XHC-HB04 wireless MPG pendant HAL module
10 years 8 months ago #70686 by blacksmith99
dgarret,
From the xhc-hb04.tcl file:
net pendant:spindle-rps <= motion.spindle-speed-out-rps-abs \
=> xhc-hb04.spindle-rps
From the SX3_parallel_hb04.ini file:
net spindle-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
changed to:
#net spindle-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
I commented out the line in the SX3_parallel_hb04.ini file and as you commented it was not connected.
That got it working. Thank you.
Regards,
Matt
10 years 6 months ago - 10 years 6 months ago #73142 by dannym
Throwing this into this megathread:
I'm getting "Missing Stanza: [XHC_HB04_BUTTONS]"
[HAL]
HALUI=halui
HALFILE = 7i92_general.hal
HALFILE = xhc-hb04.hal
HALFILE = LIB:xhc-hb04.tcl
xhc-hb04.hal:
loadusr -W xhc-hb04 -I xhc-hb04-layout2.ini -H
xhc-hb04-layout2.ini:
#INCLUDE layout2.inc
layout2.inc:
[XHC_HB04_BUTTONS]
all these .ini/.inc files are already copied to linuxcnc/configs. They're unmodified.
Is is saying that XHC_HB04_BUTTONS is required, and can't be found? Why can't it be found?
EDIT: shoot, that that INCLUDE line commented out??
Last edit: 10 years 6 months ago by dannym.
10 years 6 months ago #73155 by cncbasher
layout 2.inc is your list of buttons. and it cant load or can't find them
#INCLUDE layout2.inc , needs to be included at the top of your ini file
you appear to be mixing the older xhc install , with the newer version .
which version of linuxcnc are you running ? older versions will not have the #INCLUDE function
10 years 6 months ago - 10 years 6 months ago #73205 by dannym
It's LinuxCNC 2.7.4, Preempt RTK.
I think all the files came from the linuxcnc directory. I did see online that people had problems where the .ini file used dashes instead of underscores in the names, but there's none of that problem here. All underscores.
Like I say, #INCLUDE layout2.inc is right there at the top of xhc-hb04-layout2.ini, and that is referenced in the xhc-hb04.hal which is referenced from the main .ini. It seems like it should see it!
10 years 6 months ago - 10 years 6 months ago #73460 by dannym
OK back at the shop-
I stopped worrying about why the xhc-hb04-layout2.in and layout2.inc didn't get included and just added the relevant contents to my .ini file.
Now I get
monitor-xhc-hb04: xhc-hb04 comp not loaded
monitor-xhc-hb04: <pin or parameter 'xhc-hb04.connected' not found>
monitor-xhc-hb04: exiting
any idea?
10 years 4 months ago #76314 by vre
No eBay APP ID and/or Cert ID defined in Kunena configurationHas anyone tested this version if works with linuxcnc ?
