MONSTER - A learning experience... pyVCP machine
10 years 1 month ago #81071 by Askjerry
It replaces the stock image and works exactly as the original image does. I have the time set to 4 or 5 seconds.
You can configure it however you like... Or set it to none if you prefer.
The following user(s) said Thank You: liwenbinbit
10 years 1 month ago #81072 by liwenbinbit
Interesting! Mine doesn't work, it shows nothing. I followed exactly what you have configured for this intro_graphic .
What version are you using ? I am on
LinuxCNC 2.7.7 .
Thanks for your reply and sharing, Jerry.
10 years 1 month ago #81073 by Askjerry
If it shows nothing... it is because LinuxCNC cannot find the file, or the file is in the wrong format.
In the monster.ini file there is a line that defines the graphic...
INTRO_GRAPHIC = ./IMAGES/splash.gif
This starts with the directory or folder that the image is stored in... the dot-slash indicates going from the current location into one level of directories... in this case IMAGES/ folder. Inside of that folder... the actual graphic file splash.gif must reside.
You must create a sub-directory inside your configuration folder called IMAGES. Then place the graphic inside that sub-folder.
Once you do that... it should work fine... providing you updated the line in the ini file to match.
If you are still stuck... ZIP the whole CONFIG folder and email it to me... I'll take a look and configure it for you.
My Email is: jerryarutherford(at)gmail(dot)com Obviously I replaced the "@" and "." so i don't get hit by spambots.
10 years 1 month ago #81074 by liwenbinbit
Thanks, Jerry.
I just made it ! The reason is my previous image is NOT REAL .gif, it was a .jpeg file and I renamed it as .gif.
It can be opened by other software but it seems that LinuxCNC doesn't read this "fake" gif well.
10 years 1 month ago #81075 by Askjerry
No. A gif and a jpg have different compression routines... and Linux (or any operating software) would fail to properly open it because it was using the wrong method.
I find that LinuxCNC seems to "like" the GIF and PNG format better than others. I use INKSCAPE to create my graphics, then export them to PNG. I find the images look better, have more colors, and the transparency works well.
Jerry
10 years 1 month ago #81113 by liwenbinbit
Thank you, Jerry !
Time to create page: 0.206 seconds
