XHC-HB04 wireless MPG pendant HAL module
13 years 4 weeks ago #39515 by rmagnus
My machine is a probotix comet so yes it has 2 motors for the y axis. Should I do something different?
Thank you!
13 years 4 weeks ago #39516 by rmagnus
I will try it and report back thanks!
So for the Probotix comet with 2 motors for the gantry what should I be aware of ? I don't want to damage it
Thank you
13 years 4 weeks ago #39517 by andypugh
rmagnus wrote: ISo for the Probotix comet with 2 motors for the gantry what should I be aware of ? I don't want to damage it
Are you using trivkins or gantrykins?
Does the machine start up in Joint mode?
13 years 4 weeks ago #39519 by rmagnus
I have no idea! Probotix ships the machine ready to run so this is the first time I hear about that
Where do I look for. Excuse my ignorance
13 years 4 weeks ago #39537 by andypugh
rmagnus wrote: Where do I look for. Excuse my ignorance
When you start the machine, are the axes referred to as 0,1,2,3 and do you then need to switch to World Mode after homing?
If no then you don't have a Joint Mode to worry about.
The following user(s) said Thank You: rmagnus
13 years 3 weeks ago #39592 by rmagnus
Hello Frederic
Thank you for the help.
I had problem implementing.
I did what you suggest but got this error:
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
Unrecognized line skipped: POC FMS LEN DIAM COMMENT
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/and2.ko': -1 File exists
xhc-hb04.hal:3: exit value: 1
xhc-hb04.hal:3: insmod failed, returned -1
See the output of 'dmesg' for more information.
2375
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
And if I comment the lone loadrt and2 count=3 I get this error.....
xhc-hb04.hal:52: Pin 'and2.0.in0' was already linked to signal 'switches-y1'
2076
Please advice!
Thank you
Rodolfo
Time to create page: 0.232 seconds
