andypugh wrote: Well, that's weird.
"show pin" was only meant as a way to get some output to check if the pin existed. It wasn't meant to fix the problem.
Does the problem un-fix if you take the "show pin" back out again?
I don't see any reason for "setp pokets.0.devSerial" to need to be in the postgui call list.
It looks like some sort of race condition, which is odd as the -W should wait for completion.
Do you have the potentiometer values appearing and changing in HAL?
It might just be that "show pin" uses up a couple of mS of CPU timeErikcnc wrote: I could try to remove 'show pin' and check if its realy that issue.
No, they are optional, for human legibility.Another thing, those arrows are they have a function? Does it make a difirents how you insert them? ( <= or => )
Halmeter (From the "Machine" menu in Axis) will show you the value of a HAL pin or parameter.About those potentiometers, i set them as analog input with the pokeys software.
I have to check how i can see values insted of I/0 dots.
