EMC2 axis display program error
- BigJohnT
- Thank you received: 1176
18 Jan 2011 12:48 - 18 Jan 2011 12:49 #6763
by BigJohnT
Replied by BigJohnT on topic Re:EMC2 axis display program error
Unfortunately you can't run EMC in a virtual machine because of the latency (the error you got).
I see you have a quad core processor and there have been some issues with them in the past as I recall. I did a search on the wiki and found this page that has some info on quad core processors.
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Ubuntu10.04PackageNotes
EMC does not need a multi core processor to work. So if you have a single or double core machine to try it on you might have better luck.
What did you use to get the hardware print out?
Last edit: 18 Jan 2011 12:49 by BigJohnT.
- Rick G
- Thank you received: 155
11 Feb 2011 11:13 #7140
by Rick G
Replied by Rick G on topic Re:EMC2 axis display program error
I just tired 10.04 on a new AMD 6 core. Out of the box latency test reports 0 and does not run, EMC reports error. Set computer to 1 core in BIOS and now appears to run fine.
Rick G
Rick G
Time to create page: 0.160 seconds
