The opto is what was suspected the first time in St Louis a few years back... this time... when I send the reset signal... the micro responds... but the MOSFETS don't lock in... so i think they are toast. I ordered new MOSFETS and the OPTO simply because if you are in there changing parts... what's 81 cents more right?
As your post stated
tommylight, my calculations were probably off... the the current draw is very close to the max... plus the issue of instant MOSFET death if the motor coasts due to an ESTOP or similar. Changing the encoders is a $300 adventure... and if I'm going to drop that much... and still potentially have some wire / current / spike issue... then it's probably better to drop $700, replace all the
35 year old motors, redo the wiring, and replace the single mongo (40 pound) transformer with independent power supplies.
Plus... the new controllers have built-in optocouplers on every input... that's going to isolate the parallel ports. Then... I'll add optocouplers to the inputs for every magnetic switch... because they all have a 9v input... and if any leaked... that could have been the cause of the parallel port zap. The outputs to the 120vac have always had industrial opto units on them... so this way every input and output will be protected.
As for the encoders I was using
cncnoel... these are what I was using...
usdigital.com/products/encoders/incremental/rotary/shaft/H1
They have an integrated shaft that I connected to the existing upper shaft. It originally had a 50-year old design of resistors and cam followers.
(I regret not photographing or video recording the old units... all brass workings.) At the time... this was a HUGE upgrade.
I know that with steppers there is the potential to miss steps... but if it is adjusted properly... with modern microstepping... the chances are low. I said the MONSTER was a learning experience... not just for you... but for me too! I'm hopeful that this really improves the machine. I have not played with steppers this big before... I hope they are enough... I'm committed now.
