Ok,I think I've got it!
Yesterday I was testing the system. thinking first in the update I moved my debian wheezy to debian jessi and afterwards tried to update linuxcnc.Everything seemed right until I tried to open my-mill then a linuxcnc error appeared. I thought the issue was because I had created the file in the older version so I created a new one but had no success. Desperate and a little upset I made an afresh installation of debian wheezy, I updated cnclinux and was able to open up the file.
I went back to do all the steps Fixer stated from page 1 and connected the Pokeys in windows to know the serial number. In the file my-mill.hall I wrote loadusr pokeys, ran the linuxcnc and was now able to see the pins. I shut down linuxcnc and now in my-mill.hall I wrote pokeys.0.devSerial 66258 save file and try to open linuxcnc send me an error:
Debug file information:
./my-mill.hal:7: parameter or pin 'pokeys.0.devSerial' not found
I change the code loadusr pokeys and pokeys.0.devSerial to custom.hal and show me an error, if I put the loadusr pokeys in my-mill.hal and pokeys.0.devSerial66258 in custom.hal linuxcnc run fine, and pokeys.0.err are false and pokeys.0.alive start blinking. Is this procedure correct?
I tried to use estop with pokeys to test but i did not get it work, in custom.hal I wrote net estop-ext <= pokeys.0.in-52 it dont send me errors and in HAL configuration the pin 52 show :
Owner Type Dir Value Name
7 bit OUT FALSE pokeys.0.in-52 ==>estop-ext
Thank you so much for your help, have a nice day.
