EMC2 axis display program error
- BigJohnT
- Thank you received: 1176
11 Jan 2011 14:42 #6625
by BigJohnT
Replied by BigJohnT on topic Re:EMC2 axis display program error
Ok, that looks good.
From the CNC menu can you run the Axis sim?
- BigJohnT
11 Jan 2011 14:44 #6626
by BigJohnT
But something is still wrong if you can't run the Latency Test...
Just for grins did you reboot?
Also boot from the liveCD and run the latency test...
- johnthomas75
13 Jan 2011 15:40 #6660
by johnthomas75
Replied by johnthomas75 on topic Re:EMC2 axis display program error
So reinstalled the bundled linux-emc and didnt do any updates. plugged everything in and tried to boot emc w/the same custom confirguration and got a new set of error messages...
Any ideas?
pastebin.com/preg9fa0
Any ideas?
- johnthomas75
13 Jan 2011 15:48 #6661
by johnthomas75
now removed the reference to the emc file which I did before in the mantis 9 ini file and :
pastebin.com/YRgTsiqc
- Thank you received: 4994
13 Jan 2011 16:30 #6662
Replied by andypugh on topic Re:EMC2 axis display program error
I am a bit stumped, but wonder if it is a graphics driver problem (Axis not starting because openGL won't start).
If you change the display to tkemc do you get the same thing?
If that starts OK (or even if it gets a bit further) then you could try the tip here:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Tro...oftware_based_OpenGL
- johnthomas75
13 Jan 2011 20:40 #6667
by johnthomas75
Doesnt work:
Machine configuration directory is '/home/john/emc2/configs/Mantis9'
Machine configuration file is 'Mantis9.ini'
Starting EMC2...
Unrecognized line skipped: POC FMS LEN DIAM COMMENT
Shutting down and cleaning up EMC2...
/usr/bin/emc: line 358: 2664 Killed $EMCTASK -ini "$INIFILE"
Cleanup done
then nothing happens!
Starting EMC2...
Cleanup done
13 Jan 2011 23:39 #6670
Sorry, can you say which of the options didn't work.
I appreciate that this is frustrating, especially when the software is being so uncommunicative about what the problem is.
- johnthomas75
13 Jan 2011 23:43 #6671
by johnthomas75
using tkemc instead doesnt work.
thanks for the help!
- BigJohnT
13 Jan 2011 23:59 #6672
by BigJohnT
Andy,
I ran his config (on page 2) after removing the NML line from the ini file...
14 Jan 2011 01:07 #6673
I will be quite cross if that is still in there.
