EMC2 axis display program error
09 Jan 2011 20:29 #6583 by johnthomas75
EMC2 axis display program error was created by johnthomas75
I keep running into this error and cant figure out why?
"Starting EMC2 DISPLAY program: axis
USRMOT: ERROR: command timeout
waiting for s.axes"
Any ideas?
Much appreciated!!!
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/john/emc2/configs/Mantis9'
Machine configuration file is 'Mantis9.ini'
INIFILE=/home/john/emc2/configs/Mantis9/Mantis9.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=emc.nml
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Starting EMC2 TASK program: milltask
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=1742
Killing task milltask, PID=1813
Timeout, trying kill -9
Cleanup done
09 Jan 2011 21:16 #6584 by BigJohnT
Replied by BigJohnT on topic Re:EMC2 axis display program error
Did you just upgrade from 2.3 to 2.4?
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?UPDATING
09 Jan 2011 21:21 #6585 by johnthomas75
Replied by johnthomas75 on topic Re:EMC2 axis display program error
I am using 2.4.6.
I think it did update from 2.4.3 as this was the version on the ubuntu-emc install disk.
09 Jan 2011 21:25 #6586 by johnthomas75
I checked the changes in your link, but all teh changes dont appear to cause the specific error that I encountered...
10 Jan 2011 12:19 #6594 by BigJohnT
Updating from 2.4.x to 2.4.6 should not break anything.
So does Axis run sometimes and sometimes not, not at all, ran for a few months then quit etc?
10 Jan 2011 12:59 #6600 by alex_joni
Replied by alex_joni on topic Re:EMC2 axis display program error
can you post your config files?
Alex
10 Jan 2011 13:42 #6601 by johnthomas75
thanks for your help!
Re: BigJohnT: Axis hasn't run yet as I am a new EMC2 user.
Re Alex_joni:
The configuration file is here:
makeyourbot.org/local--files/emc/9config.zip
10 Jan 2011 13:55 - 10 Jan 2011 13:56 #6602 by BigJohnT
Remove the line "NML_FILE = emc.nml" from the [EMC] section of your Mantis9.ini file.
I'm not sure why Step Configure Wizard put that in there... was the config files from 2.3?
Last edit: 10 Jan 2011 13:56 by BigJohnT.
10 Jan 2011 23:05 #6606 by johnthomas75
tried that but it didnt fix the underlying error related to the above....
11 Jan 2011 00:51 #6608 by BigJohnT
I ran your config after removing that line with no problem... so you have some other issue
hmmm
Clear dmesg then run your config from a terminal window then pipe dmesg to a file and attache it.
You can see how to do all that in the Getting Started Manual.
Time to create page: 0.756 seconds
