MONSTER - A learning experience... pyVCP machine
11 years 4 weeks ago - 11 years 4 weeks ago #63428 by cncbasher
here you go :
loardrt or2 count=1
net probe1 parport.0.pin-10-in or2.0.ino
net probe2 parport.0.pin-11-in or2.0.in1
net probe-in motion,probe-input or2.0.out
Last edit: 11 years 4 weeks ago by cncbasher.
11 years 4 weeks ago - 11 years 4 weeks ago #63431 by eFalegname
I lost something, could you please explain me what is the difference between this post:
loadrt or2 count=1
addf or2.0 servo-thread
net probe1 or2.0.in0 parport.0.pin-11-in
net probe2 or2.0.in1 parport.0.pin-12-in-not
net probe motion.probe-input or2.0.out
and this one:
loardrt or2 count=1
net probe1 parport.0.pin-11-in or2.0.in0
net probe2 parport.0.pin-12-in or2.0.in1
net probe-in motion.probe-input or2.0.out
in this case we must also consider that the first probe (pin 11) is normally closed and the second one (port 12) is normally open
Last edit: 11 years 4 weeks ago by eFalegname.
11 years 3 weeks ago - 11 years 3 weeks ago #63437 by cncbasher
then by all means add the -not and change pin numbers accordingly , to suit your requirement
the or2 function does work as you described
it was a suggestion that you may consider adding an appropriate pin to either select the input or
have a situation where you know the correct probe is selected , but as i do not know the probes in question , i left a generic answer
Last edit: 11 years 3 weeks ago by cncbasher.
11 years 3 weeks ago #63518 by eFalegname
Cncbasher Hi, thanks for your advice, I did not answer you before because I was trying to understand how mux_generic works, I ask you again please to clarify me another doubt. Will be possible by implementing a function mux generic put a couple of pyvcp radio buttons to choose the probe I want to use and change the status of parport pin from "IN" to "IN-NOT" and so in order to use the two probes with the same pin.
I have a "NO" fixed probe on the Router table to measure the length of the tool and a second one "NC" like a Renishaw probe that I mount on the spindle and I wish to connect both to the same parport pin. Is that possible?
11 years 3 weeks ago #63526 by Askjerry
I just made a switch so that I could select between normally open and normally closed.
It works well... here is the video that i did...
Jerry
11 years 3 weeks ago #63528 by eFalegname
Thank you Jerry, I saw your video. I have this signal inverter NPN PNP , but my question is: Is there a way to change the parport pin signal from IN to IN-NOT with a HAL component? I want to check a pyvcp radio button to switch between the "NO" and "NC" probes using the same parport pin swaping the IN entries
Time to create page: 0.251 seconds
