Askjerry wrote: adding a second parallel port today to give me more inputs.
Not much chance of finding a PC to plug it in to nowadays, but I wrote a driver for a different ISA card and it was pretty simple. For some reason it doesn't show up in the html documentation, but there is a man-page.Askjerry wrote: I actually have an older AR-B2201 card that I had used originally, it had 32 Input, 32 Output pins. Unfortunately, older style PC connector, so it doesn't fit anymore. Manual: www.acrosser.com/download/2201bv10.pdf
Normally you would use pncconf but I am not sure if that has caught up with the 7i90 yet. It does support the 7i43.do you have a link to someone showing the installation and setup using LinuxCNC?
