Pokeys_homecomp EncoderSearch / Encoder Arm Topic: Pos_Fb Following errors
8 years 3 months ago #114941 by andypugh
Replied by andypugh on topic Pokeys
Just to be clear, does the module load and create HAL pins that do not work / change state, or does the module load and not create any HAL pins?
8 years 3 months ago #114944 by jbunch
Replied by jbunch on topic Pokeys
I think that the pokeys out of the box has no programing its pins are undefined. Did you load the pokeys app in a windows machine and define what the pins are. Input/output keypad, matrix. This might be your problem.
Jim
8 years 3 months ago - 8 years 3 months ago #115011 by Erikcnc
Replied by Erikcnc on topic Pokeys
Yes, if is load Halshow i see the HAL pins from the pokeys. But nothing changes if i puls for example pin 6.
@jbunch
I define pin 1 to 6 as input die buttons and pin 45 to 47 for potentiometers in pokeys software on Windows.
Last edit: 8 years 3 months ago by Erikcnc.
8 years 3 months ago #115126 by andypugh
Halshow only updates the "watch" tab. Is that where you are looking?
8 years 3 months ago - 8 years 3 months ago #115139 by Erikcnc
Ah...No, nothing in watch! Just empty screen.
I'm guessing it has to look like this? But then with my defined pins?
Example:
8 years 3 months ago #115142 by andypugh
Yes, you should see your PoKeys on the left and can add the inputs to see what is going on (if anything).
You can also save the layout for next time in the File menu.
Time to create page: 0.114 seconds
