplot
Last edit: 4 months 2 weeks ago by Aciera.
- billykid
4 months 2 weeks ago #347073
by billykid
I'm definitely wrong because I was a machinery repairman. I started in the '80s with Olivetti CNZ machines, all transistors with delay lines.
The last 20 years of work have been spent welding and cutting. I built a small CNC and a plasma cutter for fun. In the photo, you can see the machine in the home position; the crosshead to the left is negative, and the carriage coming forward is positive. It doesn't look right because with the handwheel clockwise, one axis is positive and the other negative, it's easy to make a mistake. But if I invert the crosshead to make them go the same way, the plot is mirrored. But I don't even waste too much time on it because I have Sanmotion AC motors, so I'll do everything properly.
- Thank you received: 4153
4 months 2 weeks ago #347079
Replied by rodw on topic mirror backplot
Linuxcnc will let you do anything but there is an expected paradigm. If you go against the paradigm, life becomes painful.
Think of the home position as being 0,0 on those Cartesian graphs you drew at school and the table represents one of those quadrants.
So if the current position is home, X & Y need to be negative values to move away from home.
Another way of looking at the expected paradigm is that the front of the machine is where you stand at the machine. Home should be on your left and closest to you with the gantry going across your chest. So to satisfy that rule, you need to stand at the back of the machine behind the gantry.
So you could
1. stand behind the machine
2, Turn the machine around so the back as shown is the front of the machine
3. Live with negative X & Y coordinates
4. Move your home switches to the front left of the machine
5. In your homing configuration, set the home position to max-X and max-Y coordinates so it knows the home switches are at the back of the machine.
I might add if your origin/home respects the cartesian origin and you accept the quadrant you are in, it all becomes moot when you place your workpiece on the table and set the part origin with G54 offsets. Once you touch off, everything is referenced to the part origin.
So you could
- billykid
4 months 2 weeks ago #347084
by billykid
Thanks everyone! Once I install the Sanmotion AC servos, I'll see how to configure them properly.
Time to create page: 0.362 seconds
