Code:loadrt orient addf orient.0 servo-thread #loadrt mux2 -- This has already been loaded in the sim_vmc.hal addf mux2.0 servo-thread # chooses which pid output goes to the spindle speed control
Code:#for a real spindle run by a VFD loadrt abs addf abs.0.servo-thread net spindle-cmd mux2.0.out abs.0.in net spindle-cmd-abs hm2_5i25.0.7i77.0.1.analogout5 #net spindle-fwd abs.0.is-positive parport.0.pin-NN-out #net spindle-rev abs.0.is-negative parport.0.pin-NN-out
thewho wrote: Like this?
Code:#for a real spindle run by a VFD loadrt abs addf abs.0.servo-thread net spindle-cmd mux2.0.out hm2_5i25.0.7i77.0.1.analogout5 net spindle-cmd-abs hm2_5i25.0.7i77.0.1.analogout5
You will need to tune the PID values in the INI file.thewho wrote: Tried a M3 S100 but It doesn't compensate at all? Am I missing something here?
M33.1 Does not do anything ether.
