Hi. I need some help configuring this to my 3 axis mill. I *think* I got the most basic configs entered. When trying to open up EMC, I get the following error:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.3
Machine configuration directory is '/home/bradley/linuxcnc/configs/SuperMax'
Machine configuration file is 'SuperMax.ini'
INIFILE=/home/bradley/linuxcnc/configs/SuperMax/SuperMax.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Killing task linuxcncsvr, PID=2525
waiting for XHC-HB04 device
found XHC-HB04 device
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
xhc-hb04.hal:23: Pin 'axis.3.jog-enable' does not exist
2525
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 447.431153] I-pipe: Domain RTAI registered.
[ 447.431158] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 447.431159] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 447.431193] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 447.431194] PIPELINE layers:
[ 447.431196] fb11be20 9ac15d93 RTAI 200
[ 447.431198] c085cb20 0 Linux 100
[ 447.443525] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 447.443920] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 447.443925] RTAI[sched]: hard timer type/freq = APIC/12556305(Hz); default timing: periodic; linear timed lists.
[ 447.443927] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3214281000 hz.
[ 447.443929] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 447.443989] RTAI[usi]: enabled.
[ 447.470382] RTAI[math]: loaded.
[ 447.525567] config string '0x378 out '
[ 449.805553] RTAI[math]: unloaded.
[ 449.817581] SCHED releases registered named ALIEN RTGLBH
[ 449.848511] RTAI[malloc]: unloaded.
[ 449.948350] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 449.950022] I-pipe: Domain RTAI unregistered.
[ 449.950059] RTAI[hal]: unmounted.
When attempting to see what output each key gives, I get no feedback when pressing any keys:
CNC-Mill:~$ /usr/local/bin/xhc-hb04
Creating pin: xhc-hb04.x.pos-absolute
Creating pin: xhc-hb04.y.pos-absolute
Creating pin: xhc-hb04.z.pos-absolute
Creating pin: xhc-hb04.a.pos-absolute
Creating pin: xhc-hb04.x.pos-relative
Creating pin: xhc-hb04.y.pos-relative
Creating pin: xhc-hb04.z.pos-relative
Creating pin: xhc-hb04.a.pos-relative
Creating pin: xhc-hb04.feed-value
Creating pin: xhc-hb04.feed-override
Creating pin: xhc-hb04.spindle-rps
Creating pin: xhc-hb04.spindle-override
Creating pin: xhc-hb04.jog.enable-off
Creating pin: xhc-hb04.jog.enable-x
Creating pin: xhc-hb04.jog.enable-y
Creating pin: xhc-hb04.jog.enable-z
Creating pin: xhc-hb04.jog.enable-a
Creating pin: xhc-hb04.jog.enable-feed-override
Creating pin: xhc-hb04.jog.enable-spindle-override
Creating pin: xhc-hb04.jog.scale
Creating pin: xhc-hb04.jog.counts
Creating pin: xhc-hb04.jog.counts-neg
Creating pin: xhc-hb04.jog.velocity
Creating pin: xhc-hb04.jog.max-velocity
Creating pin: xhc-hb04.jog.increment
Creating pin: xhc-hb04.jog.plus-x
Creating pin: xhc-hb04.jog.minus-x
Creating pin: xhc-hb04.jog.plus-y
Creating pin: xhc-hb04.jog.minus-y
Creating pin: xhc-hb04.jog.plus-z
Creating pin: xhc-hb04.jog.minus-z
Creating pin: xhc-hb04.jog.plus-a
Creating pin: xhc-hb04.jog.minus-a
Any ideas?
